Hi all. Just got my wheels, it's 18x8 et 38 with 255-55-18 tires. Is 10 mm hubcentric spacer enough to clear the rear strut housing or shall I put 15mm?
i'm worried that 15mm might bring the wheel/tires out too much. I'm trying to avoid it from stick out.
That's true. Tuned, you have the H&R Spacers I think, do they come with extended studs?
Yes I have H&R wheel adapters, they bolt on to stock studs on one side and have build in studs on the other side. I think 10mm still is OK as long as you can get a good 3-4 complete turns to fasten lug nuts securely. One need to explore whether stock studs can accommodate bigger spacers safely.
Wheel adapters usually have minimum thickness of 20-25mm to house lug nuts. I have 25mm with +42 offset rims, outside of wheels is flush with the body instead of recessed.
So that come out to 17 offset? If the wheel ifs flush with the body, then I might go with 15 mm spacer with 38wheel offset = to 23 offset.
Do you have a photo?
Thanks again
Yes +17, don't forget tire and rim width are also important to get the flush effect. my rim is 18x7, tire 235/60/18. Here is the best picture I have (sorry no picture showing the flush look)
