Lubricating Roof
Lubricating Roof
Called my Lexus dealer about setting up an appointment for an oil change and disconnecting those ugly RDL. Will be doing this after I get back from a trip around June 28th. Talked to the service guy (not the guy who gets dirty, but the guy that makes you feel like a King because you own a Lexus) about lubricating the roof components while it was in for service. He said "Sure, we could spray some WD-40 on it for you" Really...WD-40!!! Thought something in the line of some silicone lubricant would be what they would recommend. Any thoughts?
they are gonna charge you $100 to turn off the DRL. You can easily do it with the TechStream software and connector.
you need a laptop and $20-$25 for the cable and software.
then you need about $5 to go purchase a can of spray white lithium grease at Walmart.
A spray can of silicone, for the rubber, should be about the same price or you could get a tube and apply it with your finger or a clean towel.
the dealer may do the entire job for about $300.
Last time I looked at those joints, the grease looks white so it should be lithium grease (not 100% sure though). If your service advisor tell you that they will spray WD40, go to another dealer. WD40 will attract dirt like a magnet, and that'll do more harm than good.
The following 2 users liked this post by digitatc:
JohnnyCake (06-12-19),
Shushley (01-10-23)
I use Gummi Pflege stick on my weather stripping and rubber seals. It's made for precisely this application. The stick has sponge tip on it which makes for an easy and clean application.
On nearly every car I've used it on there was a noticeable difference in wind noise.
Highly recommended.
Highly recommended.
The following 2 users liked this post by RRocket:
Born2saw (09-07-19),
daddiojigg (09-03-19)
Rr
Just ordered two bottles off Amazon. It was the only place besides Ebay that i could find it. Where did you get yours?
I've bought it from places that carry detailing supplies as well as Amazon. Like here: https://www.autogeek.net/1z-einszett...are-stick.html
Wherever it's available, really.
Please do post here how you like it.
There's also another similar product by Sonax...but I've not tried it yet.
WD-40 fixes everything...heck, have him lube the leather while they are there...
I'm new to these cars, can you post more detail about techstream and which cable to get? What else does it let you do? I was under the impression these ECUs were locked down pretty tight.
Also, in terms of lubricating things, I've used "Fluid Film" for years on various things and its magical.
https://www.fluid-film.com/
Not sure if it's right for this application, but I thought I'd pass it along.
Here are some of the main informational Techstream links:
https://www.clublexus.com/forums/sc4...r-2-0-4-a.html
https://www.clublexus.com/forums/sc4...solutions.html
https://www.clublexus.com/forums/sc4...-and-tpms.html
joemg (09-04-19)
Krytox is good. In my former place of work, we applied Krytox on rubbing surfaces on the panoramic sunroof.
Of course nothing beats Shin-etsu Grease from Honda, however they are so expensive, $17 for a small tube, well worth it.
The following 2 users liked this post by mandyfig:
Lavrishevo (09-04-19),
Natroth (09-04-19)
mandyfig post #13 is spot on with the Honda 08798-9013 silicone grease.. It is highly recommended on the LS forum as well. A tube of it is expensive but it will last for every. Just a thin film coating applied with a gloved hand once or twice a year and the rubber weather stripping will stay just as soft as the day it was made. Great Stuff
Dennis
Dennis
Dennis
Dennis
I had a hard time finding it here though.
