Speedometer needle over 160MPH!??!?!
Old Apr 23, 2007 | 05:01 PM
Jewcano's Avatar
Jewcano
No Sir, I Don't Like It
CL Folding 1,000,000
Default Speedometer needle over 160MPH!??!?!
So my neighbor's RX300 is giving him some hell. One of the problems though is the needle flew all the way past 160mph, and is just resting there pointing directly down. I searched this part of the forum but really didn't come up with anything of the sorts. Anyone got any clue what could be wrong? Also his battery has been draining alot recently. I thought it might either be the battery or the alternator, but both check out ok. Any help would be greatly appreciated.
Old Apr 23, 2007 | 06:12 PM
YoshRX300's Avatar
YoshRX300
How old is the battery? And are the battery terminals making good contact? It once happened to me with my previous car and battery also checked ok, but still changed it and no more needle problems.
Old Apr 23, 2007 | 06:23 PM
Jewcano's Avatar
Jewcano
So you're needle went all the way on the speedometer, and just stayed there, whether the car was on or off?
Old Apr 23, 2007 | 09:33 PM
YoshRX300's Avatar
YoshRX300
Only did that when I put the key in the ignition and tried to turn on. It went from 0-160 then came back to 0 after start.
Old Apr 23, 2007 | 09:49 PM
Jewcano's Avatar
Jewcano
Well my neighbors is staying past 160....so i dunno whats going on, i've never seen it, its as if the needle is broken and but why would it go that far?
Can anyone else chime in?
Old Apr 24, 2007 | 03:53 AM
edbro's Avatar
edbro
Is the scenery blurry when you look out the windows? Has your commute become notably shorter?
Old Apr 24, 2007 | 07:36 AM
YoshRX300's Avatar
YoshRX300
If its staying at 160, I would say its deffenetly broken. I would try tapping the speedometer cluster with my finger when the car is running. And maybe the needle will come back to 0. And or remove the battery for a few and make sure the battery terminals are making good contact.
Old Apr 24, 2007 | 10:39 AM
Jewcano's Avatar
Jewcano
Har har....i think we have a comedian on our hands here.......
I pretty much figured the same when i looked at it. It would bounce a little when you pushed the bar there that you use to reset the trip meter. I just assumed that maybe someone else has experienced this before, and perhaps could chime in, i appreciate you trying to help YoshRX300.
Old Apr 24, 2007 | 10:49 AM
YoshRX300's Avatar
YoshRX300
No prob Jewcano, hope you find a solution to your neighbor's RX.
Old Apr 24, 2007 | 10:53 AM
Lil4X's Avatar
Lil4X
Out of Warranty
That battery drain is probably no coincidence. Your neighbor needs to put an ammeter in the battery circuit to determine if the drain is from an external short or one inside the battery itself. (NOT BETWEEN THE TERMINALS) I would vote for the battery. As they age, plates often collapse, resulting in internal shorts that can pull a battery down dramatically even overnight.
Are there any strange effects going on in the radio stack? RX's are well known for mysterious re-setting clocks, display anomalies, even memory dumps when battery voltage falls below something like 11.2 vdc. You still may be able to crank the engine, but if system voltage is low, all kinds of craziness can appear in the electronics. Clean and replace the terminals - even replace the battery if it is over a couple years old - especially if it has been deeply discharged a time or two.
Old Apr 24, 2007 | 12:01 PM
Jewcano's Avatar
Jewcano
Will tell him to look at that thanks.
However does anyone have a clue about the needle??? I've personally never heard of one just shooting past 160 and just hanging there as if its disconnected.
Old May 3, 2007 | 07:13 PM
wishihad1's Avatar
wishihad1
did he have the "D" bulb replaced, or the combination meter out?
Old Jun 11, 2007 | 07:28 PM
Jewcano's Avatar
Jewcano
ANCIENT THREAD REVIVAL:
Well it seems his cluster has done it again. I'm at a complete loss as to why i could be doing this.
Any additional input?
Old Jun 11, 2007 | 08:39 PM
Meetya's Avatar
Meetya
Just take the cluster out turn it upside down for 10-20 seconds and slowly turn back clockwise and reinstall. I have seen this and and fixed it this way. It usually happens if the alternator+battery die at 70+ mph or someone just replaced the "D" light or anything on the cluster.
Old Jun 11, 2007 | 09:12 PM
Jewcano's Avatar
Jewcano
Hrmmm, will take a look at this thanks
Shaggydog
Apr 2, 2015 12:36 PM
lex3gs3198
Maintenance
Apr 4, 2013 07:31 PM
slidingIS
IS - 1st Gen (2001-2005)
Oct 8, 2010 08:29 AM
imDementeD
Aug 1, 2010 04:27 PM
