- Any pics of V-Mount Intercooler/Radiator SC's?
- EGR + Me = FAIL.............
- New ACT HDG6 racing clutch installed.
- Uh Oh (actually means) Dropped socket into engine.
- How do I change the gears on my transmission without the shifter?
- South Florida SC X-Mas Gift!!!!
- Ecu upgrade
- 1jzgte-vvti turbo
- Dang Coolant leak
- My SC400 overheated, help me diagnose
- Replacing distributor cap
- Noob here with probable noob question.
- Seatbelt light staying on
- Headers- what do you know!?!?!
- 94 1uzfe problems
- how do I determine valve size when upgrading to 272 cams?
- Question on the vacuum lines around the ps pump
- drive shaft for gte swap
- Sc400 Starter randomly engaging while running..........
- Bottom line: Soarer ECU part #'s (auto or manual)
- Problem with EGR on 95 SC300
- 94 sc400 1uzfe
- Toyota Soarer (SC chassis) Power to Fuel Pump
- questions on heat wrapping
- SC300 2JZ-GE Bottom End Question
- Exhaust help- Any Bright Ideas!?!?!??!
- If Motor Gets put sideways
- cam gears legal in California?
- s-afc or e-manage
- 2jzge head question. are head parts between gte and ge interchangable?
- 99+ SC300 auto to manual questions...
- BFI intake?
- Did my ECU die?
- Ok, wtf?
- 81k should i seafoam?
- Dual fuel pump wiring question
- Is the supra/sc300 radiator fan hydraulic or mechanical?
- Need help with gas tank ! !
- Starter? Orrrr?
- aristo to usdm turbo question
- 5 speed conversion on SC300
- Build threads?
- Please help Check engine light p0402
- engine swap.
- need help troubleshooting overheating problem!!
- Should I change my SC400 AT Tranny fluid?
- i want to build my motor...i have an extra 2jzge..should i build it?
- WTF!!!!!???? Can you do this????
- 1jz gaskets
- Anyone got a power steering line crush washer part #?
- Let's just clarify the w58 tranny and shifter issue right here in this thread.
- Why the hell does this happen when i turn the heat on?
- SC - 1JZ swap - ?JZX90 1JZ or Supra/Soarer 1jz?
- Vibration & Hesitation... driving me crazy!!
- Calling all auto to 5spd guys! Need some advice.
- Another starting problem thread
- need help starting car.
- Couple power steering pump questions
- 92 sc400 tranny slips help!
- How to install fuel pump
- Question on swapping to 4.27 gearing
- Help my car doesnt pass smog !?!?!??!
- SC400 tranny swap?
- Reading trouble codes in pre-OBD II (pre 1996) SCs
- Heater problem, please help
- Anyone got a repair manual?
- w58 tranny swap and speedo not working!
- Check Engine Light Issue
- 94 sc400 shakes when i drive
- Tune up causes A/C heat to not work...
- Help with Aristo base map for Aem
- SC400 - low speed stalling
- Info on SC400 vvti w58 swap!
- Good question on sc400 vvti a650e tranny
- SC 300 Heater Putting Our WARM Air
- intake smoke...um yeah lil help please!
- HELP! 1JZ overheating in boost
- Aftermarket Transmission Filter?
- SC400 Cold weather operation.
- 1UZ thermostat?
- aristo in sc300 problem
- 220,000+ maintenance on recently purchased car.
- PLEASE HELP!! Starting problem;SC400
- SC400 stalling issues
- Exhaust Ideas Gents
- need help..where do these all the vac lines go? na-t with ttmanifold project
- HELP: Puzzled by my car
- Hi, new here, first SC300, have a few quick ?s for everyone
- Distributor...
- Best aftermarket parts
- EGR71 code will not clear trac/check engine
- how do i know its my alternator?
- Another Bad Noise
- Help with motor swap.. non-turbo
- Mkiii r154 vs soarer r154 shifter feel
- is it normal?
- water leak
- Pics of my 1j that came in this morning
- Mechanic says I may need new transmission - you agree?
- Sc400 drag car
- Screeching noise after seafoaming my car
- diy torque converter request...
- Prestolite Plug Wires
- HELP WITH RPM !! 1995 sc400
- Engine Hesitation at 5200 rpm
- 1jz wiring blues
- Stripped bolt with pic, suggestions
- You've got to be kidding me!? An Electric turbo?
- Timing belt install, but it wont start!
- Automatic Stalling Out? Waitwut?!
- SC400 W58 Swap in progress
- HELP - '92 Lexus SC300 idle problems
- VVti question
- Any automatic drivers ever had this PROBLEM
- PLEASE 92 Sc300 automatic transmission not changing gears
- *94_Soarer's Auto to 5spd Swap*
- How do I remove the alternator on my 98 SC400 without removing power steering pulley?
- My SC just took a dump. Any suggestions?
- r154 bellhousing??
- jdm tt question
- car jerks while accelerating or decelerating
- Help!, 1JZ-GTE vvti into an SC400
- HELP. Changed trans mount now Power Steering Overflows.
- Clublexus, any idea what's wrong with my car?
- Maintenance Schedule for 98 SC300?
- Spark plugs, wires
- shift solenoids
- List of bolt in rearends?
- Is it even possible to remove the 400's PS pump?
- All 99 SC300 owners Air intake Question
- Car has lost power, Cats glowing... All bad!
- Metal shaving in the transmission fluid is good?
- Has anyone ever installed headers on a vvti sc400?
- 5spd conversion
- cigarette lighter not working?
- Motor mount question for you 2jzgte'ers
- A/T shifter Knob sakes while riding
- MagnaFlow 99175HM?
- 300-350 hp with 1uz
- Automatic trans gear indicator not working properly
- Making Power in California
- Automatic Transmission -cooling feed/return lines
- Sc300 automatic problem
- Anyone know where where these wires on IK2 go?
- About to buy a 1jzgte
- coolant loss searched
- 5spd Problem =(
- ecu
- Hesitation / sputtering around 1500rpm
- 1jzgte Engine Harness
- Future SC300 owner with questions, performance and some others
- IMF SC400 Headers GB $399!
- SC400 Trans whining and clunks
- Lets Discuss - 3.23 Gears in MY SC400
- Need Help With My SC300!!!
- question.
- Radiator replacement help
- should i run 2.5 or 3 inch piping? help me order real fast.
- Need quick verification
- High Mileage concerns
- R154 shifter Question(please help)
- SC400 rough idle, off idle fine, then doesnt start one morning
- Gas tank drain plug location ?
- 1jz pistons?
- Resonators
- s4s hybrid kit owners post.
- working on tt manifold on ge lower runners
- TH400 In an SC300.. Question on Install.
- gs300 axles on sc300?
- Newbie to JDM need help
- Intake adapter and k&N filter #0810
- VSS no.1 code 42
- 1JZ running good, sorta...
- Noob ? GE GTE Questions
- 1995 SC400 Overheating problem. Need solution HELP!
- Upgrading alternator and battery
- PLEASE HELP QUICK!!! Aluminum Radiator for sc300 A/T?
- Loud exhaust
- SAFC froze now running rich...??
- So is 1 turbo better than 2?
- Aristo swap to Usdm ecm/specs
- Cant rev after headgasket install
- greddy speed cut
- what do ya think so far
- GOING SINGLE! first pics in side
- need help asap. weird part melting
- Timing Belt "O" BOI.. VVTi 1UZ
- Please help.. Pinouts needed 1992 SC300-2JZGTE!!
- What clutch should I get?
- Driver door won't open!
- Help with wiring..1992 SC300 Auto w/2JZGTE
- Help from you 1JZ gurus please...
- Water Pump replacement?
- 99 SC300 Transmission vs 99 GS300 trans?
- Question/Verification on Fuel ECU bypass wiring
- bulding a turbo kit need intercooler piping for the sc300
- sc400 custom exhaust piping question
- 5 spd Swap with an OBDII Car
- supra 550's...?
- yes or no question
- 2jzgte swap...
- replacing rod bearings, motor in car?
- What is the number of the tail light bulb?
- Sc400 gurgling sound/ hot exaust
- New Ebay Exhaust Out
- clutch just dropped while driving =O
- HELP need asap...(really means Starter Issue)
- in search of soarer 1jz engine harness pin out
- Need help with twinturbo setup !! Please !!!! Asap !!!
- Egr mod do i put the resistor here? picture
- CAR Hesittating & Loss of power!
- spoiler brake light
- More Problems!
- Power Steering Tube leak
- Transmission Upgrade (Auto or manual)
- Hold the exhaust please....
- boost my LS or upgrade to XJR
- exhaust swap question
- Looking to buy a catback exhaust
- Looking to buy an intake
- Odd Battery Problem
- Any interest in SC300 headers?
- will a gs300 ecu work on a 92 sc300?
- What is this called???
- Checking interest for the IMF headers..
- which would be better?
- Which NGK Plugs to Use?
- GE block and TT head Who's got it?
- A340E and an A341E transmission
- I have got the throttle body and intake manifold off
- Drive Shaft Bolts
- Lexus warning light
- are these motors and trans the same ????
- Fellas Got a Check enging light on 98 sc400 vvti
- Radiator Leaking!!! LS400 part in SC??
- Rear O2 Sensor removal and tricking?
- Wtb: 1jz turbo or 2jz turbo motor !! Socal !!
- CEL turns on and off
- Need help gathering minor tune up parts SC400 98 vvti
- sc400 tranny to a 1jz-gte tranny???
- would this work?
- Gotta figure out why the oil light was tripped when.......
- Lost on the turbo size to get. Please help.
- underdrive pulley?
- Is it just me or does the a650e tranny drive funny?
- 95 SC400 won't fire, need help with external fuse box wiring
- Clutch replacement
- need help with auto tranny on 93 sc400
- Amsoil Help
