- Electrical Mayhem inside our 99 RX
- RX 300 Shocks/Handling improvements
- Sound Rattles...
- Extended bolt?
- Transmission upgrade...
- Trans Oil, can't get a good read
- 2001 Lexus Rx300 Silversport
- Stripped the wheel lock, now what?
- I adapted a socket to fit front diff drain plug.
- Vibration with gear change
- Please Help: 2000 RX Not Starting
- Belt chirp,chirp,chirp
- light replacement
- Clock loses time
- looking for rx300 wrecking yards
- OEM Nav Installation w/ Pics
- Lock/unlock With Remote
- Lugnuts?
- Unusual Vibration
- Best price Parts ??
- Gear shift console light out
- Irontoad?
- VSC light + engine light comes on...oxygen sensor 1, bank 1
- 10mm spacer enough?
- What is this?
- Seat heater replacement
- Musical Chimes
- grille
- A few small things I did on the weekend
- exhaust smell in 1999 RX300
- What the heck is this??
- ebay rx300
- 99 Rx 300
- Squeaks & rattles - please help
- Wheel?
- Reverse Gear Not Engaging
- 40 offset too much for rx300
- Which of these fluid changes have you done DIY?
- Tire recommendations for RX 300
- Navigation DVD Drive failure?
- Should I go for it?
- no heat in cabin after changing spark plugs
- A/C Servo Troubles - (merged threads)
- RX300 on RX330 5 Spoke Rims
- Hurts me to see this...
- Tail Light out reminder
- P0171 Code
- RX Parts for cheap?
- Remote Start?'s
- 2001 rx300 225/60/r16 tires
- 2002 Rx300 A/c
- Perplexing P0768 Solenoid Code (2000 rx)
- RX300 better or RX330 better?
- Engine shutting off?
- 2002 Rx Nav Update
- Replacing window motor
- Super Long Life Coolant (pink)
- Aftermarket Fog Lamp Bulbs?
- Saturday modifications and maintenance
- performance chips
- Lot of suspension noise
- sticking gas pedal
- rear wiper washer
- RX300 not quite Sporty
- a/c stuck on one setting
- Might buy one today?
- low gas light
- Help: Engine stalled when car rolled forward while in Reverse
- 2000 RX Leather Steering Wheel Wood Cover
- Replace starter
- Transmission Service
- good tow vehicle sometimes?
- longevity/reliability question
- Wheels
- New Member Introduction : 1999 RX300 Owner
- Popping sounds...but it ain't suspension
- Lower rear supports for shocks FYI
- Let's see pics of your RX with aftermarket rims (18's preferably)
- Can't get front diff plugs out!
- Rear Sway Bar Bushing Part Numbers
- had to buy 4 new tires
- Wheel Studs
- Squealing A/C
- Wheel?
- CODE bank one too lean
- Struts
- finally full of air
- trans. cooler
- Fabulous Hood Wing???
- Accessing 12V at the windshield?
- RX300 Rear Suspension Failure???
- sluggish accelaration
- Brake Squeak
- Break Light Bulb Question *Help!*
- Touch-up paint recommendation
- Will 04/05 RX330 rims fit on a 00 RX300 ?
- Problem - Help: Spontaneous not wanting to idle problem
- Still No Aux In
- where can I get the rear spoiler(wing)?
- HID standard on 03 models?
- thinking about sellin my car.....
- p0100 problem! jerking and engine cut offs
- Retrofit Projector Headlamp
- how to clean under 2nd row seat
- front center jack point?
- PO768 Shift Solenoid D Circuit Problem
- Transfer case and rear diff lube
- Vsc
- NewB
- fog lights
- Blown light indicator with LED taillights
- squeeky steering wheel
- rx300 valve adjustment at 60k
- drag on deceleration
- Broke wheel key for wheel lock Help
- Thinking about buying an RX300...Advice?
- Clunking by rear wheel and squeeking
- How do you call the seat belt holder?
- need help with bbs lm gp?
- rx300 18" FI btl
- Upgrades....
- New Member-Q's re 2001 Rx300
- Castrol Syntec 0w-30 Used Oil Analysis for RX300
- Surging Idle
- Front strut upper mounting point fix
- Camber adujustment?
- Choppy Windows
- Help with rubbing noise
- RX isn't fast enough
- 00 RX300 - $10,500 - 112k miles good deal?
- Windows opening on their own
- Retrofitting Heated Seats
- oem rx300 spare wheel
- Light in dashboard
- Radio upgrade
- Timing Belt & General Questions
- My Rx300
- Keyless entry no longer turning off lights
- VSC Light is on
- Does 99 RX300 have hydraulic lifters?
- Car Don't Start After 12hrs Parked
- Help Lights..
- Any DIY for timming belt?
- Thomas Knight Electric Turbo?????!!!!!!
- 2002 Headlight assembly
- chrome rx300 emblem
- LED Turn Signal replacement
- What's a good brand for angel eyes?
- Spark Plug Break In???
- Rockford Punch 12" P112S4 In 1999 RX300
- Starting problems
- Brake Fluid
- Rear Wiper Arm Replacement
- EOS6 roll call
- A/c Clutch...
- New to the Forum, Looking for Info.
- More Problems...
- ? about Changing Transmission Fluid when it's hot - how much to put back in?
- heat shield
- Resurfacing rotors
- Clock resets every time I start
- my 99 twp rx300
- Cel
- Idling down & black smoke
- trailer harness
- Leaking drain plug
- stuck open thermostat?
- tinted windows!
- Car starts then immediately dies - very intermittent
- Clicking noise - behind glove box
- My RX300 wont start, Fuel problem Electrical problem?
- altezza
- eyelids block projectors?
- code po125- p1150
- wings
- v8's
- Anyone ever used or heard of Run-Rite Fuel System Cleaner?
- newbie advice
- Bay Area, CA local meet anyone?
- Areas to inspect??
- Bad Taillight on Dashboard
- RX300 Pilot HID Kit Question
- Won't Idle When Cold
- slow as a zombie
- WInd Noise and roof rack placement
- i want this :-( -/ exhaust (Merged Threads)
- Suspension mods (merged threads)
- need driver seat bottom cover (tan leather)
- Switching to CLOTH interior for 1999 RX 300
- Quick question, Oil fiter
- part# for top engine mount 99 RX300 AWD
- IDLE AIR CONTROL VALVE & only face air from AC
- Dash lighting up like X-Mas tree!
- K&n
- Oil usage
- replacing belt for A/C?
- hi SGK3554*
- Getting 99 Rx300 AWD, 114k?
- what's the right oil weight for 60,000 miles
- A/C is colder on the drivers side than the passanger side?
- Engine Vibration...
- rear lower control arm bushing part#?
- A few newbie questions about the RX
- Tell me about the RX......
- Problem with automatic transmission fluid level
- Black window frames > care of
- Rear Bumper Mat
- Lexus RX300 LED Tails *installed*
- Expected trouble free service in miles for RX
- Noise..
- New Owner
- Please Help.. thanks
- Brake Job ?'s
- Typical Rotor Life
- Anyone know part # for OEM brake pads?
- Question about changing all the transmission and differential fluids
- detecting bad traction?
- Engine noise has me baffled...
- No coasting when off gas
- out side temp
- newbie to this forum - trouble starting and update (merged threads)
- Warranty ?'s
- RX won't start...
- Disable Daytime running Lights?
- New audio system!!
- Just Won't Idle
- RX300 2nd most reliable SUV STILL!
- Old Harrier commercial
- AWD specs and differences between US and EU models
- Transmission
- Replacement Tires for '01 RX300
- Balsarini bodykit for the RX300! [pics]
- Rear spoiler
- New 02 RX300 owner
- Brake question
- new pictures ....
- dash kits and interior problems
- Idling Engine with A/C On In Hot Weather
- Door Lock/Unlock programming
- questions
- bluetooth anyone?
- Mini bullhorns on the black bull (lower air intake modification)
- Regarding keys...
- New Owner Of Lexus Rx 300 (2002)
- Removing roof rack
- sneak peek! new setup!
- RX300 brake clicking noise problem
- window tinting
- Power door lock switch do not unlock/lock driver's door.
