Sponsored by: CARiD
Converting cornering lights into fog lights?
Old Jan 18, 2004 | 07:45 AM
buggsc3's Avatar
buggsc3
Question Converting cornering lights into fog lights?
Quoted from: http://www.intellexual.net
" Converting cornering lights into fog lights.
This modification is specifically for the 1992-1994 SC coupes, which came with cornering lamps instead of foglamps. Foglamps were introduced on 1995 production cars. "
Can someone please tell me, what cornering lights are and how do they differ from fogs?
Thank you.
Old Jan 18, 2004 | 07:50 AM
TimmyD's Avatar
TimmyD
They're under the headlights in the bottom of the bumper, where foglights would be on the newer sc's. They're extremely bright turn signals that work when the headlights are on.
Old Jan 18, 2004 | 07:57 AM
legendary's Avatar
legendary
Here are the differences:
This is the 97-2000 model version (fog lights only)
This is the 92-94 version (cornering lamps only)
This is the 95-96 version (fog lights only)
Moving to Lighting Discussion..
Old Jan 19, 2004 | 04:28 AM
BLK13X's Avatar
BLK13X
For Mind Cruising
Woowoo! That's my ride hehe... Anyway just to extend a bit, the cornering lights' purpose (found on the 92~94 SC's) is just that... to illuminate a corner (either left or right, relevant to the blinker position). They point out to the side unlike the 95~00 fog lights, which are purposely fitted as fog lights. Look closely at the second pic (92~94 SC) and you can see that on mine, the cornering light is on (bad pic though... it was shot in the afternoon) but the headlight's not, as the cornering lights (in my case) are wired to the parking lights.
Hope that helps you out a bit.
Jose
Old Feb 4, 2004 | 10:17 PM
lex400sc's Avatar
lex400sc
Cornering lights are dimmer in light output, but have a wider (localized) light spread. They only come on one at a time--left cornering light with left turn signal, and right with right.
Old Feb 8, 2004 | 11:19 AM
ummagawd's Avatar
ummagawd
and how does one go about converting the cornering lights into fogs?
Old Feb 10, 2004 | 04:47 PM
Lexkost's Avatar
Lexkost
I did it on my LS400 and it can be done on yours.
Old Feb 10, 2004 | 04:50 PM
Lexkost's Avatar
Lexkost
Here's another s pic showing all six bulbs at once .
Old Feb 10, 2004 | 05:07 PM
siniquezu's Avatar
siniquezu
Wire a spdt 12V bosch relay up to the low beam, battery, and the cornering lights.
Old Feb 10, 2004 | 11:39 PM
ummagawd's Avatar
ummagawd
gotcha
bmillham
Feb 25, 2016 01:29 PM
x2jzsc300x
Jul 14, 2013 04:28 PM
RafyIS300
IS - 1st Gen (2001-2005)
Jun 28, 2010 03:26 AM
TRD soarer
Dec 16, 2007 02:24 PM
Oleg400
Sep 18, 2007 09:50 AM
