Left cargo area leak fix
Old Mar 15, 2023 | 12:18 PM
Ogeniver's Avatar
Ogeniver
1st Gear
Default Left cargo area leak fix
Water collects in left rear quarter panel cargo area and flows onto back seat carpet. How do you fix?
Old Mar 15, 2023 | 12:53 PM
Clutchless's Avatar
Clutchless
That is probably from the left rear sunroof drain tube being clogged. The best approach is to start removing the rear hatch panels back there until you find the drain tube. If I recall you can then separate it where sections join and try to clear it out with Weed Wacker Line or compressed air. Shove the line in both directions.
FYI it is almost impossible to reach the top of the drain tube at the rear of the sunroof from above.
See these threads and the first one has photos.
https://www.clublexus.com/forums/rx-...ain-tubes.html
https://www.clublexus.com/forums/rx-...-moonroof.html
and
raviola4
NX - 2nd Gen (2022-current)
Mar 28, 2022 12:09 AM
TryingBest
Nov 24, 2019 01:08 PM
Andyboy980
Northeast
Feb 18, 2019 11:53 AM
dbs600
Jan 14, 2016 11:19 AM
gs300-99
Jul 19, 2006 07:49 PM
