need wiring diagram of o2 sensor connections to ECU so i can do continuity test on them. had intermittent fault lights which went permanent after moving sensor plug/harness. new sensor fitted but still the same , codes are p0133 and p0134 , so sensor slow to react which leads to no activity code i assume. all help much appreciated. fuel consumption has come down as well.
I am unclear on what you mean by the statement. Fuel “consumption” versus efficiency can be affected by several components. Besides the O2 sensor problem, you could have an injector, fuel regulator, or fuel filter issue too.
Reason: Clarification
thanks for this , it is because loss of oxygen sensor makes it run richer apparently. can't see them using different ecu, probably just in a different position. we will see
