i have a problem i was looking at the book couldnt find anything ... everytime i press the alarm to lock/unlock my lights doesnt flash anymore.. i went back to the book looking at the fuse lay out .. couldnt find anything .. does anyone how what the problem is?
An RX300 or a Japanese Harrier?
Does the alarm beep as it should with normal volume?
Do all the doors activate, lock and unlock, including the rear hatch?
Does the alarm indicator flash as normal?
Does the panic button function correctly, activating the alarm?
Are the lights not flashing, once for lock and twice for unlock, the only indiction of a falure?
I am not sure if it is a C-Best setting or not, but after the first few times I started pulling the negative battery cable off (for an issue apart from CELs), sometimes my rear lights would not flash and then a few weeks later, it would be back to normal.
its a rx300 .. everything works beside the flashing lights... it beeps, lock/unlock it does everything but for the panic part i dont know i havent press the key for longest time...
Mine's currently in use, but if I remember correctly, the lamps also flash with the panic button.
Press the flashers button a moment, just to isolate out the flasher relay and it's controls. Do they appear to flash at the correct speed and do all four corners flash?
