- Best place to get a 2JZGTE?
- Need help! Supra tt auto LSD
- 1JZ 101 for dummies
- Max hp on factory fuel lines?
- Q45 beech tps adapter help
- GE NA-T correct MAF placement?
- OEM Ignition coils for 3.63$~ can this be real? Will these work on my Sc400?
- Hesitation above 5K RPMs?
- Anyone Heard of Phoenix Power?
- SC4 and GS4 tranny mount the same?
- Electrical Issues with my 97 SC300! Won't start.
- Where Are You Buying 1UZFE Tune-Up Parts? What are you using?
- 2jzge MAF blow through?
- Help! Braking/Dash problem, car feels weird!
- Sticky Clutch Problem after replacing
- w59 transmission on sc300?
- 1000cc injectors
- time to re do my exhaust...HELP!!!
- soarer r154 leak
- PLEASE help! gotta get my sc running ASAP!
- Fuel leak
- Need help with car
- A/C Light blinking
- sc4 power steering removal
- Hard shifts from park to drive
- will it work?
- How to tighten and lock Metal cable ties?
- Tuning /maintenance help?!?
- Take a look at my frayed timing belt.
- Distributor screws - do not remove
- Need help quickly!!!
- HELP Code 78 Sc300
- ??Broken exhaust thread questions??
- Turbo coolant fitting blew
- 1jzgte Soarer Swap into 1992 SC300 Wiring issues...
- sc300 rear diff ?lsd
- Drive shaft questions
- injecter not getting signal no fire
- Aluminum Radiator
- Gas tank pressure
- Universal Intercooler and piping for 1jzgte in sc300 HELP PLEASE!
- W58 Transmission Filll Bolt
- drivetrain vibration solved...well i hope so anyways, video inside.
- Project going down hill :( help
- gated shifter linkage
- LSD needed?
- Vacuum question, tried search, no help :(
- Desperate plea for help
- Clearly this air filter is too small...?
- What is the purpose of an X-pipe ?
- Key and starter won't turn on car? No accessory/fuel pump.
- headlight parking light housing, painting??
- supercharged 2jz??
- Any southwest Florida folks here?
- IS300 lower plenum same as SC?
- Differential Fluid Leak??
- Lexus dealer tranny advice!
- Need advice
- need N/A 2jz cooling diagrams, OR help flushing heater core
- 1UZ experts, I need help!
- 98 SC400 Rush Headers =need quite exhaust??
- 1jz single turbo
- 92 SC300 w58 driveshaft length?!
- Cams cap and head scoring
- SC4 Fly by wire to cable conversion?
- SC400 to SC300
- Koyo Radiator install into SC300 5-speed
- 1JZ hks SSQV Adapter
- Another injector resistor thread!!!
- Some Exhaust questions
- Couple newb questions-engine oil type, trans fluid, temp issue
- Miss fire plus now wont start! HELP!!!
- Battery light doing the harlem shake
- tight oil filter
- Need a Guru's advice; SC400 Problem!!!
- I know the search rules but i need heater help
- Is this a soarer 1JZ?
- Will Someone Explain???
- FFIM question
- 1998 sc300 tan airbag want to buy!!!
- Exhaust leak
- There's engine in my rack? Or rack in my engine?
- Code 55 Aristo ECU
- sc300 high idle and clutch squeak
- Fuel level sensor affecting performance
- 1zj swap problem
- Fuel pump issue???
- Quick question for 97 Tach fix with GTE swap
- Need Help Removing Power Steering Pulley
- 1992 W58 5 Speed Conversion.
- Tranny swap Question
- Lets talk intake manifold...
- Bypass fp ecu
- Converting fan system from hydraulic to electric? Pulley found!
- Coolant Drain and fill Question
- 1992 SC400, instrument cluster stays
- Is there any way to tell if timing belt was done?
- Sc300 1996 low idle?
- I need some advice on an Ebay Turbo kit
- Anyone currently installing an r154
- WTB 1JZ psteering pump replacement
- Failed HARD
- Connector Part Numbers
- Manual SC300 idling a little off
- How do you tell if it is a Soarer 1jzgte as opposed to another rear sump 1jz?
- Manual swap 96 sc300 now check engine light. Ecu questions
- powersteering pump or rack and pinion
- So who here is running the ACT Extreme Clutch on their R154?
- chasing this random multiple misfire problem....
- T56 trans adaptor to 1jz auto bell housing..
- More 2JZ vvti wiring questions
- stock idle on sc400?
- HELP!!!! Unknown Clutch/Trans Noise
- 2jzge w/ 2jzge harness w/ Aristo ECU w/ 2jzgte FFIM TPS Idle problems
- stainless works mufflers?
- Bad wastegate? car wont boost over 10 psi
- CXRacing Turbo Manifold = Junk. Does not fit.
- how to wire 97+ gauge cluster into pre97 sc300?
- *Internet Find* SC600 Twin turbo LS
- Idle Problem-Video
- OEM gasket on Na-t manifold
- Clutch kit hardware
- Should I Pull The Engine?
- Na-t is go...
- Front o2 sensor for aristo swap?
- Sc400 maf adapter questions
- What should I know before buying this SC400
- Turbo Application + DD Reliability
- New MAF?
- 1JZ won't warm up
- General Motor Swap Related Questions
- Engine Running Slightly Hot Following T-Belt Replacement
- 2jzgte what do I need to go single turbo
- Increased valve body pressure
- Csm059
- 1998 SC400 long tube headers fitment ?
- Fuel Leak
- Help with supercharging my SC400
- Sc400 M2 performance mufflers
- fuel filter question on SC400
- Gated Shifter Question
- Soarer R154 questions
- 1JZ Intake Manifold Question!
- Fuel System Emergency. Please Help
- Interior fuse box compatibility
- Ralco rz underdrive pulleys
- question on mbc and hks style wastegate
- SC300/400 Body Exterior Detail Improvement
- TT iacv flange size
- Spark plug blow out
- Fuel leak?!
- Tt ecu on obd2 car
- 1994 sc300 code 12 RPM signal no. 1
- Fuel pump; car wont turn over
- 1JZ Single Turbo - Throttle Hiccups & Hard Starts
- Florida need mech
- Holset Hx52 Questions
- Window goes down not up
- Leaking Distributor Repair
- Fuel Pump / Sending Unit
- SC300 driveshaft question
- Sc400 won't crank after tranny replacement!
- 1jz NO BOOST???
- Stock Radio Intermittent??
- Going na-t
- 1uz into sc300 questions
- What are my best economical exhaust options if smog/inspection is of no concern?
- 1jz wastegate fitting line
- Weird power steering leak during tranny replacement
- Oil Pressure Sensor
- 2003 GS300 rear Brakes
- 5-Speed Flex Coupling
- Repeated Power Steering Failure
- Down pipe fabrication question.
- starters
- Broken Tripod... R154
- What size fitting do I need for a feed on a gte block?
- po 430 pls help tell witch o2 it is.
- new here need help swap manual trans. sc400
- Garrett gt35 vs precision 6265
- Replace Wheel Bearing or the Entire Hub?
- help
- Coolant Leask streaming from right side engine, near PS pump
- Bad gas mileage (another gas thread.......)
- 1992 5 Factory 5 Speed SC 1jzgte conversion HELP PLEASE!!!
- 1994 sc300 alternator problem?
- sc400 1JZ or 1JZ-GTE
- 1jz-gte
- Lexus SC400 (1994) Shakes/Misfires/Backfires: Continued
- Smog legal 1UZ mods?
- overdrive issue
- which cams
- GE/GTE Harness Wiring!!!
- Sc400 Performance choice for the time being
- Heater Control Valve Repair
- JDM Engine swap and Cali emissions?
- Hiccup after sc3 spark plug change
- Help with hiccup at random RPM's Sc300
- Which is easier?
- Weird issue...do i have a different diff?
- sc300 burning clutch?
- Specific questions before DIY transmission R&R
- Tial 50mm blow-off valve or HKS SSQV (old model)
- SC400 Cat Delete pipes
- 1JZ single turboo swap - hose questions
- HELP! ECU problem?
- wiring issues? How to check?
- Help me identify where this noise is coming from
- performance upgrades
- Replacing PS Pump in a 97 SC300
- Quick question
- A little help will be appreciated. Serpentine belt, etc...
- Just Dropped Off My Lexi At A Shop :/
- Need engine builders advice
- oil pressure switch
- sc300 help
- Supra cam ?
- 1jz resistor pack/afc problem. Please help!
- Quick crank pulley question
- TPS adapter HELP??
- 4" downpipe or 3" downpipe on a BW s366
- The Manual SC400 Swap, SMOG
- 1jzgte where can I get these coolant sensors new?
- What is the ohm range of our sending units?//Where do I get oil pressure on the block
- Fan Clutch Replacement
- 1JZ Valve Cover material
- Main Relay
- Instrument Cluster..removal easy...But the wires ????
- 92 SC300 Need info on doing the timing
- Broke oil feed line need quck fix
- Need help with codes P0441 & P0446
- 1jz wiring help
- Totally Lost / Please help
- Which Spark Plugs should I get for my SC300?
- Four-Wheel Steering, and TEMS?
- SC300 overheating - Radiator empty, steaming from engine
- Aftermarket Aisin Water Pump SC400
- Replacement Cam & Crank Seals SC400
- What are 1992 SC300 Stock Spark Plugs?
- Aluminum Radiator
- Noob with lots of Questions
- Na-T Project
- Just found my old multimeter!
- NA-T Your Thoughts!
- Fuel vapor canister replacement..need cheap substitute
- Lets discuss missing
- Getting resistance on maf
- Where are the pro know it all SC300 5 speed people?
- Xerd/Mvp Header Or Obx For N/A?
- 1992 lexus sc400 transmission swap
