Squeaky Door Check ?? Suggestions?
Old Jul 28, 2021 | 07:35 AM
JapanBuick's Avatar
JapanBuick
Default Squeaky Door Check ?? Suggestions?
Hello friends, first post!!
I really liked the 1st Gen RX, so much so I think I actually prefer it over the newer models (honestly they seem better built than the newer ones where the dashboards get all cracked up, ick..)
I believe the door checks are a bit squeaky. I could be wrong, perhaps the noise is coming from elsewhere.
I don't particularly want to rebuild or replace the door checks as they seem to work okay (good enough for my liking, at the moment), but would like suggestions on getting rid of the noise.
At what point should I try lubricating? What should I use? I was thinking graphite may be good, or I have some bike chain lube that I used for the radio antenna....
I can try putting my ear to it to see exactly where the sound is coming from, but I'm not sure. Perhaps the pin in the door, or maybe it's inside the door behind the door panel.
'99 RX 300 w/ Premium Package
Thanks!
Old Jul 29, 2021 | 09:19 AM
ricco750's Avatar
ricco750
I figured at least 10 people would jump on this when it popped up, but I'll be happy to give my two cents. I assume you are talking about the slide bar on the door check mechanism. I would clean it well, then apply white lithium grease for a lubricant.
Old Jul 29, 2021 | 11:42 AM
bordenj66's Avatar
bordenj66
Try vaseline or some silicon spray. Both will lubricate and also prevent rusting.
Old Jul 29, 2021 | 05:29 PM
sktn77a's Avatar
sktn77a
Squeaking or creaking/groaning?
Old Jul 29, 2021 | 05:40 PM
This stuff works great for door checks, clean whatever build up is on there first.
https://www.canadiantire.ca/en/pdp/p...3815p.html#srp
Old Jul 29, 2021 | 05:59 PM
JapanBuick's Avatar
JapanBuick
Thank you all for the tips. I was playing with the doors the other day and I can't even really get them to make noise now. For the moment, I just shot some chain lube into each hinge and each door check. Everything is quiet.
If noises return or get worse, I will use something better like a silicone spray.
The door checks seem to be in fairly good shape, and not worn out, at least for now, so I don't need to worry about messing with that.
Thanks again
Old Jul 30, 2021 | 09:41 AM
salimshah's Avatar
salimshah
25 Year Member
Never worry about this. Your opinion is as important.
Salim
G6612
RX - 4th Gen (2016-2022)
Jun 12, 2025 11:43 AM
GNS
Jun 16, 2024 05:08 AM
Kennyr44
Jun 15, 2017 03:20 PM
FamilyRX
RX - 3rd Gen (2010-2015)
Jan 2, 2013 01:16 AM
NemeGuero
Jan 13, 2010 08:36 PM
