Wheel speed senor replacement help
Old May 19, 2007 | 10:41 PM
JOHNBRAY11's Avatar
JOHNBRAY11
Default Wheel speed senor replacement help
I had a CEL and the code was a p050 ( wheel speed sensor). Before i order one, which wheel is it where the speed sensor is located? Also how and is hard to replace?? The speedometer works fine also. Any help would be great. thanks
J~
Old May 20, 2007 | 05:28 AM
Lexmex's Avatar
Lexmex
J~
The speedometer was the other thing I was going to add, but if it is working fine...
I have gotten this error before when I did my emissions test down here for the first time, given the AWD RXs are full-time AWD, but here CELs don't matter, just passing the test is what matters.
Here is the location below. Not sure how visible this would be with a stock air box.
Old May 20, 2007 | 10:34 AM
JOHNBRAY11's Avatar
JOHNBRAY11
Thanks Lexmex, I guess i will take the air filter off. I had one more question. I put bigger rims on tha car. I had Autozone download the code and clear it out and it has not come back, should I change the speed sensor anyway?? Thanks again for all the help..
J~
Old May 20, 2007 | 10:59 AM
Lexmex's Avatar
Lexmex
No, I would leave it alone. Keep in mind the ECM can adjust within a certain range to these types of things (just like my modifications) and since you haven't gotten an error, it means all is well for now.
Jesterking
Jan 16, 2019 04:57 PM
Bankswood
Jun 17, 2017 02:08 PM
freddyboy
Sep 11, 2016 05:19 PM
Gs3500
Jan 1, 2016 04:23 PM
robert187
Suspension and Brakes
Jul 16, 2012 05:47 PM
