- Camshafts
- Can Anyone Describe/Pic Where IAC is on 99 SC300?
- a/c unit
- Fuel Pump DIZASTER/DEVIL PROBLEM
- ATTN: Those planning to swap in 2j gte and plan keep twins
- Cylinder head question
- air conditioning blower low
- Resonators Anyone?
- Okay to change old ATF?
- Heavy Tranny Clunk When Shifting @ Standstill
- wierd powersteering issue.
- Can you use non-turbo parts on the sc300 engine
- Who Has A BL FMIC? Fitment Issues! PICS!!!
- deceleration noise
- vss wire location
- VVT-i SC400 with Tanabe exhaust
- Proper Intake?
- fuel pump setups....got pics?
- No Fourth!!!!!
- trans and diff fluids..
- proper level of power steering fluid
- cam gear + left index finger fail...
- accelerator pedal vibrate
- What exhaust is this?
- weird noise in powersteering... HELP!
- Solution to Short Mount SC300's!
- Question about using Auto Brake pedal on a Manual Car
- Help with strange oil/coolant mixture/leak.
- *****W58 shifter end bushing...
- Fuel Injectors?!
- MAF disconnected conclusion
- 99 sc300 headers
- A/C Diagnostics
- MAF simulator
- AC question
- Rear main seal replacement
- Busted Radiator - Need some advice/help
- Catch can install for everyone
- APEX-i RSM install
- sc400 spark plugs and throttle body
- 95 sc300 ecu diagram? tryin to install mapecu
- Can this be trusted???
- Dash Board Warning Light... Cannot understand what it means...
- Ordered shifter extension
- Calling all aftermarket TC gurus
- what leak is this? (pics)
- I didn't read rules
- Nagasaki motors
- PCV Valve question
- What is the pros/cons of a Solid Driveshaft Bushing?
- W58 Whirring Noise - All gears but 4th
- SC 400-Stem Seals
- Help Temp Gauge Going UP
- transmission slipping check
- sc300 engine cover
- engine/feedback
- found hose disconnected and capped PICS
- whats your torque
- SC400 Burnout
- Question SC300
- Funky Steering
- Where is my ECU?
- MK3 W58 swap into 1JZ auto, need some more info and help
- Speedo Needle Goes Crazy
- Single conversion what do you do with
- Help with my SC400 Please!
- Important Question :(
- Couple of clutch questions for the W58
- oil pressure gauge
- Speedometer problem...?
- W58 clutch question
- Overcharged a/c ?
- Wastegate vacuum question...T61 In Progress
- If you have a skip this may be the cause
- What is this goo/part?
- help/engine tapping
- car problem
- What do you think happened here???
- GAS Gauge Fked up HELP
- Oil pooling on top of spark plug wire caps.
- Aluminized vs Galvanized Exhuast Piping
- IACV Loaction questions
- Burning Oil when at stop light
- SC300 2jzGTE swap confusion
- What to do w/ the water pipe
- Differential Fluid Change Advice
- Overheating problem.....
- Does this sound like a bad torque conveter?
- My SC 400 overheats when stopped
- Turning Air Conditioner off causes idle to DROP to 250-300
- DIY manual for 2jzgte motor swap??
- Upper oil pan re-gasket
- JZZ30 SOARER front clip!!
- Punch list for my 1jzgte swap
- Loosing Water
- in need of some helpful info 1jzgte intake manifold gasket
- 1uz-fe/R154 combo
- Engine won't fire up after engine shampoo
- JDM 2JZ-GTE VVTI swap
- PLEASE HELP oil and temp lights
- power out of 1jzgte??
- Transmission question
- Doors keep locking
- FMIC kit options for a 1jz swap.
- My 93 LS400 wont start im forced to scratch my head
- 1jz Y-pipe for twins: OneJay's Review
- relocated the harness, now it wont start.
- BFI efficiancy question
- MAF Unplugged = Car runs better PART 3? HELP!
- 2jzgte from 97 supra to sc300 help
- a/c problem
- CX Racing Radiator?
- play in steering wheel
- Na-t or 2jz gte swap?
- SC400 timing problem?
- 1jz sc400 a/c
- Lower Oil Pan Reseal
- What ATF are you using in your A340E?
- SC400 Vs 3000GT
- dyno my sc300
- How can i make a VPC work on a aristo engine?
- Curious On How You All Removed Your Alternator
- neeed help. steering wheel goin crazy (moves on its own)
- Clutch Pedal Won't Spring Back Up
- Alternator not charging?
- Can't pass emissions need help asap
- Driving...WTF...Then there was smoke!
- Aftermarket fuel pressure regulator : 93Sc300 5spd
- Fuel Evap Hose
- W58 1jzgte?
- Name That Sound!
- Can the rotor, distributor cap be changed easily?
- 2jzgte aristo upgrade questions
- 1992 Lexus sc400 coolant temperature sensor
- HKS super-afr (install on SC400)
- 1999 SC cigarette lighter power intermittent
- is it possible?
- Heater VSV...what ecu pin is it??
- 1jzgte single turbo suggestions..please
- Problem with my sc help!!
- HKS Carbon TI on my 1997 SC300 5 Speed
- 1jzgte-vvti
- Dumb question but here it goes!
- aem series 2 ems pnp
- Help me find a turbo!
- 2jzge hockey puck mounts
- SC 400 Maintence Question?
- Lets talk intake manifolds!
- heater core hoses
- i promise i searched
- Exhaust Manifold betwen vvti and non vvti
- 92 SC400 Need help asap!!!!
- Vacuum lines diagram sc300
- Replacing OEM fuel pump with Soarer pump?
- DriftMotion power steering hose ?
- What's Under Your Hood?
- 92 SC400 Idiling problem
- Need an answer ASAP! Thanks
- GS300 HKS axle backs fit an SC?
- Cost concerns for 1JZ swap
- SC300 Clutch Problem r154 2jzgte help...
- DIY: Engine Coolant Temperature Sensor Replacement- 2jzge I6 SC300
- Trans Diagnostic Retrieval
- HELP Experts Supra TT suspenison
- Need help R154 transmission mount and crossmember
- r154 drain plug
- new battery still losing powers
- Coolant leak
- sc3 1jzgte engine cut
- check engin
- 97 and 95 Sc400 engine differences
- Driveline vibrations??
- What Radiator? (SC + 2jzGTE swap)
- My SC400 just started stalling intermittantly ... what could be causing it?
- Misfire again! (I know I hate misfire threads too!)
- Car runs better with MAF unplugged (part 2)
- manifold
- Need some suggestions - Turbo and Tuning
- Drive Shaft Phasing
- power steering h/p hose
- More 1UZ woes
- Broken Harmonic balancer?
- Something Keeps Spinning After Shutting off Engine
- Need Help With Haltech Install
- first ever CEL on my 97' 5spd...ideas??
- Oh, my 1JZ woes :(
- Wiring Problem: Chaser 1JZ into SC300
- How many miles is too many miles to turbo?
- Why a 1JZ-GTE?
- Pillar Gauge pod
- SC300 2JZGTE Auto Swap
- what sensor is this? i need some help
- TT Supra Exhaust on GTE swapped SC?
- Greddy bcc questions!
- Which swaybar to complete my suspension
- My R154 finally let go.
- oil leak from under tensioner
- Difficult starting issue!!!
- how to fit a mk4 auto tt rear
- Shern's W58 to R154 swap thread
- Pulleys???
- How do you guys get to your oil filter on your SC300?
- Oil and oil leaks.
- leaking VVT GEAR?
- <<help>> unknown sensor
- where iz my voltage regulator?
- Mk3 1jzgte into a Sc300 help....
- Straight pipe thread. input appreciated!
- greddy profec b II
- Engine Swap!
- car dies out
- Intake manifold lower GE to upper GTE rail adapter?
- MK4 clutch pedal
- Bogging off the line
- SRT Intake - Yay or Nay?
- HELP on replacing the headgasket
- Air conditioning question..wow
- Power steering lost, battery light on
- Oil leak - The remedy?
- Loose shifter assembly
- Clutch Fork Lubing?
- Finding TDC
- Requesting Reviews on Electric Fans: your experience, your thoughts...
- Transmission return line...
- W58 swap HELP!
- question on header install..
- noise around 40, help me find the problem!
- Another "holy crap the 1UZ sounds amazing" thread
- So... Explain the AC Speed Sensor PLEASE!
- Car won't start... Loud grinding noise
- AC problems
- AEM UEGO and stock o2 sensor question..
- Serious Loud chattering noise from underneath the car..???? HELP!!!!!!!!!!!
- 1 UZ-FE performance upgrade w Temp Sensor replacement?
- My 1JZ Overhaul/Swap into a '92 SC 300
- 1JZ engine problems.. need help!
- idler pulley braket is snapped
- Aristo Swap & Fuel Pump ECU Issues
- FLashing AC light cuts off after a few minutes 1994 300 SC
- Need help with rear diff LSD!!!
- Green wire with Blue stripe?
- na-t owners couple of question...
- Emange Ultimate no Fuel
- what for SC300?
- help me out a little guy with my o2 sensors
- Alternator issue
- 1jz FPR question
- My 1JZGTE thread, 93 SC300 with W58
- 1jz vacuum line picture ( I believe lol)
- AFM disconnected: side effects
