- Question about Turbo...
- Need help with Ac clutch or compressor...
- engine rebuild
- 98+ shifter plate
- If I drive with this "stuttering/sputtering" can I make anything worse?
- Adjusting a TPS by hand?
- cr with gte pistons, na hg? TT hg?
- Tapping into Tial BOV for Boost gauge reading?
- sc300 midpipe lenght?
- Universal ecu for...Well, everything?
- Need HELP with new noise!
- need help in south florida
- battery light problems!!!!!! help please!!!
- Fake Greddy BOV
- question 2jzgte vvti aftermarket intake mani, 90mm tb
- R12 a/c service still available?
- Weird tranny?
- Best engine cleaning oil!?
- Where to buy a new decently priced MAF and TPS
- Bad O2 Sensors causing 92 SC to have NO real power?
- Misfiring after swapping OEM wires? Possible Solution
- need help with ac problem!!!
- Oil catch can setups
- Alarm Question
- Sc400 bad accelerating stalls/dies when Car is warmed up
- side mirror fuse
- my "HELP ME C.L."thread
- clutch driven cooling on sc
- Bucking/surging at around 40 MPH
- funny problem (car dies after doing donuts)
- 1995 Lexus SC400 lurching on acceleration
- HELP! Disable or remove Door chime??
- This guy says an auto trans driveshaft works on r154??
- A340LE code 67
- AEM digital Gauges lens
- does taking cats off give you worse gas mileage?
- Radiator leak
- gs300 intercooler piping on sc300
- 1jzgte no start/spark - has power at engine fuse box
- 1997 SC400 Stalling Issues
- Clutch failure.
- A/C compressor won't turn on.
- 93 SC400 Accelerating Issues
- Converting from *.amr format so the Forum can hear my new noise
- Special order intake gasket?
- SC400 Distributor Noise
- random misfire driving me crazy!!! lol
- Exhaust/Gas in Cabin
- Electrical Problem??
- 92 sc400 power steering questions after search
- Are these ebay HKS BOV real?
- Expansion valve Identity Crisis!
- 1jz vvti wireing question
- Engine knock sensor PLEASE HELP!!!
- ABS lite stays on
- Denso 471-1150 vs. 471-1215 compressor
- TT 550's on an AEM question
- wont go past 2k rpm??? im lost
- Oddest check engine light issue ever.......
- Is my regulator or IAC going bad?
- 1JZ (or 2JZGTE) basic wiring question (searched)
- Rear combo light
- q45 throttle body wiring for sc300
- Opinions on an Engine problem
- Air Conditioning drain issue
- Capacity of 1993 AC Condensor
- My ongoing Sc400 Issues :(
- Overheating - water pump replacement question
- 92 SC 400 Ecu Kickdown "Mod"
- annoying whining sound from front of the engine!!
- engine light...smh
- Dropping in the 1j right now quick ??
- my 95sc400 CA smog test 2011 and 2012 numbers got better after mods
- Best oil for the SC400's?
- 1uz r154 pilot bearing p/n
- 94 SC400 idle
- Fuel Filter Advice needed ASAP
- 93 sc300 na-t *iacv wiring*
- V160 -> UZ Revisited
- 4 runner cap and rotor
- R154 front drive shaft
- R154 Shifter Extension Play after BC parts install
- shift knob help
- Which new compressor for 92 r12 or r134a
- Can the turbo front housing be rotated?
- how to remove ac condenser 99 sc300??
- AC poopy-ed the bed, and it's summer in las vegas
- Ignition problems
- help
- oil change help
- JDM Soarer Digital Dash
- Heater not working...help
- Need help, IACV wiring harness shattered
- Hello everyone, w56 swap questions.
- SC300 battery drain issue
- front upper control arms
- Clunking noise
- What T3 single turbo manifolds are 1JZ owners using?
- How much power can a Competition clutch Stage 3 clutch??
- GTE 6spd a (sc400 or get a sc300)?
- Supercharging SC 400?
- '99 SC400 CEL and other problems.
- show me your hose!!
- Idle Issue with history and questions
- Fuel Pulsation Damper SC400
- Replace Valve Cover Gaskets + Lots More DIY
- soarer 1jz vvti swap questions
- low idle
- 2jzgte wont crank
- Transmission Problem: No Reverse or Neutral
- sc300 downpipe exhaust leak help
- New 2JZGTE Complete Harness?
- need advice on choosing a route.
- Climate control and radio not working
- wastegate sizing and manifold connection
- Dumb question.
- 2jzgte map ecu
- 1jzgte people come here!!! problem eith tranny mount!!
- 93 sc400 help!!
- My Lexus SC400
- Fuel Pump Not Getting Power
- 1JZ swap/SC400 A/C not kicking on
- Another AC problem.
- Need help with selecting headers for 1UZ
- TRAC light on and TRAC OFF light on...HELP!?
- 92 SC400 Loss Of Power & Unidentified Leak *PIC*
- Rough Idle IACV Idle Air Control Valve
- 1j crank walk
- 93 sc300 na-t *No overdrive* need help
- 1jzgte bov?
- need some help my lexus friends.
- Tachometer Capacitors SC400 vsSC300
- obd2 TT ecu on na-t
- clutch pedal question for the pros
- auto-tune
- What to recharge ky my a/c with?
- Powersteering pump re-seal
- 1/2JZ w/ 350/370Z tranmisson
- Tach tachometer V8 to I6 potentiometer calibration
- 1jz breaking up at 2k rpm
- What would make my shifter shake?
- The Repair Riddle that has stumped a Lexus technician for 3 weeks…
- MK3 Supra Turbo auto trans + 1UZ??
- Ac questions for sc300 r12 vs 134a compressor
- Starting problem out of no where?
- 2jzgte swap questions
- wheeling hopping why???
- BFI Question.
- Rack Spacers ?
- Rough Engine Idle and Stall
- Oil restriction on 1JZ PT6765?
- Charcoal Canister Part Identification
- Could a bad fuel pump ecu cause the engine to misfire?
- 1UZ engine gasket kit
- Remanufactured Denso starters
- 1UZ knock sensors
- 98 VVTI cams ?
- Little help please with Crank Pulley!
- clutch pedal box
- Flashing/Blinking TRAC Off Light help?
- DIY: How to not strip 2jz headbolts, how to fix it if you do, and removing your crank
- 1UZ limits?
- 4.7L Truck headers on 92 SC400?
- Misfiring under heavy load!!
- 1jz idle/running issues
- is300 cooling fan setup ?
- 10 hole vs 11 hole waterpump sc300
- What line?
- 1jz swap CEL 12
- Hydraulic Actuator
- FMIC w/ IC?
- where to find right hand distributor housing
- Fan on ac condensor
- What is the fluid the brown fluid that comes out bottom of SC400 radiator?
- 92 sc400 ignition problems
- STP Multipurpose Motor Treatment - TRY IT!!!
- 1jz starter/vacuum problem
- Help please!! (smoke at startup)
- Odds of both coils going bad at once? Ohms measured and reported
- Replacing the starter? Other parts?
- 215 70 15
- driftmotion 60-1 turbo - whats its name?
- 2JZGTE idle low, rich, A/F read 12.5
- Few concerns going to run single 1JZ with auto trans
- A341E Solenoid diagram
- Conflicting reports? What model tranny does the stock 92 sc 400 have?
- Oil in a blown SC
- SC 400 transmission model location?
- past experiences on exhaust set up
- 1JZ with 440cc inj. + E85
- Found that exhaust leak
- 95 Sc400 Check Engine Light
- What solenoids do I need
- 350z 6speed tranny on a sc?????
- sc 400 misfiring
- aristo intake manifold
- Easy bolt on horsepower?
- Turbo kit on my 2jz ge?
- Drive Belt Tensioner question
- what else could it be?
- What could this problem be? 92 sc 400
- Wiring Help: Headlight Circuit not working
- Craigs list R154 trans ?
- Quicksilver manifold, suprastore??
- I need help wiring this, take a look
- Opinions on this K&N intake for a '94 SC400 please?
- Tanabe exhaust w/removed resonator?
- Most exotic sounding exhaust?
- My 92 SC 400, Transmisison issue??
- sc300 with a stumble. RPM's up and down?
- sorry another catalytic converter question
- Who has replaced their cats?
- starting issue
- I need a valve
- **nitrous help please**
- Stalled at 60 mph/turn swtch only on n off a few times and it starts..
- Power Steering Fluid versus ATF
- Need help identifying this part on the 1UZ
- Am I missing part of my Fuel Pressure Regulator?
- Dome light doesn't work...
- P/N for SC300 PS Bearing?
- Are Silla radiators any good?
- 1jz Head removal tips?
- Emanage ultimate noob questions (o2,map)
- im lost, code 31, 52 trac off
- FINALLY - won't start - RESOLVED
- Odd power steering issue
- Help me identify this subframe/diff (please)
- How does my timing belt look?
- Injectors Constant make Zapping Noise
- Steering Damper Question...
- Exhaust Guidance.
- 4" dp fitment
- 1jz map sensor voltage
- Tranny rebuild?
- Sc 1j clutch questions
- Is there an easier way to reset CEL and pull codes
- 1UZ Automatic tranny options?
- need help or link on how to set ignition timing
- launching
- sc300 1jz project help
- please help!!!! sc300 shaking over 60mph
- Cam and crank seals
- 1jz oil pump sensor leak
- rack and pinion leak
- ac compressor gray plug
- 4.27 auto with overdrive max mph?
- '97 sc300 w58 swap emissions help, need ecu pinout
- help me! quick valve question
