recharging a/c
Old May 14, 2003 | 11:29 AM
johnw's Avatar
johnw
Default recharging a/c
Both Lexus and another mechanic have told me I have a in my a/c. Both said it would cost about $1200.00 to fix. Now it only needs recharging about every three months ( and I live in S.W Florida where you never shut it off) so I went to Discount Auto and got a can of 134a and a quick connect hose for the low side. I also got a can of Interdynamics R-134a Stop Leak and Detector, it says it pinpoints leaks and stops them in seconds.
Now it all sounds good but has anyone actually tried it or have any suggestions ?
Also, approximately where is the low connect that I tap into ?
Look forward to your help.
johnw.
Old May 14, 2003 | 01:30 PM
retrodrive's Avatar
retrodrive
Search Function Inc.
I can tell you exactly in a couple of weeks. Even take a pic if it is possible to get there easily. I just replaced my AC system and see my mechanic in a coupe of weeks so he can show me where.
Old May 14, 2003 | 08:58 PM
johnw's Avatar
johnw
I went ahead and put in the stop leak without a hitch but now I hear a squealing noise from the fan belt. Since I didn't spill anything and the low fill hose is in back of the engine I don't understand why it's doing it. All I can think of is maybe I had a pin hole leak in an a/c componnent next to the fan belt and it sprayed out as it sealed.
My question is this; Can I use a type of belt dreesing spray on the belt or does Lexus not reccommend it?
johnw.
Old May 23, 2003 | 04:03 AM
007's Avatar
007
Where is the leak... is it at the compressor? or near the pulley? If the compressor is about to lock up or the bearings in the pulley are going back it could be leaking there and that could cause the squeal.
Belt dressing should be okay... but unnecessary since there is constant tension on the belt from the drive belt tensioner. The squealing noise is indicating bad bearings in one of your components.
Old May 23, 2003 | 07:52 PM
johnw's Avatar
johnw
I was told the leak is coming from the component under the dash which is why they want 1200.00. The squeak has stopped and so far it seems to be holding, I do have a question though: I used a single hose and filled the low side of the a/c, but I noticed in the auto parts store they had a more expensive unit for filling that monitored both the high and the low like the mechanics use.
Does this help you fill it more completely ?.
The parts guy said I didn't need it but if thats the case, why do auto shops use them ?
johnw.
Old May 30, 2003 | 08:39 PM
gp1200x's Avatar
gp1200x
You don't need it. It allows you to monitor the high pressure side...useful for home A/C units. Just don't overfill the sysem or it will discharge excess freon. It could also damage the compressor.
I doubt the leak will seal with the additive but you never know. Check the belt tension again to make sure it is tight and not slipping. The noise may be from belt slippage. Your A/C compressor may not have been cycling on before because of low pressure in the system. Now that it is cycling, the belt may be too slack and slipping.
JNP1227
Apr 22, 2019 10:28 AM
RXstate
GX - 1st Gen (2003-2009)
Jun 30, 2011 10:28 AM
Viper6
May 20, 2011 11:51 AM
huerdo623
Jun 24, 2007 01:41 PM
Laxsc300
May 25, 2006 07:49 PM
