Suspension thoughts.....
Old Apr 18, 2007 | 04:36 PM
defo's Avatar
defo
Default Suspension thoughts.....
I believe my front struts/shocks are bad.....so I am looking around at my options.
I don't want to change the ride height, I like it where it is. But I would like are more responsive suspension.
I have read that the SilverSport has a better (tighter) ride.
Does anyone know if the SilverSport struts will fit a regular RX?
Thanks inadvance, Tony
Old Apr 18, 2007 | 09:03 PM
Lexwang07's Avatar
Lexwang07
Registered User
http://www.tirerack.com/suspension/S...lar=&brand=all
These are very good struts and reduce some body rolls from stock RX300 SUV! I highly recommend!
Old Apr 19, 2007 | 11:39 AM
defo's Avatar
defo
That's funny, those are exactly what I was looking to purchase.
I can pick up all 4, for $365 shipped.
Have you or anyone else used them before?
Old Apr 19, 2007 | 12:30 PM
TunedRX300's Avatar
TunedRX300
KYB GR2 is RX's OEM struts, it is highly likely that KYB sells the same product for OEM and aftermarket markets.
Some report stiffer feel but new strut should have a different feel than a worn out one.
If you want better handling, just increase tire pressure. Many swore that Lexus recommendated PSI is only safe but fail to supply a single proven evident why increasing PSI below Max rating is not safe.
Each tire model is designed differently, how can one assume one PSI to fit all aftermarket tires, all driving style, and all road conditions?
Old Apr 19, 2007 | 01:57 PM
sgv_bum's Avatar
sgv_bum
Wink
i got the KYB on right now with tein s tech springs riding on 20" .. the ride feel good and smooth... you got yours 5 dollars cheaper then me lol .. i got these about yr ago for 368 shipped...
Old Apr 19, 2007 | 04:01 PM
defo's Avatar
defo
Mine are bad need replacement anyway, so the tire pressure deal does not matter. And I agree that new struts will automatically feel better.
What I'm trying to get info on, is the SilverSport RX.....Lexus claims it has different tuned struts (more sporty).
So, if KYB is truely the OEM struts, why can't I fine 2 different models? Can anyone confirm/deny this?
Since I have to buy new struts, so I want to see if I have any real options.
Old Apr 20, 2007 | 03:42 PM
TunedRX300's Avatar
TunedRX300
A while back, Ederny made a comment on his web site that SilverSport has bigger sway bar, but it turn out SilverSport has the same sway bar part # as the regular RX.
It could be dampering rate is different, another member reported KYB GR2 is 40% stiffer, but no one can confirm, the only way is to try it out.
Let us know how it turns out.
BTW, if you have FWD, you can get Teins coilover, they are expensive but I heard the ride worth every penny, lowered look w/o harsher ride. If I have a FWD and blown struts, I will get the Teins. Not saying KYB is not good, just Teins coilover is just a different class.
Old Apr 20, 2007 | 09:09 PM
miniround's Avatar
miniround
hmm...I've blown my BFGoodrich's up to 42 and had no problem. I'm still here, right?! It is a completely different ride. Those speed humps I used to fly over--well lets just say I had to creep over them as if I had a 4 inch drop and a body kit.
Old Apr 20, 2007 | 10:35 PM
TunedRX300's Avatar
TunedRX300
Do you have BFGoodrich G-FORCE T/A (KDWS) tires? If so what size.
defo,
I forgot that tires makes a big difference in handling. When I upgrade to Pirelli Scorpion Zero 235/60/18, I can cruise at least 10mph higher on a steep bank.
Wider stance also help handling, I have 25mm H&R wheel adaptor on all four corners. Not only my RX have wider track, my rear wheels are also flush with rear wheel fenders.
Old Apr 21, 2007 | 11:31 AM
defo's Avatar
defo
Thanks for the insight.....I think I will go with the KYB's since I have an AWD and I like my ground clearance....this SUV is for snowboarding trips and light off-road use, I'll keep the lowering to my other ride.
Old Apr 21, 2007 | 11:38 AM
defo's Avatar
defo
defo,
Wider stance also help handling, I have 25mm H&R wheel adaptor on all four corners. Not only my RX have wider track, my rear wheels are flush with the wheel fenders.
That's cool..... my intent is to get some 20's w/ scorpions. Do you have any pics?
lexslexus
Sep 12, 2017 04:52 PM
pimplux808
Suspension and Brakes
Nov 9, 2008 07:55 PM
AzNMpower
Jan 29, 2007 12:49 PM
eddied106
May 12, 2003 11:47 PM
satxrx
Feb 27, 2003 03:34 PM
