- Got my new 4" to dual 3" Setup done!
- swapp the head or not?
- Apparently my car is quicker than I thought
- anybody else see this?
- Resurfacing the flywheel
- Help: Pulling Out The Tranny On 1jz :::in Progress:::
- LSD questions...
- Brake light comes on in my 95 sc300
- Overheating issue
- 1jz OEM blow off valve replacement?
- it died =/
- SAFC WOT vs regular driving
- any one using the xspower turbo kit?
- Timing belt, water pump and PS hose $1700
- what is EGR?
- exhaust silencer magic trick??
- 1jz ecu mounting without extending harness??
- PA emissions and turbo SC3
- what do you guys consider a healthy motor
- Fuel tank Denmension?
- Help - Boosting Problem
- O2
- Thermal Fan Clutch?
- Strange chatter sound when accelerating??
- From Mild to Wild 1jzgte
- sc400 abs/trac question. Need help!!! dtc codes...
- Turning up Trans line pressure.. SC400
- question about n/a motor.
- traction off, engine light on!!!!
- Starter Issues or can it be more?
- Auto Supra TT Diff Installed (LSD and 3.76 gears)
- GTE power issues
- Torque damper?
- Greddy Catch Can Contents, is this normal ?
- 1jz ECU Problems, Anyone Else?
- Starter locking?
- LS1 into a SC300/400
- Aod-e (4r70w)
- Boosting my 95SC4 and some other projects
- Car dies randomly
- 99 SC300 With A W58 5 Speed Trans.
- Best spark plug for a stock SC400..................
- How strong are SC300 Axles? Anyone break one?
- JDM vs. USDM...
- car is misfiring at idle
- traction off light, check engine light ON!!!
- 2JZSwap.com / Tech2Motorsports shifter: A review
- fmic piping ?
- what throttle cable wiht 1jz swap?
- 1jz300 installs with Todd....56k BEWARE
- MSD BTM - Boost Timing Master - 2 Distributors?
- getting a tune up
- Sweet times..... NOT! Engine = vibrator except 300lbs..
- overheating issues
- Exhaust suggestions for boosted cars
- Torque Converter for 99SC400
- Looking for Someone(In Regards to a Manifold)
- Running stock 15.7 quarter mile... Help me drop that into the 14s
- Electric Fan
- High flow cats/headers for 99SC400
- need a new lsd diff broke while doing a burnout
- 99 SC400 catalyc converter
- Here we go... new engine and FI stuff on the way!!
- Optimum take off for auto?
- I know I am going to regret this.."BFI"...........
- 1jz-gte spark plugs / oil filter
- What's the first thing for a SC400/93.........
- Yay New exhaust setup :D
- N1 Style Mufflers??!?!
- safc II settings
- What can be used for Power or Ground Distribution Box? (for gauges and such)
- butterfly in n/a intake mani???
- Clutch Line Removal???
- Engine Ground - Inside Passenger Cabin?
- Engine slightly skakes car
- 2jz-gte swap and the gte throttle cable is short????
- what is the tork on the sc300 valve cover bolts?
- Exhaust........
- What upgrades could you do with $2,500?
- Bearings?
- Need a few 1j swap confirmations
- Power steering high pressure hose question/SC300
- E-fans in SC400's?
- 1999 2jz w/ vvti into 1992 SC 300
- R154 box in JZA80, speed sensor question
- Push Start?
- SAFC II question PLEASE ANWSER IF U KNOW ASAP
- is yellow the tps 0.5 volt out put? n20 wiring.
- PLX User's, Simple Wiring Question
- Changing fuel pump with full tank of gas
- MAF (LS400- SC400) compatable?
- Need Help!!!!!!!!
- Help with engine issues
- My SC300 NA-T done. Pics and vid
- radiator coolant line nipple broke need help
- 550cc Injector Upgrade
- 1JZ Cam Sensors and CPS Sensor are they compatible with 2jz
- 1j auto tranny troubles
- serpentine belt replacement help
- R154 prices???
- Speed cut?
- Clutch pedal install
- Timing Belt Issue
- Crowler Valves
- sc300 differential questions
- Help plz Car shuts down while driving?
- Who is running an AEM?
- what is a complete 5 spd swap worth??
- where can i get tex headers?
- CCC-TT's 2JZ-GE to 1JZ-GTE swap
- o2 sensor mounting question
- nobody buy this trans on e-bay
- Vid of Texas Jam 07 with 970rwhp SC300
- 2 fuel filters in the sc300?
- power steering pressure sensor Help
- data port on ODB1 2jz-ge cars
- Smell some gas in the ride
- need a pic of fuel pump assy 4 sc300-400
- MAF Clean didnt work
- Am i missing something here?? TRAC
- capabilites of the 2jz-ge
- what size serpentine belt to bypass a/c compressor?
- Looking for non Ross pistons
- rear end diff ratio for 5 spd
- 970rwhp on Stock GE short block
- engine leak
- Torque Converter
- Seafoam help... PCV? Where is that located at?
- Cooling Fan Problem
- help with looking for parts
- R154 soarer,mkIII differences
- SC300 stock exhaust w/ deleted resonators
- Downpipe / Exhaust question
- Gte + Bpu + Extreme Cold Weather
- Stock 1UZ what exhaust is best?
- 95 SC400 Alternator Remove/Install
- 1.5 jz
- so i finally got the flywheel i needed so badly
- valve stem seal part number
- bad BOV?
- fluidyne raditor
- Stage 3 Clutch
- how do i change my spark plugs?
- water soaked engine
- Woot ! She came in today !
- Hissing noise when A/C is on
- car dosent idle right 93 sc300
- switching to COLD air intake
- AFM cleaning: need help
- automatic or manual when buying ?
- Humming??
- I am having throttle position sensor and throttle motor problems
- Please help!! code 41 and 21+ egr?
- 1jz woes
- Boostlogic Turbo Kit Install Problems NA-T Guys HELP!
- 93 sc300 odd a/c issue, searched 4 3days now...
- Please help!!! car stalling everywhere
- 1- 1jz at Jhot i got the other =)
- test igniter
- V160 measurement.
- Belt ownage version 2.0
- need confirmation if possible
- in the hospitital
- 2 more quick questions
- radiator shroud?
- Will MKIV TT mounts work?
- 1j BOV location
- No more cats, will I have a problem with my third o2 sensor?
- Mechanical Engineering Paper...
- 1jz coil pack help
- "WOW" transmission mount
- TE44, PT52 and PT61 Comparisons.
- 92 SC300 lives again....mostly. Help with idle/timing.
- jeez (a real thread title would have been "my car dies")
- 2jz-gte
- Help!! My car is dying
- Looking to gain more HP....
- Turbonetics backplates
- order the clutch pedal assembly for my sc400. do i also need to buy the accelerator a
- hekp finding exhaust
- What is this worth....
- tt 5spd auto attatched to a 1uz
- I need pics of Extension Of Knock Sensors...
- Supra twin turbo aluminum radiator installed in a 1992 sc300 5 speed (with pictures)
- Magnaflows stock or with new pipes?
- broke it : (
- Wiring Service?
- Stock 1JZ, How to Maximize HP
- Need help!Stripped head bolt
- Suggestions on buying catalytic convertors?
- 92 SC400 Smoking engine
- ABS Wire...
- Considering 2JZ 6 speed swap. Any info on this?
- engine temp reads HOT! anyone familiar with the problem?
- SC400 to 1jz rack questions...
- Intercooler piping
- Cats on the outs?
- speed cut ?
- IM BACK! This time i got a 97 black on tan sc300....Grrr engine went south
- aristo GTE + AEM?
- 1jz in SC330: no tach no temp gauge. PLEASE HELP!!!
- Help !!!!!!!!!!! My Car Died
- Nedd trans advice
- Emanage and V8.
- New Haste radiator w/ pictures
- 1jz/2jz Oil Feed & Drain Question
- how to check transmission fluid?
- Throwing down the gauntlet against Toyota's ECU
- im back but who cares right?
- Lsd?
- What tranny in 98 SC400
- Latest project(v8 vvti swap)
- heater control valve ?
- Need help 92 sc400 tranny
- tranny question (noob)
- Interchangeable Toyota Parts
- 1JZ problem...
- Name this tranny: W58 or R154?
- sc400 harmonics/vibration at 2k
- Need help putting engine back together
- Pictures of Ignitor Locations
- 2jz-gte Turbo Manifold
- Couple of (Dirty Engine Parts) Questions
- Clutch
- Exhaust question?
- Preparing external engine for boost
- electronic question
- 92 SC400 performance TUNE UP LIST
- Exhaust help...........
- The Stock 2J in the Sc300
- Passing Emissions Questions
- Torsen LSD Question....
- Another SC400T in the works!
- the a/c compressor stops spinning...?
- Whats Better? Twin Turbo or Big Single Turbo?
- Replacing valve cover gasket OFF
- My Exhaust Story...
- O/D light is flashing
- Changed out your gear shifter?
- Catalytic Converter - SC300
- Lexus SC Swap Auto to Manual
- lsd i need your help
- sc300 vs is300
- Exhaust Gaskets For 1jz!?
- Need a Favor from the Sc3 guys
- Anyone have working A/C with JDM ECU?
- 2JZGTE Single, Stock MAF & ECU -- Car won't idle right
- question about the intake....??
- GS400 Transmission?
- piggy chipped
