- i neeed help!!!!!! electrical problems
- sc400 and ls400 autotransmission
- question?
- Serpentine Belt
- flowmaster custom exhaust, header, ingen air intake, NO CATS
- JDM Falcon exhaust for soarer
- water pumps
- gated shifter
- r154 1-2 shift problems
- Radiator Hose(s)
- anyone ever see this?
- Some info on our alternators (SC300)
- Electrical Diagram which represents the plugs on sc300, got one?
- Z32TT Vs. 2JZ-GTE SC
- medallion touring exhaust.
- Why is it so hard to find a VPC
- Coolant leak Help!
- I just got my 1jz clip!!
- Burns exhaust?
- 1jz missing at WOT
- heres my 1j swap so far.
- 1jz head part question
- EGR Tube interchangable on 95 SC400 & 95 LS400? Help Asap! Thanks
- What mods to get?
- found these headers
- power steering problems
- Boost pipe for single 2jzgte SC300? Any shops make it?
- anyone upgrade their fuel lines??
- ebay vs stock twins
- Fixing that dreaded door clip problem on an sc400
- does anyone make a ecu chip for sc400's?
- American V8 in a SC
- 1jz
- 1jz swap coming soon, whats the easiest 1j to swap.
- UR crank pulley belt
- s-afc..not really sure if i should get it.help???
- power ect not workin?
- heater hose leaking??
- IAT Sensor Location??
- A/C problem?
- 1jz injector...please help
- what motor do i have? need help
- MSD CDI Ignition Install?
- greddy emanage ultimate
- Question: Clattering sound while under load in 5spd SC300
- hey how much to go turbo?
- 2jzgte questions
- Want to do NA-T , need help
- is my MAF bad?
- 2jz-ge turbo help!
- MisFire during Acceleration - Assistance
- HELP!!!! Stalled in high water, what to do next?
- need a jic single exhaust pic...
- 2jz-gte swap guys need AC help
- need help plz urgent (Car dying)
- Engine Stall: 1995 SC4
- Air mix servomotor circuit (ac error code 41)
- 1jz question PLEASE READ!
- 1JZGTE, 1JZGTTE 2JZGTE, 2JZGTTE, 4 options HELP!!!
- Tremec TR-6060? Size of T-56 & Handles 650lb-ft tq, will it work?
- Anyone look into the Aisin AY-6 6spd tranny? Company that makes the R154
- What Is This Thing (on the Turbo)
- Clutch pedal question
- Oil in my coolant after 1JZ swap :(
- Bad gas or bad transmission ?? or something else...
- Safe Temp for running the twins
- what do u guys think of this engine?
- sc300 5spd vs supra 5 spd (clutch master cylinder)
- Has anybody ever taken out there intake and driven without it??
- Overdrive Light Flashes AFTER JDM 2jzgte -> USDM ECU Swap
- DIY Clear corner marker lights
- air intake heat shields
- 2jz single turbo
- Just recieved my motor today and have a few questions??
- White exhaust smoke
- removing heat shield???
- STRAiGhT EXhAUSTT?????
- safcii help
- 1.5jz swap
- A/C not blowing cold when car is not moving
- Stock mufflers
- Pro Boost Platinum performance module
- SC leaking fuel
- A hello and a code 71
- C.L. mem. has ques. about 90 Supra
- Weird things happening
- Ball Bearing Coolant lines
- I think there is something wrong with my Transmission
- Planning some mods
- My New SC's engine problem, Should I worry ?
- anyone remember the post about univeral toyota SC kits?
- Emission test woes...92 SC300
- Thermostat Prob.
- GE clutch/fan/shroud fit GTE
- How strong are the stock rear ends?
- R154 & W58 shifters
- Whipple Supercharger
- 97 SC300 w/USDM 2JZ-GTE and V160 <Speedometer Question?>
- Idle Speed Too Low
- 2jz-gte w/ a ge auto trans
- Valve job?
- Resonators?
- anyone heard of this turbo kit?...
- Radiator Question?
- Need LA Based SC300 Knowledge Assistance
- stock fuel pump
- crazy thoughts (Engine Swap)
- Does the SC have an A/C System Diagnostic Check? Come on FSM folks!
- 1jz / Greddy Profec B Spec Ii Info
- c.d. changer weight
- new fans! pics
- Short little exhaust video...
- my idle?
- What is my single 1J setup worth?
- sc 400 wont start
- Fuel Pump or Fuel Pump ECU?
- R154 Transmission question
- the big diff 300 vs 400
- Th400 in Sc300 1j
- Car breaking up!
- Is a sc400 97 tranny a direct swap with a 95 sc400 tranny??
- Resetting the ECU? Or do I need more fuel?
- Worst climate for boost?
- 1JZGTE SWAP into SC300
- Sc400
- Bee*R rev limiter installed pics and vid(it may be ricey, but darnit i love it)
- My SC just started bellowing out smoke; smells like gas
- AC conversion R12 to 134a
- My SC1JZ Project
- 2jzgte into sc300
- High Idle Speed @ 1000 rpms
- 5spd driveshaft Vs. Auto
- Engine Cover for 1992 SC4
- Battery Relocation Help
- who can wire up my harness?
- Leaking coolant from back of motor
- SC400 and LSD (limited slip differential)
- map ecu wiring diagram for odb1?
- Searching for a 1jzgte.
- oil filter location SC300?
- Ordering the motor but need some help...?
- What oil should I use?
- Pondering my intake setup
- Magnaflows
- Air Flow Meter
- Squealing noise from new clutch
- is there a trick to the fuel filter
- What's next on my 2jz-gte SC?
- MKIII Supra does 701 RWHP on stock 1JZ
- Oil Capacity in an sc300?
- Differential
- Catch Can Setups
- Air Conditioning redux
- needs help after 1jz swap
- 92' SC 300 Performance Help
- Driveshaft Guibo / Flex Joints / Bushings / rubber piece with 6 holes in it
- Bfi ???
- tach fix woot!
- My Mechanic Says Car Not Worth Fixing
- Filtration
- A/C Clutch Engages w/Relay jumped, Freon Level Good, Still not cold?? Ideas?
- Where is your idle?
- sc400 not starting in morning but easily starts later in day?
- Temp Gauge and Coolant
- Tranny question?
- Personal concern: Are lightened flywheels "loud" ??
- Supra Front Mount Intercooler Kit Fmic 1jz
- speed wire at cruise ecu
- Cooling system maint...
- Difffence between 7mge and 2jzge intake manifolds?
- Does anyone know if the SC300 and the first gen GS share the same tranny?
- Damaged SC400 engine; replacement / rebuilt recommendations
- Supra LSD
- 1j leaning out not reving well
- sc400 idling at 3k rpm
- started polishing my oem intake!
- What are the possibilities???
- Whats Wrong With My Sc400?
- Does this Lexus Dealership theory sound logical???
- Where is the fuel filter
- turbo question
- what i did this weekend......
- Got a question about 2jzgte
- cooling system
- which injectors?
- Any known problems with swapping in a JDM motor in our cars?
- JDM Racing motors
- Need Picture Of Soarer Harness Asap!!
- SC300 12v Fuel Mod w/ Pictures - FAQ
- Possible Blown Head Gasket?
- Motor mounts
- car studdering
- Grounding issue??????
- Which is SC4 is best for boosting?
- 1uz manifold on EBAY AREADY
- just put a 1.3 head gasket on, quick question
- motor mount question.
- Apexi SAFC2 and PHR radiator fans discontinued?
- Rough Idle ... looking for some help
- Local Tuning Shops.
- Sc400s post your 1/4 times
- Hyper Voltage System
- 98+ sc's suitable for performance mods?
- 300 Pumpkin into 400?
- Distibutor O-Ring Part (pic)
- What else can you remove from the engine bay?
- tranny
- The start of some V8 madness
- Trasmission Shift Solenoid #1
- odd clutch pedal problem!!! some insight please
- 95 SC400 hesitation ?
- NA-T & Miles
- Need Some Help
- Japanese harness diagram
- Magnaflow mufflers
- 2JZ-GTE swap to sc400 questions
- what 1jz motorset did I buy??????
- help, neutral safety bypass , no crank
- Dyno result of my 2JZ-GTE 6 speed SC300
- my 2JZ-GTE 6 speed SC300 Dyno result
- cleaning iacv
- getting engine code read
- TPS sensor Zex kit
- 1JZ-GTE gasket kits
- some vaccum issue during 1jz swap, help
- yea....i did it guys.
- Pulling as much Power out of the 1UZ-FE as possible
- Coolant in Spark Plug valley
- Question about fuses/relays
- starting problem
- Rebuilding a W58
- buying my husbands gift
- ??? bout thevsafc from MRS. T70 supra
- exhaust fitment
- Dave H LSD kit??
- clearance ?
- why wont the mkiii 1jz downpipe work???
- So is it a grounding issue or... What do you think?
- Catalytic converter replacement issues, in need of advice
- help with oil leak
- Rear end ?'s
- r154 drive shaft issue, mk3 front won't fit
- sc400 plug wires ?
- Need some help from anyone
- 1jzgte downpipe mk3 vs jzz30
- transmission starts in second gear need help!
- Can't Put It In Gear
- im shootin for 1000 hp on the stock ge block, wanna see whats next? (pic)
- help please read!! 1jz swap!!
- Timing belt replacment...
