- 2010-2012 aftermarket front grille
- Air temp when in vent
- Non-OEM coolant brand?
- Cooling fan last year, now radiator?
- How to remove Drive shaft
- Ongoing issues with 2010 Lexus RX
- Key fobs intermittent
- Clearing eDestination Icons
- trac off and check engine light
- small wire on positive battery cable
- CV Axle driver side
- new Rx450h owner with personalization questions
- Upgrading Regular blinker to Tap Turn/Tap switch 2014 RX450h
- Has anyone replaced the sun visor?
- Considering Purchase of 2010 RX350
- Navigation screen is just white and flashing
- 2015 Lexus RX350 Front End Squeak
- Factory tow package?
- LED Headlight Conversion...
- Headlight Issue
- Intermittent Starting Problems -2011 rx350
- Radio and Climate Control Unresponsive.
- Multiple unrelated warning messages
- Power Steering Failure
- Car wont "Ready" ... Won't start. heads up
- Shift point program
- Loud metal clank when shifting between D and R
- Random misfire after installing NGK Ruthenium HX High Ignitability
- 2013 RX 350 frozen average mpg display
- 2010 RX350 HVAC Issues- Mode Servo & AC Amplifier
- 2010 RX450H - A/C problems (HOT air on one side)
- Bullet-proof / better choice, 2nd. gen RX vs. 3rd. gen RX
- Intermittent long cranking
- ac system diagram
- 2013-2015 RX350 gauge cluster removal
- "Trac Off" Message
- Which RX to buy 2014/2015
- RX350 2015 Apple Carplay
- Sputtering noise when given gas
- Refurbished air suspension
- The most hated B1479 code attack again
- Wheel Alignment Report
- Rattling noise after braking rx350-2010
- '13 rx350 oil pan replacement
- Part for my fender
- Lesson learned - don't go to a dealer for inspection
- Ticking
- Replacing radiator fan assembly
- 2012 RX350. PLEASE HELP. ECU?? Dash Cluster
- 2010 - 2015 door interchange
- 2015 Rx 350 Rear Driver Light Assembly
- Liftgate motor damaged in collision?
- Sticking button for up temperature drivers side.
- passenger side bumper partially fell off
- Is there cvt/gearbox oil filter for 3rd generation rx hybrid?
- Replacing or fixing AC Amplifier
- lexus rx450h 2010 sleep mode?
- Hitch-mounted cargo rack?
- Pumping out bad gas
- Oil capacity problem
- Diagnostics for 3rx
- Preferred Brand of Oil Filter and Oil?
- Wanting 2010 - 2012 Rx350 AWD
- 450h Front Left Popping Sounds
- 90,000-Mile Service Today
- Power Steering Hummm 2015 RX. New Guy
- Amazon music and bluetooth
- Short & Fuse Removal
- Error codes for BOTH rear wheel speed sensors
- parking sensor malfunction
- Locking/unlocking bizzer is not working
- New-to-us 2013 RX350 Base - wheels
- rear sway bar bushings
- Lower rear shock bolt problem
- Noise from Brakes/Engine Bay when stationary
- Removal of plastic in front of Nav Screen?
- New Guy with Questions... Maintenance
- HELP!!! 2014 Lexus RX350 acceleration hestation from stop
- Audio Settings?
- Replacing trunk lift-pulldown motor
- Front rotors
- Grom vline issues
- Window Tinting
- Bolt for front bumper cover and wheel well
- 12 good years
- 3rd Gen Highlander (14-19) Suspension On 3rd Gen
- Does the 4th-gen rear-view mirror fit on the 3rd gen?
- Oil drain screw looks different
- After Market Remote Start Issues
- seats rx vs is
- What to look for in a used RX
- Need Some Advise Regards To Wheels
- Reputable dealership / indie mechanic for service in New York?
- Seat covers for 2013 RX350? Recommendations?
- 2011 RX350 Transmission failure
- Rx350 Engine Mount bolt (water pump replacement)
- 2010 Lexus RX 450h front suspension and brakes upgraded
- 2012 Lexus RX350 80k miles service
- 2013 RX350 driveshaft center bearing carrier
- Acceptable way to change my coolant at home?
- Two different temps of AC?
- Nav monitor problems
- 2010 RX350 Coolant Reservoir Cap Hose
- 2010 Rx350 Hatch handle does not work automatically…key fob and inside button are ok
- Easiest Way To Hardwire Dashcam
- Windshield Cowl Drain Tubes ?
- Radio issue
- Whining engine noise
- 2015 F-Sport Wheel Replacement
- Front lower control arm bushings
- Looking for carplay other than GROM for RX350 2010 and suggestions?
- 2014 RX Oil Cooler Line
- Coolant leak on radiator fill neck
- 2014 RX Issue (Steering, check engine, etc.)
- 2013 RX450h horn working intermittently - suspect due to steering column ground
- 2015 rx350 engine noise
- 2011 Rx 350 Passenger Headlight Issues
- My 2012 Car /Cabin is Suddenly Noisy! 60K miles
- Alarm randomly going off
- Tightening chassis bolts and lubricating drive shaft service
- Why are my projectors on the inside?
- Overly tight steering on 2014 RX350 AWD
- bulbs replacement
- Any taller 'trail' RX's?
- 2015 RX 350 F-sport - OIL Cooler line
- Another Lexus Catastrophe: Engine Oil Cooler Pipe
- Body work
- Dealer recommendations
- Looks like some damage by my wheel anyone help?
- 2012 RX350 Rear interior removal
- the abs scam
- Sound from front left driver side
- Driver's side mirror
- 2010 rx350 sensor
- --Interior Rattles--
- What other fluids needs attention?
- Added my phone, now RX won't start
- Android Head Unit Replacement Ordered
- RX450H 2010 AFS sensor location
- car won't start
- Brake pedal don’t depress
- Part number for 2015 RX 350 headlight Leveling sensor
- 2012 Lexus RX450h P0011/P0012 and P0016 codes
- A/C not working 2011 RX350
- 2013 RX350 Roof Panel Noise
- Power Rear Trunk Not Latching At Times
- 2013 RX350 150,000 mile servicing
- 2010 rx350 sensor replacement.
- New 2011 RX 450H headlight assemblies look different
- Need help “”strange noise””
- 2015 Rx 350 F sport - fuel injection type
- Evap Leak causing O2 Code?
- Drive shaft issue, should I replace??
- RX 2011 tail light assembly removal
- Auto dimming mirrors look funny
- 2011 RX350 Up Vent Speed Switch not Working
- 2013 RX350 ABS module question
- 2010 Lexus RX350 o2 sensor
- 2010 rx 450h rear suspension solution
- Tesla-Style Android Head Unit
- 2010 rx350 with issues
- Fare Thee Well 3G RX
- Goose in the trunk?
- Left cargo area leak fix
- passenger temperature won't cool
- Fender Liner help
- Still have clicking sound after steering column replacement
- What is the flat black thing next to the USB port in the center console
- Transmission problems
- Key fob issue
- Enform apps
- Blew fusible link and can’t find part
- RX450h SE-i 2010 Reverse Camera
- RX450h SE-i 2010 Boot Lid Jerking Movement
- RX450h SE-i 2010 De-Cat Straight Pipe
- RX450h SE-i 2010 Loose Object Rattling
- Driver's door won't unlock
- Speaker Sizes
- park assist alarm
- Replacing left rear door panel
- Park Assist weirdness
- Manifold replacement part number question
- Rx450h cd player facelift swap
- Looking to buy RX 450h or 350
- HUD stuck too low :-(
- Lexus RX450H Intermittent Wiper Relay location
- Post-spark plug change problems (Slip Indicator and more)
- Cabin head light do not turn off!!!
- Not starting - fuel gauge empty
- Would you even bother saving this one (RXh with salvage title)?
- Back Ordered Parts
- Radio question
- Breaks malfunction after dead battery
- Can’t figure out what are rear lights and what are cosmetic
- Draining the battery in 30 minutes
- Anyone have rattling noises with Brand new KYB Excel G shock absorbers?
- How to mute door ajar beeping sound
- RS-R lowering springs feedback
- Installing sway bar bushings
- Difficult to start
- Replacing front CV Axles: Couple questions.
- Old RX V Newish NX
- Help and thoughts on which RX to get?
- Does all 2012 RX350 have backup camera showing in the screen?
- RX MPG Dropped by 3 MPG after New Drive Belt and Idler Pulley Service
- Cost of repairs
- 85,000-Mile Service Today
- Bluetooth started crackling all of a sudden.
- Odd creaking sound when shifting in reverse
- Lane change blinks change to 5
- Weird Electrical Issues with 2010 RX 450h
- Rear defrost causes radio to cut out
- seeking good independent shop i st paul, minnesota?
- All 6 Ignition Coil DTCs at the same time
- Strange noise from the engine area
- AWD or FWD...how to tell what I have?
- Getting rid of hill start assist light
- Rear Power Hatch Issue
- Infotainment system not working after car battery changed
- Need advice: OEM v. Aftermarket front fender
- 1st Timing Cover Leaking, 1yr. later high pressure oil line
- RX450h 2012 - rear loud bangs
- TPMS Receiver Issue- possible quick (but maybe termporary) fix.
- Anyone know which speaker wires are plus/neg here?
- Noise from radio
- 2015 RX 350 Window Tint Question
- What is this camera?
- Iphone 11 not clear
- Help - Check SRS Airbag light
- Rx450h ABS/Actuator question (c1391)
- BT function greyed out on 2012 Lexus RX450h - any ideas??
- Plastic around climate controls
- Lexus RX350 HID with AFS not working?
- Leaking oil
- Control arm repair. Are they serious, r&i the engine and transmission?
- Lower Control Arm Bushings Cracking
- Brake Light replacement
- Low beam bulb replacement
- Inline Potentiometer with Torque Sensor or Ecu
- What size bulb is this and how hard is it to change?
- 2013 RX 2 Years not an oil
- Fuel pump Noise ?
- Just bought a 2014 RX350, and want to upgrade navigation unit.
- New battery problem 2010 RX350
- Part Number(s) for VTT-I oil pipe (hose)?
- AVS information please
- 2015 Lexus RX350 F-Sport TPMS question
- 120K miles service coming up Lexus quoted $2100
- 2010 RX 350 loud popping and cracking in speakers
- Bilstein B6 (2014 Highlander)
