Think-design LED turn signal conversion kit
Old Feb 12, 2011 | 11:12 PM
RudeDoggy's Avatar
RudeDoggy
Default Think-design LED turn signal conversion kit
Hello CL,
I ordered the LED turn signal conversion kit from think-design.jp. Here is an example of what it should look like once installed:
http://www.youtube.com/watch?v=OEBs_XlLvZw
The only problem is that the instructions that were provided to me are in Japanese and I don't understand Japanese. I tried Google translate and I think I get the general gist of what needs to be done but some of it is getting lost in translation.
Does anyone understand Japanese and might be able to help me? I am having trouble understanding the steps on pages 4 and 5 specifically. Here is a link to the instructions: link
Any help would be greatly appreciated. I want to make sure I do this installation correctly but can't figure out what to do once I am able to locate the original relay under the dash (I am assuming that it will be under the left-hand side since we are LHD here in North America).
Thanks in advance!
Old Feb 13, 2011 | 11:05 AM
passnu2's Avatar
passnu2
looks to me like they are just showing you were to disconnect the OEM harness and install the PNP adapter. Since its PNP I cant imagine there is anything else you need to do. I would just use the pictures as reference to find were this plug is that you need to use.
Old Feb 13, 2011 | 11:30 AM
RudeDoggy's Avatar
RudeDoggy
That's exactly what I did. I just disconnected the original flasher relay and plugged in the aftermarket one. Good call.
Now to just figure out how to replace the front turn signal bulb (the manual says to contact a dealership )...
Thanks for the input!
Old Feb 13, 2011 | 11:54 AM
passnu2's Avatar
passnu2
I think I have one in the DIY thread. Its pretty easy to access, just take off those lovely black covers. Same process to get to the HID bulbs/.
Old Feb 13, 2011 | 12:06 PM
RudeDoggy's Avatar
RudeDoggy
I took off the circular cover that covers the light area (where the HID and turn signal bulbs are) and I tried to twist the light housing to un-click from the socket but maybe that is not the correct way to do this? Are there tabs that need to be pressed in or something?
Old Feb 13, 2011 | 12:22 PM
passnu2's Avatar
passnu2
it just twists off and pulls out. I found it easier to leave the OEM harness plugged in to twist it and pull it out.
Old Feb 13, 2011 | 12:33 PM
Jskyline's Avatar
Jskyline
Anyone notice the side mirror close itself when it locks? Wish someone can't figure out how to do that.
Old Feb 13, 2011 | 01:03 PM
RudeDoggy's Avatar
RudeDoggy
I'm a weakling apparently. I got everything installed and up and running. I am a happy camper.
Jskyline, yeah, that would be a pretty cool feature, although I could see it being an issue personally and wouldn't use it myself. e.g. You are parked very closely to another car or obstacle and when you unlock your door, the mirror extends, hitting the other car/obstacle. Kind of defeats the purpose of having folding mirrors.
But it does look pretty neat I must say.
Old Feb 13, 2011 | 08:31 PM
Stormforge's Avatar
Stormforge
executive matchup
maybe it's a jdm option?
Old Feb 14, 2011 | 04:12 AM
Lex Luga's Avatar
Lex Luga
How much is this kit in us dollars
Old Feb 14, 2011 | 04:19 AM
Lex Luga's Avatar
Lex Luga
also can you purchase the rear turn signals separately?
Old Feb 14, 2011 | 05:27 AM
gridlock13's Avatar
gridlock13
if you're parked that close, wouldn't it be impossible to open the door anyway?
Old Feb 14, 2011 | 10:19 PM
Lex Luga's Avatar
Lex Luga
Just converted the prices..for the 4 led winker bulbs plus relays its 226.32....ill pass...im guessing VLED will be cheaper.
Old Feb 15, 2011 | 08:40 AM
xxrap985xx's Avatar
xxrap985xx
I would really interested if someone could figure out how to get the Mirrors to Change on their own. Like the ls does
Old Jan 1, 2012 | 02:07 PM
ashley1977's Avatar
ashley1977
Hello CL,
Thanks in advance!
Hi I am interesting in this conversion kit too,
would you please let me know how I can order it from Japan and ship it to California?
Thank you!!
