Fusebox Location
Old Aug 23, 2006 | 06:52 PM
02rx300's Avatar
02rx300
Default Fusebox Location
Anyone know if there is more than one fusebox in an 02 rx300. If so where is it located because i can only find the one under the hood. thanks so much and sorry if this is already posted i couldnt find nething
Old Aug 23, 2006 | 07:40 PM
Josh Combs's Avatar
Josh Combs
well there is one under the hood and also one underneath teh dash on the drivers side. You will have to take a peek up there and you will see it.
Did your cig lighter stop working or what are you looking for exactly?
Old Aug 23, 2006 | 08:21 PM
02rx300's Avatar
02rx300
im looking because i just bought it and the radio and power seats do not work...hoping its a fuse..thanks for ur help
Old Aug 23, 2006 | 08:25 PM
Tammy's Avatar
Tammy
Check fuses in your owners manual for additional instructions on how to remove the swing out change holder. The fuse box is behind this swing out box.
As your aware, the fuse removal tool is located under the lid of the under hood fuse box.
Old Aug 23, 2006 | 09:15 PM
Josh Combs's Avatar
Josh Combs
you are correct tammy I was thinking for the RX330 not teh 300 good catch
Old Aug 24, 2006 | 01:27 AM
02rx300's Avatar
02rx300
Thanks guys...that was the proplem, the last owner had an amp remote line plugged in with the radio accessory fuse and it wasn't plugged in all the way THANK GOD!! ....thanks for the help again
Old Aug 24, 2006 | 11:26 AM
toy4two's Avatar
toy4two
I found them by accident, pop off the change holder. They are behind it.
Old Aug 24, 2006 | 02:57 PM
miniround's Avatar
miniround
yea, i found it by accident too...then found those fuses to be of good use. i now have all the led accent lights in my truck hooked through my tail light fuse...so when the auto headlights turn on, the led's go on.
neat little accent to my car
pentiumvi
RX - 4th Gen (2016-2022)
41
Nov 12, 2024 09:47 PM
sexxylex11
Lighting
12
Jul 23, 2017 12:27 PM
Joegbr
Jun 14, 2017 08:54 PM
Dx3
Apr 9, 2010 01:29 PM
jutt
Jun 15, 2006 06:43 PM
