Check engine light Po5o5
Old Jun 18, 2021 | 11:10 AM
Toymaker's Avatar
Toymaker
Default Check engine light Po5o5
Don't know if this have been covered. MANY threads to look through.
I have a 2001 Lexus rx300. Check engine light and VSC light came on. Only code I got was PO5O5.
It has a list of things it could be. I wanted to clean the throttle body first but don't know if it's a manual or electronic.
Hoping that takes of the problem. Does anyone know which throttle body
I have?
I'm gonna star there the go down the list. TIA!
Also could some tell me where the ETCS fuse is? It's one of the things on the list,,,
  • Faulty Electronic Throttle Control System (ETCS) (Throttle body)
Old Jun 18, 2021 | 10:12 PM
salimshah's Avatar
salimshah
25 Year Member
This is my first encounter with P0505.
At about 65K miles many folks have reported issues with IACV [please search and look up the DIY]. Idle issue does not pop up any codes.
RX meters the air going in to the engine and then analysis the exhaust. Gas pedal, via cable, open up the air to the intake and the ecu meters in the right amount of gas.
Salim
Old Jun 19, 2021 | 11:09 AM
Toymaker's Avatar
Toymaker
Thank you Salimshah. I'm taking it to my dealer cause none of the smaller shops are familiar with that code either. $50 to diagnose then however much more to fix it.. Plus no one knows why the VSC light came on at the same time. *sigh*
Old Jun 19, 2021 | 02:03 PM
salimshah's Avatar
salimshah
25 Year Member
VSC light is a companion light to the Check Engine Light.
Unconfirmed thought is that the VSC is actually deactivated.
Salim
Old Jun 19, 2021 | 07:41 PM
bordenj66's Avatar
bordenj66
Is the issue resolved? Are/were there any other symptoms?
Old Jun 22, 2021 | 06:51 AM
Toymaker's Avatar
Toymaker
Issue isn't resolved yet. I have an appointment in 2 weeks at the dealer. As to symptoms I don't really notice any and that's the problem. it's running the same. Hoping the dealer can figure it out.
Old Jun 22, 2021 | 06:54 AM
Toymaker's Avatar
Toymaker
I guess that's possible but would that throw a code separate to the other one?
AlaskanLS
26
Feb 27, 2017 02:52 PM
818GS
Jun 14, 2013 06:20 AM
Max Power
Nov 8, 2010 06:06 PM
Percy
Jan 1, 2006 07:50 AM
Splatsc300
SC400 / 300 Classifieds
Jun 14, 2005 12:14 AM
