I am tired of resetting my clock!
Everytime I start my vehicle, it resets the clock back to 1:00. The dealership said it was a sign of a bad cranking battery but it checked out OK. Any suggestions? Bad cables? Does it have a backup battery?
Super Moderator
This happened to me a long time ago in a galaxy far, far away (actually about 5 years ago here in Mexico), and it was the battery. I got Lexus to cover it under warranty.
Bob, the battery "looks" 8 years old but there was no documentation to say whether it is any newer. We bought the vehicle used. It turns the engine just like a new one but may not be providing the amps needed to run everything like it should.
Believe us, it is time to change the battery. If you want to push it, carry jumper cables or auto-club card as you might be left stranded.
[there is a slight chance that you battery needs attention and can be revived by adding electrolyte and an overnight charge]
Salim
Batteries are cheap enough and important enough to not attempt saving one. You don't know the history of the battery so just bite the bullet and get a new one.
yep same thign with me, after 6 years needed a battery. Get a Kirkland one from COSTCO they are exactly like Interstate (made by same OEM Johnson Controls) for much cheaper.
If it's a Panasonic battery, you can be pretty sure it's the original. Not many Panasonic replacement batteries around.
Costco batteries are the way to go.
$50, built in stand (in some models), built in handle, meets/exceeds OE CCA's, 5+ years of trouble free(battery) driving, made by Johnson Controls...
Can you have it any better?
Are costco batteries sealed like the OEM?
Salim
Salim
We had a thread on battery replacement recently (see https://www.clublexus.com/forums/sho...ob2200+battery ) . It's possible the 1999 year has a different style bracket than my 2002 model and that's why some people didn't need the washers I did in installing the Costco battery. Anyway, I recommend the Costco battery too.
