View Full Version : RX - First Generation
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
  1. Timing Belt Service - ?s re: parts
  2. RX300 Issues
  3. rx300 gas mileage
  4. Lexus RX330 2004 18 inch Chrome Wheels set of 4
  5. 1999 Rx300 blower fan barely blowing on high
  6. Replacing AF Sensor with code 1155
  7. Driver side low beam problem
  8. Odd knocking noise coming from underneath
  9. Buying a 2001 RX300 awd tomorrow...need thoughts.
  10. Please read this (vehicle won't start)
  11. Sensor/intermediate pipe repair
  12. FS and WTB posts go in the classified forums only
  13. Intermittent Loss of Power, Misfire, Exhaust Leak Noise
  14. Spark Plugs
  15. Solution for smoke from engine sludge
  16. Excessive oil usage on the highway
  17. help me check engine and vsc light on (P0300)
  18. New 99 RX300
  19. Radio Stats
  20. Worn Leather Steering Wheel
  21. A fix for Mode Servo that has me a little worried
  22. changing the color of the radio button lights?
  23. anyone know what size halo's we need for headlights?(RETROFITTERS RESPOND PLEASE)
  24. Maintenance for rx300 99 AWD with 150k miles?
  25. No first gear, starting in what feels like 3rd
  26. handle lubrication question
  27. New Guy Here- 99 rx black, grey leather
  28. problems with windows/locks from driver's door
  29. Blinking dash lights
  30. Bad Master Cylinder on 2001 AWD RX300
  31. Leatherique applied (pics)
  32. Water seal plate replacement?
  33. Transmission Cooler Lines Rusted
  34. Oil sludging
  35. Somebody help.....ugh!
  36. 99 rx300 passenger seat question
  37. Bushing repair kit for RX300 Trunk Lid Support Strut Arm?
  38. What is it?
  39. rx300 cel code P0768
  40. Correct tire pressure?
  41. Engine Oil Grade
  42. Alternator out?
  43. RX 300 lexus harrier 2001 cd player touch screen
  44. Honey, It's just a scratch!
  45. auto rx advice please
  46. Rear main seal leak- auto rx?
  47. 98 RX 300 Gearbox
  48. What the heck is this?
  49. Antenna Mast Replacement Help
  50. 02 awd tire reccomendation?
  51. Sell or fix?
  52. Considering used RX300...advice pls
  53. Oil change tips
  54. Transaxle Additives?
  55. Transaxle Drain Bolt Torque
  56. Timing idler was supposed to be all
  57. Mityvac 7201 Fluid Evacuator Trans & Oil Change
  58. Black smoke,no o/d shift , horrible gas mileage
  59. Dealer claims I need a new power steering pump, but...
  60. HID balast gets really hot? help??
  61. 2002 rx 300 rear end noise on acceleration
  62. RX 300 LED Tail Light Pic's
  63. Fuel Door Problem - need help
  64. Another oil sludge thread
  65. A/C Compressor Seal Leak
  66. mpg display
  67. What type of LSD in a 99 RX300?
  68. engine error codes: 0125,0300,0171,1130,1150, And 0768
  69. Anyone tried Pentofrost A1 antifreeze?
  70. How to repair leather seat seam damage on 2000 RX300 ?
  71. oil change question
  72. catalytic converter ugh!
  73. Knock Sensor questions
  74. warranty:)
  75. Window Vent Shades
  76. Airbag light started flashing
  77. Strange misfire issue
  78. HID lights
  79. Got an RX300
  80. Sorry! Another Servos question?
  81. Can I Neutralize knock sensor on 99 Rx 300
  82. Knocking noise in/around tire?
  83. Trac off indicator and CEL on, P0125!
  84. Help with RX 300 Check Engine codes
  85. NEW LED Taillights installed :)
  86. a/c issues
  87. What exactly does "Coach" add to 2002 rx300?
  88. Lexus RX300 2002 85k - Losing 1 quart every 750 miles
  89. How much have you towed in your RX300?
  90. RX300 & GS430 steering wheel swap
  91. 2002 RX300 Ball Bearings
  92. '99 RX300(AWD) Struts & Mounts Replacement
  93. Garage Door Opener--active even when car is switched off
  94. Front Passenger Window Motor Install
  95. I think I found touch up paint for gray RX bumpers
  96. Mayday, mayday spark plug help
  97. Broken antenna motor gear???
  98. abs brake pedal noise and pulsation
  99. Mode Servo 17 for heat
  100. 2001 rx 300 failed emissions
  101. Need Double Din for 2001 Rx300
  102. im so CONFUSED!
  103. rear lights
  104. Shelf life of "Toyota Red" antifreeze?
  105. TB/WP Life
  106. Reverse Gear Sometimes Hesitate
  107. Noise from rear end around highway curves
  108. Timing belt ?
  109. need a lil help
  110. Transmission Woes
  111. "rear lights" indicator
  112. Advice on tighter suspension for RX300
  113. Grom iPod DIY or recommend installer near S.F./S.J., CA?
  114. Engine turning over but won't start
  115. Help!!!
  116. DIY: Add Surface Mount LED to Center Console
  117. Replacing/repairing door weatherstripping
  118. Shift issues after new transmission
  119. Changed my plugs, got 2 codes
  120. Buy Acura MDX or Lexus RX300, after so many years of testing
  121. Starts but doesn't stall
  122. Rear bumper protector
  123. Dashboard Transmission Shift indicator Light
  124. Timing belt, crankshaft and cam replace!
  125. Valve cover gasket
  126. Re: Rx300 Antenna And/or Motor Replace/repair Complete Instructions
  127. what is correct part # please
  128. Quick Vote: Tires
  129. 99 RX 300 leaking coolant from front passenger side
  130. LED Light in Center Console (Cup Holder Area)
  131. Air intake box gaping open
  132. Air/Fuel sensor under car hardware
  133. AIRMIX and MODE Servo Arms
  134. Antenna Extend/Retract disable switch
  135. Convert Tape Deck to Aux input
  136. DIY Radio Antenna Mast
  137. Clunk Sound From Rear When Shift from D to R
  138. White LED in Orange/Red Side Marker
  139. Bought 1999 RX - Previous Owner Used 87 - I use 91 - MPG Plummet!
  140. How to get to or remove the washer reservoir?
  141. Subwoofer Infinity Basslink Installed
  142. Sticky: DIY backup camera integrate with gps nav screen
  143. DIY DVD Headrest integrate with GPS screen
  144. 1999 RX 300, O2 / Fuel air sensors assistance required?
  145. Rear strut replacement
  146. How would you install a LED Theft Deterrent light
  147. 02' RX Longevity
  148. RX300 December 2004
  149. Replacing spark plugs posted on youtube?
  150. Filling your gas tank
  151. Faster? Off-Road?
  152. Gear Shift problem even after new transaxle
  153. i fixed my p1133 code
  154. Was warned NOT to change my Transmission Fluid
  155. LED Taillights
  156. What Brand Fuel Injector Cleaner If Any Do You Use?
  157. Brakes and rotors
  158. How an Air Filter SHOULDN'T look...
  159. GPS system looking for disc?
  160. good morning everybody
  161. What is this part that rusted off (fell off)?
  162. 1999 RX with transmission issues.
  163. knocking sound below 2K RPM
  164. Throwing EVAP need some help please
  165. First issue with the RX: Starting Issue
  166. RX300 Fluids
  167. Time for New Springs with Struts?
  168. How far down should E-brake go?
  169. In need of rx300 rear passenger window
  170. My goodbye, sold my RX300.
  171. RX300 randomly dies on me... fuel pump? injectors? plugs?
  172. Volume up (8 number out of 10)and sound get distorted
  173. Where is the DLC1 connector on a 2003 RX?
  174. SRS Flashing Light and Dtc 72 Diagnostic Port? 2003 RX
  175. How to remove stock stereo and hook up subwoofers
  176. What's the most I should pay to repair my RX?
  177. should I do tire rotation?
  178. Help: where to find inner door trim??
  179. high rpm on the highway
  180. RX 300 Will Not Start _ Alarm Problem?
  181. Cold Air Intake for RX300?
  182. 1000 watt amp
  183. Another ATF besides Dexron for the P/S?
  184. Spark plug tube seals in the valve covers. How do you replace 'em?
  185. P1153 Code after fixing P0171 and P0330
  186. Driver window stuck down
  187. Rusting paint
  188. Help changing headlight
  189. Can not pull out my antenna
  190. 2001 Rx300 Fault Code
  191. intermittent fan blower
  192. Navigation Update Issue
  193. 02 RX300 popping noise driver's front tire
  194. Loud Buzzing Noise
  195. Radio Static
  196. 99 $1200 RX300 FWD unkown trans issues. buy or pass
  197. Well.....
  198. rpm at warmup question
  199. RX300 ABS Issue - When starting from a stop
  200. Oil Deal
  201. interchangeable sun visor for 1999 RX300
  202. Fluid change intervals: Transmission, transfer case, limited slip differential
  203. LS460 / RX350 Remote Key Fob
  204. How do I fix a vertical tear on side of driver seat?
  205. P0171, p0100, p0110
  206. Random Window Movements
  207. DIY Vehicle Speed Sensor code P0500
  208. Door Courtesy Switch part #?
  209. P0450
  210. what are the pros and cons of a k&n air filter?
  211. New 2012 18" RX350 Take off's.
  212. 2002 RX idle issue
  213. Anyone try a paint pen for bumper paint chips?
  214. P0303 knock sensor.
  215. navigation system reboots
  216. Brake problems Left front pads wearing premature
  217. Increased Vibration
  218. rx300 amp installation problem
  219. Tires, tires, and tires.
  220. Transmission Fluid level question....again
  221. Failed Emissions, CEL on now Please Help
  222. Timing Belt / Water Pump Replacement
  223. Unlock sound
  224. P0171 questions
  225. Do we need to do Chassis Lube
  226. What is your tire pressure PSI?
  227. Is it even safe to buy a pre-owned 1st RX now?
  228. A/F sensor? Search brought up too many opinions.
  229. How to remove my PCV valve
  230. Lubrication of Ignition Lock
  231. Arm rest
  232. Tailgate help.
  233. Side view mirrors shake?
  234. Helpful Video's For RX300 Troubleshooting
  235. Stock Alarm
  236. Coolant leak please help
  237. passenger mirror fails horizontally OK vertically
  238. Anyone replace expansion valve
  239. Whats the Next Step.
  240. To Change or Not after 6 months
  241. Bluetooth Interface feedback: BT35-TOY
  242. IACV Cleaning Fast Idle Too High
  243. I want to get to the bottom of this ... why is my gas mileage BAD?!
  244. Does the CD player required a code?
  245. Transmission Fluid Replacement Question
  246. RX300 shaking problem
  247. Is there an emergency fuel shutoff switch on RX300?
  248. Transmission might fail soon
  249. Quick transmission question
  250. Tranny Fluid Leak?...Need help
Content Relevant URLs by vBSEO 3.5.2
