- GS Out, RX In
- 2001LexusRX300 check engine light on
- Idle air control valve
- Overfilled transmission
- Yellow "light out" indicator bulb is on, but why?
- New RX300 Owner Here
- trani clunking when shifting from D to R
- Dice IPOD Integration kit 2000 Rx 300
- Secret Weapon Intake
- 99 RX300 Rear Wheel Area Noise/Knocking
- Change Thermostat?
- Should I buy an 02/03 RX300?
- Lights & bulb help on RX300
- pass. seat front bolts
- p 1135 and p1130
- amp
- IPOD Integration kit 2000 Rx 300
- Anyone dealt with Luxorymods.com?
- Aftermarket Nav
- XenonDepot HID Conversion Kit : 6000k XenonDepot HID Conversion Kit
- wheel stud
- Got my teins
- 02 sensors
- Synthetic transmission fluid?
- aftermarket grill
- Stock Visor
- New to the Lexus family...
- Rear Main Seal
- Interior Rear Hatch Release?
- For Sale: Black Colgan Bra
- floormats?
- Need some RX advice (noobie)
- Headlight removal
- Power seat override??
- Oil Leak: Rear Main
- navigation swap??
- Tire and wheel size??
- Rotors: to replace or not to replace
- Fusebox Location
- Code P0446 ???
- Best Looking Hitch
- rx300 bodykit?
- Air/Fuel Sensor Replacement Tips
- Creaking Dash?
- rx300 a/c blower inop.
- weatherstripping
- Help - 2000 RX300 PCV Part No.
- ac not working???
- Windshield Cracked
- Outputs from trailer wiring connector?
- Starting problem
- Car shaking bad. Even after alignment.
- Oil Change
- Bulb Fitment Numbers
- Remote oil filter
- Pungent Odor from AC Use?
- Stripped Bung
- Catalytic Converters Replacement
- Feedback on Power Steering Fluid Flush
- Transmission Fluid level adjustment
- Lexus RX300 conversion from Miles to Kilometers
- cluster question?
- Navigation update for 2001 RX300?
- Front Windows Operation
- 2000 RX300 Antenna Motor
- Looking at RX 300's and NEED HELP
- Replacement bulb help
- Parts for 100K maintanance
- RX300 Pulley
- Service: Independant vs. Toyota vs. Lexus
- High-output alternator
- CEL confusion - more codes (0125, 1135, 1133)
- vsc/trac off warning lights
- I want to upgrade my display
- So Long RX300 Members
- 1999 rx300 stereo install question
- RX300 trans won't shift into OD
- Fog light replacement! HELP!!!
- XenonDepot 6000k HID light conversion complete...
- Very helpful and cheap
- RX 300 tool bag?
- Not the smoothest ride
- Driver's Door Panel Removal
- any rx300 members have indash dvd player?
- Yet another O2 Sensor question
- Replacing spark plugs
- DIY - RX300 red/clear taillights
- Exterior accessory help...grill
- smoke from exhaust
- What is Wrong with my '00 RX??? Battery problem or Tranny problem?
- help.. how do i find or get to the e-brake ground wire?
- Got the Angel Eyes kit now I need installation help
- Oxygen Sensor Alternatives?
- Coolant flush
- O2 Sensor Help!
- Getting at the oil filter from the top (K&N)
- Driver's Door Lock
- Antenna motor removal - need help
- nakamichi amp
- Brand new Tranny
- Shimmy and how to addressit
- driver's door lock acting up
- idle air control valve motor
- WiperFluid Compartment
- Exhaust
- Engine Coolant top-up help
- RX300 Rear Center Brake Light
- Need trunk lift.. help me~
- transmission is gone :sad:
- 2001 RX300 starter
- Trailer Hitch Cover Swiped
- maf sensor part #
- Battery size for keyless entry
- Oil leak at Engine/Trans seam
- Front License plate screws
- rx300 tail light replacement
- P0125, P1135, P0171 Codes
- Opinions on these LED tail lamp assmeblies for RX300? (photo enclosed)
- Speed Bleeder Screw
- water leak
- Timing Belt
- clicking upon turning on the key
- Transmission problem
- Blitz Realize TT Exhaust
- Replacing fog lights
- Wheel Vibration/Alignment
- Gas Mileage and Bigger Rims
- Suddenly Lower MPG
- HID lights
- Is not replacing the O2 sensor OK?
- Question About Brake Grease
- Hissing noise in cabin when A/C turned on
- O2 sensor replacement (Bank1 sensor 1)
- Washer Pump 2000 RX300
- Need help buying New Tires !!
- Exhaust Tip
- RX300 Navigation computer location?
- 99 RX300- Need help with issues with my headlights and exhaust
- Electric Antenna - options?
- I Want Angel Eyes For My Truccckkkk But I Can't Find Any
- Neons
- P1130 - which sensor?!?
- Quick question on 2002 RX 300
- RX300 Spring Install
- question about RX300 front rotor
- Sway Bar
- Best year for RX 300?
- Supercharger
- Replacing brake rotors and pads on RX300 - a couple of questions
- seat memory malfunction
- side marker light
- Hard starting; no idle; explanation?
- Is there supposed to be a piece of black rubber cover on the gas pedal?
- Replacement Wiper Blades
- 70,000 powertrain warranty set to expire
- 30,000 60,000 90,000 Scheduled Maintenance
- Does EVERY RX300 have that mirror tint?
- wheel fitment question
- Lexmex, RAM intake?
- Performance Help
- Best place for diagrams?
- Many questions for my RX
- 99 Venetian Red
- Photo DIY 3: RX300 Power Steering Fluid Flush
- rx300 skid plate
- Can I move rear spoiler?
- Brake Light Problem
- Were there porcupines in Lexmex's tranny?
- distributor cap
- Looking for good mechanic in Lancaster PA area
- Rx300 2002 Gps
- Looking for tips O2 sensor bank 1 sensor 1
- 02 RX300 - want to upgrade sound - help!
- Timing Belt Replacement
- Hit 100,000 miles
- replacing Brakes (probably rotors)
- tail light converter
- Nav DVD Upgrade for Newb with an 03 RX300
- Lightbulb out Indicator
- a mod thats just for fun.
- WARNING!!! Counterfeit Tein S. Tech Springs WARNING!!!
- Radio Removal? 2001 rx300
- Quick question:oil capacity-searched
- Dash Lights
- It Won't Start
- I hate our windows???
- Yakima Q Towers on RX
- RX300 Weird Noise...
- lock/unlock light doesnt flash....help
- Warranty on 2003 RX300
- Question on Packages for 2002 RX 300
- Anyone willing to do a DIY for foglight replacement on 2002 RX 300?
- AC problem
- questionable Handling
- Used Cars: '99 RX300 vs. '02 Honda CR-V
- Installing nav in a non-nav 2001 Rx300
- successful install of AVIC-D1
- Add me to the check engine light club, help...
- wide body kit
- O2 sensors replaced - and recent dealer costs
- This can't be good. ...codes help
- VSC & Check Engine Lights 2001 RX300
- Drivers Side Floor Mat Grommet Broken
- whos lex is this??? too funny.
- Looking to buy this RX300....good deal?
- Passenger side door mirror...How do I install?
- RX 300 computer codes
- Weird AC issue, anyone heard of this?
- RX300 Rear Headrest Question
- Cannot turn key to start
- RX300 Chrome Trimming
- LED Tail Lights
- Did lexus make a 2000 RX with 2wd ?
- Check engine light on
- VIN number diff. - JTJ vs. JT6
- navigation problem
- Tell me what you think
- Rear drivers side hydrolic bolt snapped
- Buying a '99 RX - some questions...
- Transmission Cooler and Partial Torque Convertor ATF Change
- Photo DIY: RX300 AWD Transmission Fluid, Pan, Filter Change
- Brand new uninstalled URD pulley for sale
- Dunlop Grandtrek AT2 - any good?
- Arg! I need help/ transmission slip
- Air Flow Sensor
- headlights?!?
- lost master key/removing computer...
- RMM Exhaust
- Need Glove Box Door
- Lost AC, clear oily fluid
- Nakamichi sound cut out
- Take a look
- Should I buy it?
- Oil filter
- A day at the races
- Diagnosing Costs?
- center console removal
- RX300 Anti-Lock Brake Issue
- question about tail fin
- interior bulbs
- Thinking of buying high mileage RX300 4x4 for second vehicle..Opinions?
- Am I killing my differentials/transfer case?
- Nice video of RX transformation
- RX300 Passenger Mirror
- Anyone were complaining RX300 owners?
- DIY Ideas?
- DIY Transmission Service
- Friend's RX Keyed
- Oil Change/Coolant drain
- Change cig lighter socket to full-time power?
