Sponsored by: CARiD
My SC300 projects a V-pattern :(
Old Feb 8, 2004 | 02:04 AM
ummagawd's Avatar
ummagawd
Unhappy My SC300 projects a V-pattern :(
So i followed the steps of 96sc who did a HID conversion using the stock projectors...
I opened up my headlights and cut off the tab inside the projector and put everything back together...
while it looks like i have a great cutoff line against a wall... the projection onto the road/ground is V-pattern.... so there's a V of darkness and i can't see a thing directly in front of me. No i haven't tried to adjust the aiming (and yes the bubble is all the way forward) but i'm looking for any suggestions since i called it quits for the night...
any help is appreciated... thanks
Old Feb 8, 2004 | 11:22 AM
ummagawd's Avatar
ummagawd
also.... i noticed that when i put the headlights back in.... it doesn't sit as far in anymore... i have a small gap between the lining of the headlight and the fender... It doensn't sit flush anymore
am i missing something? I'm sure the headlights sealed back properly because I was able to put the clips back on... what else could it be?
any help would be greatly appreciated
Old Feb 8, 2004 | 02:42 PM
D2-AUTOSPORT's Avatar
D2-AUTOSPORT
Former Sponsor
Did you use a 9006 plug and play kit? Or did you just use sealer to wedge the bulb into the socket? I used to have M/B HIDs in my 96 GS and I had the same problem, it was caused by the bulb not being able to go all the way into the socket! Hope this helps
Old Feb 8, 2004 | 03:15 PM
ummagawd's Avatar
ummagawd
finally a response! thanks man
I'm using a D2S
well actually what i did was take out the 9006 ring via the 3 screws that hold it on... dremelled the bulb base a teeny bit to get it to sit flush... and then put the ring back on to keep it in place... looks really really OEM and factory IMO... so if anything it sits a teeny bit further in than a regular 9006 bulb.
Old Feb 8, 2004 | 06:09 PM
D2-AUTOSPORT
Former Sponsor
Dont know then man, I'm sorry but I'm no lighting pro! Is it possible that is too far IN?
Old Feb 8, 2004 | 10:22 PM
ummagawd's Avatar
ummagawd
that could be a possibility.... but then again a board member (96sc) did the same exact thing i did.... and he said everything turned out great?
so you used a 9006 adapter? and you just pushed it in more to get rid of the V?
Old Feb 8, 2004 | 11:24 PM
rominl's Avatar
rominl
exclusive matchup
oh man we need to sc expert here. i have never worked on the sc headlight before
Old Feb 9, 2004 | 12:55 AM
ummagawd's Avatar
ummagawd
yes we really need some onein here to help... i can't drive at night!
i tried to adjust everything (short of twisting around the bulb itself)
The more i played with the adjustments... the more i began to realize how the beam is projecting... each headlight is projecting a V pattern that doesn't overlap.... meaning the dark spot of one headightisn't being lit by the projection of the other headlight. Thus i just have a dark V in front of me.
Can someone chime in?
Old Feb 9, 2004 | 02:57 PM
siniquezu's Avatar
siniquezu
Very strange. This is the second time I've heard of this problem. The first being here:
https://www.clublexus.com/forums/sho...hlight=hid+tab
My guess would be that the bulb itself is pointed too low. The cutoff of the projector is only allowing the little light that is projecting above that cutoff. If you look at this picture:
you will notice that the cutoff looks like this:
----------------/---\____________________
The bulb may be pointed so low that it doesn't allow light to reach over the top bridge of the shield. This may be a result of either the aiming of the bulb or the bulb's base. But as I've said, I've only heard of this problem once before.
Old Feb 9, 2004 | 03:27 PM
ummagawd's Avatar
ummagawd
hmm... maybe i'll try to purposely aim the bulb higher, granted it will sit funny instead of flush now... but hey... whatever works
Old Feb 9, 2004 | 03:54 PM
Lexkost's Avatar
Lexkost
Default Re: My SC300 projects a V-pattern :(
Once you alter the headlight housing the bubble leveling is no good any more, you must do you own adjusting at a good flat area.
joeyfett
Jul 23, 2012 08:07 PM
acc
May 30, 2011 12:49 AM
lixster
Apr 5, 2010 06:59 PM
yov6cam
Lighting
Dec 23, 2007 12:30 PM
Levistey0
Lighting
31
Jun 5, 2007 11:24 PM
