- Need a little help with the vpc/safcII/gcc combo
- Exploded Diagram of MK3 Supra Transmission - Slave Cylinder
- ~ Failed functional check - No vac signal to EGR ~
- need help asap, electrical issues inside!
- Slow acceleration with Lextreme TC
- Fuel line sizing(Urgent help)
- MK4 n/a and SC300 differential drain bolt the same?
- tranny surging issue?? 92 sc400
- My Koyo Radiator Experience (semi-DIY)
- ~ Can I pass smog with C16 fuel? ~
- Crank bolt removal suggestions..
- Engine oil, A/F ratio paranoia?
- Thicker oil to use to prevent oil leak?
- HP gains with bolt-ons
- Throwing MAF codes....
- Wiring Diagram resources
- quick sc question
- check engine light goes on and off now and again.
- T3 Super 60 / F1-49 .48 A/R yay or nay?
- screeching engine
- ABS in 1jz jdm ecu swap???
- Shifter Problem
- So when an ECU goes bad, what exactly goes bad?
- Motor Mounts Options
- A/C problems need help
- power steering h/p hose
- Oil Return Line
- 1jz ?
- Car radio won't work.
- SC400 Headers?
- 2JZGTE Swap
- SC300 Driveshaft!! HELP ASAP
- ati crank damper part # ??
- low idle
- Problem Changing Fuel Injectors?? Help?
- 2JZGTE swao
- Transmission fill bolt?
- The Definitive SC400 Exhaust Guide
- 1996 Lexus SC300 VVTi frozen
- synthetic vs engine seals..
- error code 13?
- Intermittent hesitation
- is there an exhaust that is similar to the Greddy MX's?
- Stripped differential bolt!!!!!!!!!!!!!
- Other Auto Transmission Options For The 2J ???
- So Stuck!!
- Exhaust Question
- Having THE worse time remove "Y" intake
- How to check codes from CEL?
- 1jz misfiring
- 1JZGTE ISSUEs
- Selected N/A Turbo Choice
- Maintenance check before a long drive.
- For the 1JZ guys, What clutch?
- Ecu
- Another "Clutch recomnendation" thread for my R154
- Fan pump screw up
- Car randomly dies, then acts like its out of gas
- Car wont start after battery died.
- resonator location?
- All hail the mighty...1JZGTE
- upper control arm install
- Code P0430
- Any TT SMIC users?
- Need a good source for ACT Clutch Kits
- Is it just me or does my exhaust sound like a VW MKIV R32?
- Is this fixable?
- Help! climate control stoped working
- soarer cluster in sc300
- Auto solenoid
- what are symptoms of bad mounts?
- Motor Mount Replacement?
- Starting problem
- which downpipe would work best?
- poor M.P.G.s on SC400 today
- Seafoamed 95 SC4 thru PCV-Does this clean both banks of cyl?
- Speed sensor question
- Ideal Turbo and Intake for my SC 300?
- JKBHEAT's BFI build
- My BFI DIY attempt
- wiring
- annoying intermittent 1JZ issue
- need A 92 sc300 ignition key housin plastic cap
- cruise control broken
- Has anybody used p/s stop leak
- Car Bogs unless MAF is unplugged... Help
- 1jz auto tranny fit 2jzge?
- 2jzgze
- really need help
- Trunk w/out master key
- Another starting issue!!!
- transmission upgrade ?s
- turbo coolant feed and return question
- Transmission Drain Plug
- Recent problems with my 1UZ
- Low Ignition Coil reading?
- Drivers side valve cover
- ANY MECHANICS in CHARLESTON, SC???
- Can an IS300 transmission be swapped into an SC300?
- Fan Clutch question
- SC4 Sometimes wont start - electrical gremlins
- precision turbo question
- P/s rack problem
- timing belt question
- 1jzgte R154 swap 1997 SC300
- Sudden rough idle & loss of power
- service repair manuals?
- MK3 Supra pedals and clutch slave into SC?
- 93 SC400 O2 Sensor codes 27 & 29
- Budget Turbo kit for a 2jzgte
- 1995 SC400 engine type?
- 1jz/2jz jdm swap ABS and trac control ?'s
- MAP ECU2 vs Emanage Ultimate
- Aristo swapped Sc300 with speed cut@100 mph....
- Tired of Searching: 1JZ Auto
- Project Car: OneOfThem1JZSwapsWithTheJayDeEm
- *JDM Engine Sources*
- another coil pack question
- Best intercooler pipping method
- Schematics for Lower Crank Pulley removal
- Blitz Dual drive BOV
- new exhaust?
- MKIV Apexi N1 -> SC300 question
- Auto flex plate installation...which side out?
- Change Differential Oil, and found a surprise
- Need help 95 sc300
- what kinda hp on your sc3/4?
- Tranny swap!
- Blow off without being under a load?
- Do these look like the correct differential plugs?
- Resonators
- Stripped Nut
- Turbo Timer: NA-T and TT Guys Come In
- Oil change question
- walboro wiring kit gauge size?
- 1jz ecu wiring placement
- Aem wideband controller ?'s
- Sticking in Overdrive
- Bfi
- changed alternator & battery still losing power
- Bfi for sale?
- Radiator Help
- Replacing Rear Wheel Bearings
- 1JZ swap
- 1uz starting issues
- Sc400 lsd
- Need Help..SC400 R154 Swap
- hks or oem timing belt
- SC 300 gas pedal sticking?
- Out with the old, In with the new
- E-Manage Ultimate and Turbonetics Boost Controller... how much is it worth?
- which driveshaft or am i stupid?
- Sc300 Side Mirrors
- Calling all manual SC's
- whats the best rear end ratio for my swap??
- Removal of the side view mirrors DIY (56k ouch!)
- Pulleys for 1JZ
- SC400 engine swap with a Tuindra motor
- Which alternator for a 95 sc300? 5 3/8 or 4 7/8 diamiter
- Tech2 shifter extension experiences
- Just one of those days..... ARRRRgh
- 1jz ac compresser ?'s
- days away from headers..any advice or objections?
- Anyone use this tool?
- 1jz power steering ?s
- r154 shifter extension for 95up sc300
- Tune up item priority?
- 1jz Power steering placement
- 1jz altenator ?'s
- what is needed to convert aristo water pump to USDM
- vpc for sc400
- need help sc4 trans problem
- Yet another Intake question..
- WTF is THIS??
- steering problem
- 1jz WOT sputter
- Compound Turbo 2JZ!!
- SC Exhaust Thread
- About to do a tune, what else should I get?
- 1999 SC300 transmission code clarification
- Exhaust System?
- ehaust?
- Clean your IACV - Idle Air Control Valve
- GS300 2JZ comared to SC300 2JZ
- Bad missing, stalling, smoke Oh My!
- Time for a stupid question!
- hks exhaust
- v160 swap
- Failed NOx emissions 4 times!
- tranny question
- Fuel pump problem on '92 SC400
- sc400/2jzgte wiring diagram
- 1995 SC400 motor mount part #
- Soarer Shifter Extension question
- Oil Level Question
- Some upgrades in the works....
- Fuel Pressue Regulator
- So the gas filter is rusted on the line..what to do?
- were is the telescopic motor????
- 1JZ... 2JZ... Jay-Z ... huh?
- Turn the key and the entire car goes dead.
- A/C Leak (Freaking Somewhere)
- w58 vs r154?
- clutch pedal broke= no car for days
- How much does it cost to fix an oil leak?
- wat is the best exhaust for 1uze
- Rust in the Radiator?
- car over heats
- strange sounds from tranny:(
- Please help A/C problems. URGENT.
- My aristo/Sc300 base dyno
- LSD ?'s
- No Overdrive, No codes, No redline
- How to replace rubber door boot
- Setting the timing on a 1999 SC300??
- car smells lean...
- Performance Problem
- Key will not come out
- 1jz blow off valve help needed
- What could this problem be?
- Air Bag light on!
- telescopic motor ????
- Soarer 1jz swap in sc300?
- Recharge...
- Actuated Exhaust cutouts
- Auto trans not kicking down
- SAFC for a 1999 SC400 with no Cats have questions !
- Transmission Question
- RMM exhaust for GS400?
- HELP! Air Fow Meter Signal?
- removing trac. comtrol & cruise
- Got my snail today
- soarer stock auto?
- SC300 Fuel Plumbing
- 92 sc400 obd code 27,29 after new cats. help
- FINALLY GETTING IT DONE Going 1JZ single!
- Price range on a/c compressor replacement?
- sc400 engine help
- UGhhh No power Sputter..SC3
- Coolant/Radiator Problem
- Broken Trans or broken diff?
- sensor ground and chasis ground
- help with telescopic motor replacement
- Engine Issue??
- just lost my job and now car finally acting up...WTF!
- Tire Wear Dilemma
- Rounded crank bolt, Any advice?
- need advice on sc300 auto swap
- Fuel system advice... 42r 1000cc a1000 etc.
