Car wont start after battery died.
Old 06-09-09, 10:07 PM
Stevens226
Stevens226's Avatar
Default Car wont start after battery died.
So i was at work and left my key in the ingnition and turned to the right while i was at work for 8 hours. i come back and notice this and my battery is dead. so i have a guy come use his jump box and he was dumb i think and would not listen to me when i tried to tell him that he was putting neg on pos and pos on neg. after a second of him trying and it not working and me yelling at him he switched it and noticed he was wrong. after that we had it all hooked up right and lights worked and the dash light worked showing my door was open. but nothing else would work. try to lock/unlock the door just hear a click from the left of the steering wheel but doors would not lock. tried to roll window down didnt work. car wont crank and all that works is lights. headlights work the lights by my feet work dash light works but nothing else. car wont start and idk what to do.... anyone plz help need to try and get this fixed asap.
Old 06-09-09, 10:19 PM
Ryeno
Banned
Ryeno's Avatar
have u checked to see if you blew any fuses. IDK if this is possible but you might have fried some boards when the voltage went the wrong way.
Old 06-09-09, 10:21 PM
KrazeMatik
KrazeMatik's Avatar
yea better check your fuses!
Old 06-09-09, 10:26 PM
Stevens226
Stevens226's Avatar
ya thats what i figured but i didnt have my owners manual and could not find a fuse box diagram. also have no idea what fuse would do that or how to test the fuses that u cant see if there blown.
Old 06-09-09, 10:27 PM
Stevens226
Stevens226's Avatar
anyone have any idea on what fuse it might b and where it is?
Old 06-09-09, 11:17 PM
boostin300
boostin300's Avatar
You dont need a fuse diagram to replace fuses. Reason being, you want all your stuff to work, ie you want all your fuses to not be broken.
Get some needle-nose pliers or equivalent and pull them out and replace if bad one at a time. Theyre see-through, basically if they're blown the wire inside will not be constant, the wire will be 2 pieces and wont be making a connection. Just replace the bad ones this way, Id hit up autozone to buy them all. or whatever auto store you're around.
Old 06-10-09, 02:26 PM
Stevens226
Stevens226's Avatar
Found my 105A fuse was blown. Would this cause the car to not start since it is for the alternator even tho I had jumper cables hooked on from another car?
Old 06-11-09, 05:46 PM
Stevens226
Stevens226's Avatar
sry 150A fuse that says "Alt" guessing this means alternator. Would this cause my car to not start?
Old 06-11-09, 07:23 PM
topdog849
topdog849's Avatar
yes its will cause your car not to start, i know from personal experience. and chances are the replacement fuse you have to buy wont be a perfect fit. your going to need a dremeling tool to grind the middle of the fuse legs to match the one that blew. or you can buy the oem fuse from the stealership
Old 06-15-09, 11:26 PM
Stevens226
Stevens226's Avatar
Ya I bought the new 150a fuse from lexus took a day to get ordered but $19.13 later my car runs perfect again besides the radio still won't work and it blows fuses every time I put 1 in.
Old 06-16-09, 11:21 PM
topdog849
topdog849's Avatar
whatever you do dont replace the radio fuse with a high amp, youll be asking for burning wires, harnesses, and magic white smoke
JamesGS
12-01-17 12:19 PM
PlotPoint
11-16-14 09:49 PM
BenjiB707
09-22-14 04:43 AM
Redfire03
04-05-10 05:49 AM
acenase
SC- 1st Gen (1992-2000)
04-02-07 10:19 PM
Quick Reply: Car wont start after battery died.
