brake light
Old Jun 25, 2007 | 11:32 PM
bloo1987's Avatar
bloo1987
Default brake light
Hi. I was wondering if anyone has experienced this problem before. I had my brake light out on the dash come on. Then when I had my friend looked in the back it was "supposedly" blown out I guess. But today I turned my car on and noticed the brake light out was off. And I had someone look at the back while i steped on the brake the brake light was working. So I was wondering if anyone has this kind of problem is it a common problem or loose wiring? Thanks.
Old Jun 26, 2007 | 03:34 AM
bob2200's Avatar
bob2200
There are three brake lights in the rear (left, right, and top center). I'm assuming that only one of them was temporarily out. I'll guess the most likely cause was an open in the light bulb that fused back together by vibration. Corrosion at the socket is also a possibility.
Either way, I'd replace the bulb at your leisure if you know which one it was. If you don't know which bulb it was, just wait until it happens again.
Old Jun 26, 2007 | 03:39 AM
bloo1987's Avatar
bloo1987
hey thanks for the info. it was the center top one. maybe ill check it out tomorrow.but dealer bulbs are pretty expensive.
Old Jun 26, 2007 | 06:26 AM
thomas1's Avatar
thomas1
you can get that bulb at any auto parts store bulb number is 921
Old Jun 26, 2007 | 09:00 AM
mandyfig's Avatar
mandyfig
Autozone, Advance Auto, Pep Boys, Napa...
Old Jun 26, 2007 | 09:46 AM
Meetya's Avatar
Meetya
Walmart...
Old Jun 26, 2007 | 12:44 PM
lexgurl's Avatar
lexgurl
I had the same "problem" with the warning light on the dash indicating that a bulb had blown--come to find out, through the very nice body shop that I took it to, they just took the bulb out and cleaned the base, and voila' the bulb worked! They said that the bulb base gets dirty and once cleaned, it will work---maybe this will work for you too...?
Old Jun 26, 2007 | 12:51 PM
zombie's Avatar
zombie
when that happened to me, i kicked my taillight and it started working again.
Old Jun 26, 2007 | 01:09 PM
bloo1987's Avatar
bloo1987
omg so many problems with the RX lately
Stemmer
Jul 1, 2018 05:40 PM
lexus05es3
Jan 5, 2018 01:28 PM
vetkilr
Jul 1, 2011 05:30 AM
RX300Scott
Jan 18, 2011 09:56 AM
bshig
Jan 13, 2008 04:59 AM
