DIY LED Tail Light Kit
Old Jan 12, 2022 | 11:40 AM
High PSI's Avatar
High PSI
Default DIY LED Tail Light Kit
Anyone have any experience with one of these kits on an SC?
https://www.illumaesthetic.com/produ...mplete-diy-kit
Old Jan 12, 2022 | 11:44 PM
ninetwo's Avatar
ninetwo
I've seen a few clips of them on facebook. looks really good. The company has been extremely responsive to everything I've inquired on answering basically instantly. Pretty sure you want to use 95 housings with them, and whatever lens you want. They have a group you can join on fb if you make an order, where people will give you ideas/advice on wiring / assembly etc.
Old Jan 13, 2022 | 01:32 AM
High PSI's Avatar
High PSI
If you or anyone else gives them a go w/ SC tails and documents it along the way, that would be great. I've got a spare set of 98 tails already apart that I'm in the middle of de-chroming and making fully red. I was just going to slap them together as-is and put LED bulbs behind them, but this looks like a great mid-point solution between doing that and dropping $1k+ on a ready-to-go custom set.
Old Jan 14, 2022 | 11:37 AM
ACleanSC4's Avatar
ACleanSC4
I purchased their DIY kit for the 95-96 tails, been watching a ton of their how-to YouTube videos but have yet to sit down and try it.
I also received a deal I couldn't refuse so I'm waiting for a custom 97-00 set that I'll debut once I get it in the next month.
Old Jan 14, 2022 | 01:19 PM
ninetwo's Avatar
ninetwo
I'll keep an eye out
you should record your progress if you think about it
the customs happen to be the dechromed oem 97 set I've been seeing for sale by chance?
Old Jan 14, 2022 | 03:52 PM
ACleanSC4's Avatar
ACleanSC4
No, these 97+ tails are using the C diffused style kit from illumaesthetic but with a few upgrades that haven't been done before on the SC.
Old Jan 15, 2022 | 01:58 AM
High PSI's Avatar
High PSI
Were these built by illumaesthetic, by someone using one of their kits exclusively or by someone who modified one of their kits? The C-diffused style for the 97+ tails is what I was going to be going with. The only modification I was going to make was to change the amber to red, but I'm very keen to see what was done on your set.
Please keep us updated!
Old Jan 15, 2022 | 09:25 AM
ACleanSC4's Avatar
ACleanSC4
These are built by one of their referred builders, it uses their diffused C panel and different LEDs and custom reverse. Full details soon!
Old Jan 15, 2022 | 11:35 AM
CLass of 1's Avatar
CLass of 1
Interested to see the progress. I had considered this same kit but I felt like the LED’s were too small and made the lights look a little in the cheap side. Most OE’s today are using larger LED’s which are a bit pricier
Eager to see what you’ve come up with!
Nick
LS430cb
Feb 29, 2024 04:43 AM
Houston3gs
Aug 12, 2018 04:38 PM
highergrou
Aug 19, 2014 06:19 PM
rvpps2roks
CT 200h Model (2011-2017)
16
Feb 15, 2013 07:55 PM
