- Any Short Shifter for Soarer R154?!?!
- What's your opinion on this aluminum coolant tank?
- 95 SC400 Timing Belt Change No Power
- new alum. radiator and slim fans for sc400? anyone done it?
- SC400 exhaust idea.
- R154 & 1jz DriveShaft
- 92 SC400 stalling issue
- 1jz vvti into 92 sc300 (i searched)
- Speedo died
- new exhuast whudgathink?
- What exhaust should I buy next? (Nur Specs got stolen)
- rebuilt stock motor now turbo
- aristo swap in 98 sc400 (shifter question)
- Well freaking fruitty doo...It's doing it again...
- Need help installing a HKS FCD
- what are you running for intercoole (sc3 1jz)
- Coolant tank leaking, common problem? (pic attached)
- Distributor Cap Users now and future?
- Changed fuel filter today, DANGER
- rounded bolt help!!
- Need Help- Idle Issues on 1992 Sc300
- Engine start - two turns before start
- will this r154 work in my sc3
- 2jz 6spd or 1jz r154
- Fuel Pump Questions
- stroker kits
- Faulty replacement rack?
- Overheated; turns over, but won't start
- New to 2jz
- I hate automotive A/C systems.
- need to know what part this is
- QUICK, Please post a closeup pic of your obd1 sc300 IACV wiring harness
- supra 1jz
- really works :D
- how do you set up catch can arrangement on a 1uz?
- Replace your fuel filter without loosing fuel*
- 1UZ crank bolt
- Do I need fuel pump/fuel regulator?
- Hard starting when engine is cold; not the coils
- LSD rear end
- Randomally wont start
- any ideas??
- Aristo harness gurus: what is this plug I have missing?
- What exhaust to use in a 92 sc400 1uzfe
- A.C. delete ?
- how should i build my engine jza70
- code 13, NEED HELP GUYS
- 1993 sc300 alternator wiring
- chirping sound coming from car
- sc400 getting no spark from either side help
- SC400 Engine Splash Guard
- question on exhaust
- 92 sc300/Aristo swap...
- Looking for a greddy emanage blue map...
- 1jz swap temp fix doesn't seem to work for me
- supra parts on an sc300
- Code 13
- Innovate Wideband Sensor
- SC400 with SC300 Auto Diff??
- Bringing the 1UZFE to life!
- My new custom exhaust for my 98 SC430
- Need help Wiring a Apexi SAFC
- Supra TT Auto LSD install
- Car running Rich all of a sudden
- aristo diff lsd?
- Warm start up problem - SC400
- 1JZ Knock Sensor Extension
- How Do I make my Check engine light work, 1jz swapped
- Ar5
- [VIDEO] 879 RWHP @ 28psi burning corn!
- NEED HELP!! sc runs great then rough idle, dies
- Difference between Soarer/Chaser/Supra 1JZGTE wire harness??
- need help buying exhaust for my sc400 yr 1993
- Runnign rough after radiator leak/swap...
- 93 sc300 emergency trunk release? Please help
- How long should a shop with lifts and air tools take to install v8 headers?
- aristo wiring experts needed
- any one using borgwarner s366
- PS Resevoir Replacement Recommendation
- headlight bulbs
- 1997 sc400 auto tranny line pressure adjustment
- A/C question
- 96 SC 400 nothing electrical works
- Advice from guys with Auto ECU 1JZ on 5 speed car
- Is there anyone looking for a 2UZFE swap w/ a built motor?
- Super 8 1uzfe car
- Question about Apexi SAFC V1
- SC300 cluster pinout
- advice for auto. cars
- 2jzgte safc2 idle setting?
- 1992 SC 400 question
- help
- Curious about a labor quote to replace A/C Compressor
- Rough idle, poor driveability! Please help.
- My SexC300 in the fast pace of light zone
- ITB's on your 1UZ-FE?
- breaking up aroud 3k
- humming noice while accelerating.
- water pump / timing belt
- 2JZGE LS400 Throttle body Mod
- Which cat for an SC400 with custom exhaust being built
- AC pipe line leaking solved
- leather seat
- v8 guys, what have you paid to have headers installed?
- 1JZ fuel pressure test
- 370cc, 440cc injector clips
- Rpm's running real low an under 1k when stopping
- Cut out
- Finally got the new motor in - V8
- Looking to swap r154 to 98 sc400 1uz-fe vvti
- Keys Locked in Car, Pulled EFI Fuse, Now Running Rough
- 2jzgte auto swap hick up
- 1992 Lexus SC400 will not start (fuel issue)
- R154 leaking.......again! Need advice please
- need help 7m resitor for 550cc 1jz
- fireball exhaust compatibility
- lets talk all things cooling
- In middle of R154 swap, starter won't line up HELP (PICS)
- Auto SC3 Chirped Yes
- zetrinix wide band
- Sc400 tranny...solenoid connector?
- NA-T Ignition Break-up at 4K
- help turbo timer & oil cooler
- : ( cant find anymore top speed pro 1 exhausts...similar replacement?
- T56 Swap kits....
- Parts List for SC300 5 speed pedal assembly
- 2jzgte swap with tt automatic- Which rear diff are you using?
- Door mirror(drivers side) ?
- It's been a month and I still can't figure it out.
- Gapping question
- Need help... my SC making noise when start up
- Anyone used A1 Turbos blower manifold?
- Changed fuel filter-what a mess.
- post starter replacement problem on 1uz
- Q : sc400 auto transmission fluid
- Aeromotive, Bosch, Denso, Walbro fuel pumps
- Sc400 low idle problem
- Sc300 Check Airbag Light?
- sc300 engine electronic help
- can i use my gte ps pump?
- Finally get to post my Dyno...
- Turbo or na
- 1.5JZ, Running LEAN-stuttering
- Crank Pulley Tool
- HELP! Identify This Engine Wiring Harness Connector
- r-12 freon for my sc400?
- Throttle body coolant hose
- questions about limp mode on 1JZGTE
- fuel injector preference question
- Tach and Speedo problem. Help!!!
- rear subframe qeustion
- sc400 auto full 2j swap??
- Rear Diff Question.
- Great vid abt AEM AQ-1...with a hot chick in a bikini (borderline NWS)
- This is probably a stupid question, but will ask anyway
- Should i get a lsd?
- 1JZ cruise control works!!! But...
- SC300/400 Fender plastic piece.
- Ls sc300?
- NEW 1jzgte
- Anyone got Soarer or Supra 1JZ harness pictures?
- Wont boost over 5LBs??
- Cat delete question
- sc300jz's 5spd swap
- What have you guys personally spent on a 1JZ swap?
- Weird Exhaust Noise... "crinkling"?
- is a safc a good idea??
- Cheap rear end options?
- W58 to 1UZ peeps chime in
- Seat removal DIY
- Bad ecu?
- cold air intake and axle back exhaust for stock 98 sc300 nonturbo
- R154 rubber seal
- 95 sc400 loss of power helppp!
- AEM EMS V2 issues
- D.I.Y. - Lexus center wheel cap for G35 19' Rays
- sweet na-turbo dreams
- R154 leaking fluid..
- Check engine light on 99 SC300
- How to remove fuel tank - completely?
- Octane vs Intercooler
- 1jzgte bucks...
- Leaking Injector Issue...
- Blow-By Vacuum Pump anyone?
- 1992 Sc300 IACV Connector.
- SC300 W58 manual 4.08 to 4.27 gearset swap
- Need any helpful advice before I attempt to replace an injector...
- 2JZGE Throttle Position Sensor on 1JZGTE?
- Seafoam Vs the stuff Jiffy Lube/Valvoline pushes..
- Question regarding 2jzge oil pan sensor
- Loss of power after installing new mufflers
- Ffim iacv????
- transmission went bad :(
- Reviews, anyone used the coils on ebay for a GTE swap?
- boost problems
- Idle issue.
- battery warning light
- What else is left to check? SC still "stuttering"...
- car wont stay on??
- Single vs double exhaust? Is there a difference?
- 1992 SC300 no overdrive and no codes
- No boost but can hear the turbos spinning??
- Rear wheel bearing
- What Dual Exhaust Sound Nice Straight Piped?
- Please help! car stalling when in park or neutral
- 1992 sc 400 engine
- Pinout Request IACV Harness 95 300
- High rpm Hesitation 1jzgte
- High Idle
- coil pack sc400?
- 5sp swap
- Ls400 bbk.
- 1JZ Coolant system question
- picts never hurt anyone!
- Testing the MAF, checking my reasoning...
- Muffler question
- Loud valve/tappet noise after head rebuild
- What are things to make my engine rev faster
- 1jzgte motor died while driving, cranks but wont start now
- Diagnostics - Engine dies at idle
- pic of your crank pulley distance. PLEASE!
- battery draining problem
- N/A power gains from tuning
- PCV valve
- sc300 na-t *turbo blew apart* !!!!
- 2jzgte swapped sc300 AC problem
- Tilton clutch inspection...
- Spark Plugs drenched in oil, 2jzge vvti
- need help..
- Huh... My catch can system actually works
- code 31 help
- HELP! Daily Driver lSC300 has gone down!
- O rings in trans
- 2JZ Freeze Plug sealant?
- Question on replacing the MAF..
- Need a description of a "good" IACV
- SC300 ECU Main Computer Fried all units affected CHECK YOUR ECU
- sc400 m90 set up help
- help plz
- Is it time for a new ECU?
- Turns over strongly but will not start
- New tps gone bad?
- Faulty distributor cap
- safc question
- R154 normal or is something wrong? It wont shift
- Is this Normal
- Embarrassing!! Need fix fast
- Can you test our coils with a meter?
- 1jz swap question
- Intake questions.
