Low Washer Fluid Light?
Old Feb 4, 2019 | 08:40 PM
mtnduc's Avatar
mtnduc
Default Low Washer Fluid Light?
2006 SC430
Out of the blue my low washer fluid light came on.
Filled the reservoir and it went off.
Next start cycle it is back on.
Assuming failing sensor.
Where is it located?
TIA.
Brian
Old Feb 5, 2019 | 01:50 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
Originally Posted by mtnduc
2006 SC430
TIA.
Brian
just curious, was the reservoir still full or is it leaking?
Old Feb 5, 2019 | 06:56 AM
mtnduc's Avatar
mtnduc
BGW70 -- You know that's a good question.
I've owned this car for 7 years and don't think I've ever put washer fluid in it.
It's a Summer car only, very few days has it ever seen rain.
I'll try to dump some more fluid in this AM and see if it puddles.
Old Feb 5, 2019 | 07:52 AM
mtnduc's Avatar
mtnduc
Yep, leaking like a sieve from under the passenger side headlight.
So I'm assuming the tube to the headlight washer is disconnected.
That's a front bumper removal to re-connect sort of thing isn't it.
If I recall it's only like 10-12 10mm bolts and a couple Phillips heads to drop the bumper. A couple PITA ones in the fender wells.
Correct?
Old Feb 5, 2019 | 07:59 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
Correct?
i don’t think you need to drop the bumper. See if you can possibly look up there to see the problem first.
the hose might have a crack, who knows. It’s probably an easy fix.
Old Feb 5, 2019 | 08:13 AM
mtnduc's Avatar
mtnduc
I had my front bumper repainted a few months ago after some idiot backed into me in a parking lot.
I'm guessing the shop didn't get the hose re-attached correctly.
I bet it's been driven less than 300 miles since I picked it up so it probably just fell off when I did a 2.5 hr roundtrip Sat.
Old Feb 5, 2019 | 08:24 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
When I bought my 2002, i had the same issue...when I put washer fluid in, it immediately leaked out.
turns out some repair work had been done on the front end and they didn’t reattach the hose.
i did NOT, drop the bumper to reattach the hose.
i either reached in from the bottom or the wheel well...been to many years now.
i do know it was easy to correct!
Old Feb 5, 2019 | 01:57 PM
mtnduc's Avatar
mtnduc
Dropped the bumper.
They failed to connect both headlight washers.
$15.00 of RainX washer fluid later and its all good.
Thanks.
Old Feb 6, 2019 | 09:58 AM
Harold57's Avatar
Harold57
Glad that it was an easy resolution and that you got it fixed.
ericsofunn
Nov 14, 2019 06:12 AM
moe33
RX - 1st Gen (1999-2003)
Feb 11, 2018 09:48 AM
pass427
Jan 28, 2012 06:56 PM
dkingphd
Jan 6, 2008 04:01 PM
Bichon
Feb 27, 2007 08:39 PM
