View Full Version : Maintenance
- Chevron Injection Cleaner ?
- Synthetic???
- Can you notice when your A/C is on?
- 95 Timing Belt Change (Part)
- Oil filters: 90915-20004 or 90915-YZZB9?
- How Often Do You Use Your Dealer For Services?
- Help! smog check fail es300
- irontoad.com feedback please
- es300 90K service part numbers
- Obd ?
- Nightmare at the dealership
- 90K Service???
- Engine Misfire Intermittently 1994 LS400
- anybody use Castrol GTX HIGH-MILEAGE oil ?
- RX300 service manuals
- I'll try here - brake upgrade - caliper bolts
- Does anyone know of any Rent-A-Bays?
- Air Filter
- Looking for Toyota part numbers...
- Oil Overfill
- I think my front strutts are shot
- speedo needle and ECU reset question
- recharging a/c
- Jacks
- Which oil filter to use?
- Synthetic diff oil for 93 GS good idea?
- ran out of freeon what to do? what to do?
- Red Battery Indicator in dash flashing
- parking brake releases S-L-O-W
- 95 ES300 A/C Filter
- The First Service
- window adjustment
- 2002 ES300. Steering wheel is off-center, can I re-center it myself?
- Engine mounts
- Paint Quality
- Disable Auto-Tilt & Telescope on GX470?
- RX300 FWD differential oil...it bugs me!!
- Should I use 5w30 or 10w30 in my 98 GS4 with 90k miles....
- Inside air filter (by floor, glove box or waht)
- 98 ES300 Differential Fluid Change
- which suspension part dies first?
- difference between 470/landcruiser ???
- Part Number for AC Filter
- Auto transport referrals
- Problems with passenger side door on 92 sc300
- Is WD-40 bad??
- Non Remote Master Key Programming for ES300
- Midas, Jiffylube, and other shops...
- problemo..
- A/C needs recharged
- Dallas Area Brake Shop
- GS4 Oil Filter: Mobil 1 vs Toyota Stock
- Where to buy Lubricant?
- Going rate for a tune-up?
- Where can I get a manual that will tell me how to service my GS400?
- Where is Coolant Drain Plug on ab RX300?
- lexus service
- Diy Section On (Club)Lexus.com?
- power window stuck?
- ES300 60K eval with questions
- GS: Where is eng block coolant drain plug???
- full tranny flush
- Air filter yet again?
- trans cooler leak question
- seat belt problem 95LS400
- Rattle from behind the spedometer and steering wheel whinning noise..? HELP!
- Strange!!!!!!!!!!!
- sc300 sc400 window regulator
- Heard something about Mobil1 synthetic oil...
- Moonroof noise fixed!!!
- Amsoil vs Mobil 1 vs ULX-110
- 75,000 Maintenance SC300
- 75k maintenance?
- Moonroof not closing - help!
- moonroof problem
- ES 300 Radiator Drain Plug location
- Broken Seatbelts
- Transmission oil dark --> car dieing?
- Getting Front Bumper Painted?
- Door lock problem
- '95 SC300 a/c problem
- Just purchased used GS4 with 31k miles...
- 93 ls cabin filter change
- 94 es 300 CV Joint
- LS - Whining noise
- Flasher going bad
- Is windshield damage a common problem on newer Lexus cars?
- Replace Emblem or Re-polish it?
- Windshield Repar?
- Extended Warranty - Need Your Advice
- Chevron w/ techron
- Changing oil filters...
- Maintenance Page Data Entry
- 93 ES300 A/C Not blowing cold air. ???
- alignment - had it done, but
- Reset "Check Engine".
- How To Change Dealer Settable Options
- climate control panel + outside temperature + clock out
- Crud ........The "Check Engine" Light is still on
- New non-remote master key - Help! Help!
- The usual problems + oil question
- Engine Replacement
- Shell gasoline
- Curious about this Dealer
- 93 ES 300 Full tranny fluid home flush writeup.
- Need definite answer on '96 timing belt.
- 98 Es300
- Extended Warrenty Question??
- How to calibrate a Throttle Position Sensor with a multi-tester
- P/S rack leaking $$1800
- Fuel Filter
- 97 ES300 light out
- '98-'01 ES side mirror question
- Need new passenger side mirror
- home tune-up
- How do you take out a WORN SCREW??
- Need advice on 30K service
- High RPM at cold start
- ATF starting to turn black
- LX470 steering wheel.
- Why is 'boost' negative on N/A?
- Failed My Inspection!
- Service Nightmare.lexus Of Melbourne
- Strange and frustrating Noise???
- Tranny Bumps when I give it gas - 93 es300
- Running tranny flush - First timer questions - 93 es300
- What do these air filters do?
- Restore
- Pinging/Popping Noise ? Help
- Electronic schematics for ES?
- Wiper Blade Replacement Question
- Should Lexus oil filters be used???
- How many bottles of transmission oil will i need?I want to change the oil.
- Car detailing \ New mats
- Belt tension question
- Programming masterkey for RHD GS300
- Oli filter location on GX470
- 2 sets of cats means OBD II?
- Independent LExus Service in Massachusetts?
- Gas Question
- Emission test
- oil, i never change the oil!
- 60K Service Cost... Unbelievable!
- 60K Service and the Don't Touch List
- Warranty Question/Clarification
- Oil Changes
- "Brake" Light
- Stock anti-squeal pads?
- Jack Stands
- A/C Compressor Not turning on.
- How can I tell if new battery was installed?
- 60k And 90k Maintenance List?
- Lexus Service At Dealerships
- Top-Sider Oil Changing Pump
- Can someone give me more info on how to do a running trans flush?
- Defective ES Engines???
- 50,000 mile service do it yourself
- Lights stay on without key.
- help with changing differential oil and transmission fluid
- Downloadable Repair Manual ?
- Loaner for 60K service?
- '98 es o2 sensor
- Bad door switch?
- (In)accuracy of computer mpg
- Running Rich?
- Coolant Type
- 93 LS Creaking Noise when going over bumps
- Timing adjustment
- Heater won't work
- differential leak
- Check Engine Light
- Clean Throttle Body,New Valve Cover Gaskets-Anything Else?
- Independent Lexus Service--Minneapolis
- Salt belt suggestion
- ES300 spark plug change
- timing belt change?
- Oil Additives
- Lead cover question...
- radiator flush
- Help!!!
- Rotten Egg Smell Revisited..
- Can I use any brand coolant?
- simple maintenance questions...
- Power steering fluid recommendation…
- Dead Battery or Altenator ?
- Do I REALLY need to follow such a rediculously anal maintinance schedule on my GS4?
- maintence
- HELP! Is the dealer trying to rip me off on service!??
- GS brake light comes on
- BIG problem....
- Fuel Filter Location4 GS430 and SC430
- overheat at idle
- 1998 GS400 Brake Fluid Amount / Volume
- Squeaky, Creaky moonroof molding!
- Losing oil every week
- "Braking" and Brakes Question
- Devil Dog code 71..........
- My lexus wont start when key is turned.
- Stumble or hesitation at 2700 rpm's
- Timing belt and service
- ES 300...Air Compressor
- How-To on changing the tranny oil on 98 ES300?
- 90K Lexus Service Cost?
- Rod Millen Problems? Please read
- Spark Plug replacement - anything else while I'm there ?
- 60K tuneup...
- Sounds like liquid flowing when I hit the throttle, anyone have that?...
- CPO Question
- hwo much for...
- Windshield Repair perhaps for Free ?
- Engine temp rising at idle
- 120K Service
- changing rear diff oil
- break-in period?
- Flushing Brake Fluid...Not Recommended?
- Servicing 91 ES250 struts
- check engine light, 92 ES, O2 sensor
- Techtom Code Reader – Diagnostic Port Tech Question
- crack in winshield
- Mods/Additives: Less is More?
- odometer roll back
- Synthetic Oil - From Factory?
- Oil Options
- Lexus #1 in Durability/Quality for 7 straight years
- oil change
- Modding EGR valve for performance?
- small leather tears
- Air Filter, how often to change?
- Need Aftermarket Keyless Entry!
- Highway wind whistle noise
- E Shift
- Sunroof rattling noise:
- what are TSB's?
- Lexus Maintenance Schedule
- FYI: 2001+ GS uses different A/C Filter
- Clutch replacement?
- "Brake" Light keeps turning on
- CD player won't play
- Changing courtesy light switches on first-gen LS?
- Funky smelling A/C?
- Maintenance Questions...
- Does anyone know where to buy a solenoid?
- Trans fluid leak at Radiator connection
- New Lexus magazine???
- Strange noises in my GS4
- PS Fluid
- 1997 ES300 newbie
- Replacing PS High pressure hose 93LS
- RAM FX air filter
- Royal Purple
