AFS Warning light
Old 03-17-19, 03:37 AM
s19sly
s19sly's Avatar
Question AFS Warning light
New owner and loving it. After 10 to 20 miles driving the Warning light starts to flash and the system goes u/s. If I stop, turn off and restart it clears and works again for another 10 to 20 miles...Any ideas?
Old 03-17-19, 03:48 AM
VVTiBob
VVTiBob's Avatar
Two thoughts come to mind. The AFS was accidentally turned off, check the button. Or, corrosion in the Sensor meaning, it needs service.
Old 03-17-19, 03:51 AM
VVTiBob
VVTiBob's Avatar
Also, welcome to the forum. Please read this...https://www.clublexus.com/forums/sc4...430-forum.html
the SEARCH tool really is terrific for finding answers. I just typed in AFS on the standard search and came up with several prior threads with two possible solutions.
Old 03-17-19, 03:52 AM
s19sly
s19sly's Avatar
Thanks for the Super Quick reply.
The button is operating fine so it looks like option 2, which is frustrating as it was in at Lexus for a Airbag recall last week....
Never mind...thanks again for the info.
Best.
Nick
Old 03-17-19, 08:11 AM
Harold57
Harold57's Avatar
Welcome to the forum. Post some pictures when you get the chance and let us know what you find out about the problem.
Old 03-17-19, 09:43 AM
DshngDaryl
DshngDaryl's Avatar
What is AFS? What is U/S?
Old 03-17-19, 09:50 AM
VVTiBob
VVTiBob's Avatar
Lexus's Intelligent Adaptive Front Lighting System, is a driver-aid that adjusts the direction of the headlights in response to steering inputs and vehicle speed, in effect pointing the low-beam headlights into the corner and improving your view. 2006 and greater SC430s.
U/S? ya got me there.
Old 03-17-19, 09:52 AM
s19sly
s19sly's Avatar
Adaptive Front Lighting is AFS, u/s Means Unserviceable, a posh way of saying, not working
Old 03-17-19, 10:07 AM
VVTiBob
VVTiBob's Avatar
Two issues regarding AFS switch and speed of the vehicle. Switch has what some might consider reverse or backwards operation. See position two & three in the diagram.
s19sly (03-17-19)
Old 03-18-19, 11:23 AM
DshngDaryl
DshngDaryl's Avatar
It sounds like this would be a good time to ask if you have ever heard of Techstream? That is the Toyota software that will let you read Lexus/Toyota error codes. It is very affordable if you buy it off eBay.
If you are interested in fixing this problem yourself (or just about any problem with your Lexus) you should do a search on this forum and find out how you can get a copy.
The following 2 users liked this post by DshngDaryl:
orsmondjm (03-19-19), s19sly (03-18-19)
Old 11-30-19, 07:47 AM
Harold57
Harold57's Avatar
When was the AFS introduced to the SC430? 2005 or 2006?
Old 12-01-19, 03:49 AM
Bgw70
Bgw70's Avatar
Headlights and taillights were changed in 2006
2005
2006
2005
2006
Harold57 (12-01-19)
Old 12-01-19, 06:29 AM
Harold57
Harold57's Avatar
So the AFS came in with the new head and tail lights? (That would make sense.)
Old 12-01-19, 07:55 AM
Bgw70
Bgw70's Avatar
yes sir, 2002 - 2005 up down only,
2006 - 2010 up down and left right (as you turn steering wheel.)
Harold57 (12-01-19)
giddyup69
NX - 1st Gen (2015-2021)
12
11-05-18 02:45 PM
roby63
RX - 3rd Gen (2010-2015)
03-20-15 09:32 AM
adamchi
08-19-11 03:57 PM
dlap
08-11-09 05:31 AM
Big Joe
05-31-09 10:12 PM
Quick Reply: AFS Warning light
