Thicker oil to use to prevent oil leak?
I was just wondering if anyone could recommend some thicker oil than 5w30 that wont leak as much with a small oil leak from the front main seal? right now with 5w30 the oil will drip like water when the car is running. but when the car is off, it doesn't leak. so i was just wondering what thicker oils out there so when the car runs it won't drip like water.
the stock oil is 5w30.in the manual it also says you can use 10w30 i'm sure you can use some thicker oils but you have to be aware of the temperature.i just switched to 10w30 but when the cold wheather returns i'll be going back to 5w30.
The oil is dripping from the front main seal. But only drips when the car is running (oil becomes thinner when hot) so thats why it doesn't leak when the car is off since the oil is cold and is much thicker.
I have 5w30 in there right now and it doesn't leak when it's cold but when it runs it leaks, so maybe I need to switch to 5w20? and see if it still drips?
bdpride04
10-31-17 12:59 PM
