Best Radiator replacement SC400
What’s the best most efficient radiator to get when replacing the OEM Denso unit on a 1991 UZZ31 (now supercharged). One that will drop in.
Available in the UK please, I don’t want to pay a fortune for shipping!
I also want your opinions on replacing the fans with electric ones.
So many options….
want to see more of the supercharger build? Let me know and I’ll post pics and videos here. Thanks
Banners.
Last edited by Banners; Apr 21, 2022 at 09:01 AM. Reason: Wrong group? Admin delete if required. Thnx.
I think the go-to radiator upgrade for most SC's and Soarers is the Koyo or Mishimoto radiator for the Supra MKIV. However the SC400 (and Soarer V8) fan shroud requires custom modifications to it or custom brackets for it to bolt up if you have retained a factory mechanical or hydraulic cooling fan on your 1UZ.
Also ALL aftermarket radiators for the SC/Soarer 1JZ/MKIV Supra are for manual transmission applications so if you have an automatic you will need to add your own transmission fluid cooler.
I know of no direct bolt-in aftermarket radiator upgrade specifically designed for the SC400/Soarer V8 but these threads may give you an idea of how to go about adapting an MKIV style radiator for your SC400.
https://www.clublexus.com/forums/per...s-of-pics.html
https://www.clublexus.com/forums/per...-radiator.html
https://www.clublexus.com/forums/sc-...an-shroud.html
Whatever cooling fan system you use, make sure your fans have proper shrouds. The Titan Motorsports (USA but can ship) custom fan shroud for mounting OEM Lexus IS300 dual OEM electric cooling fans is the best all-electric cooling fan solution you will find. Highly durable for long term use, Toyota/Lexus OEM quality, heavy duty cycle fans.
We'd love to see pictures of your turbocharged SC400! I am certain you have one of a very few in the UK since you've got a LHD model!
By all means, start a thread in our SC300/400 > Build Threads subsection
