sweet na-turbo dreams
got some money in the bank and wondering what kind of set up i should go for i have a 95 sc300 2jz ge 5spd read up a lil bit on it and dont want to change the internals said as long as i keep it under 350 whp i should be fine. so guys you have any suggestions?
ge motors are just as stout as gte motors period.. dont let anyone fool you..
the key to making it happen is STANDALONE. ge ecu has no ref for positive pressure so it soley relies on knock sensors , very very risky.
how well you maintain motor also plays a key role .. i change my oil every 1k miles and i use mobil 1 15w50.. our motors are old and somewhat delicate ( bearings) as they age. keep fresh oil in there and your golden ..
after 3.5 yrs of boosting hard , i stil have perfect compression on all cylinders
also folks, .68 hotside is not good for the 2jz motor over the long haul..
it promotes way to much back pressure which in turn puts more stress within combustion chamber and valves ( headgasket issues)..you are also choking off your mid to top end because of this backpressure..
min i would do is a .81 .. i lost 150 rpms of spool going from .68 to .81 if that but once in boost , hold on
