Factory tow package?
Old Aug 22, 2023 | 10:00 AM
Bdpakaknox's Avatar
Bdpakaknox
6th Gear
Default Factory tow package?
I'm in the market for a 3rd gen RX, and I need to tow a small trailer. But I'm noticing that basically none of them have a tow receiver or trailer wiring, so in guessing it wasn't a popular factory option. I'm fine with purchasing and installing an aftermarket hitch, but does the vehicle need to have the factory tow package in order to install a flat 4 trailer connector? I assume I need to look behind the bumper on the driver side to see if the factory connector is there, but is it possible to have that without the factory hitch/tow package?
Thanks all
Old Aug 22, 2023 | 12:15 PM
Clutchless's Avatar
Clutchless
If it has the factory tow package that includes the wiring which is hidden behind the rear bumper. None has the hitch installed unless someone did it after purchase. Look at etrailer.com for more info as they have great installation videos. Most of us have the Curt hitch.
The way to tell if you have the tow package is first see if there are vents at the front side of the driver side front wheel well as those are for the transmission cooler. Next look up under the car next to the oil filter for the oil cooler lines as only the tow package vehicles have the extra engine oil cooler. If it has the rubber lines they need to be replaced with the metal ones ASAP because they tend to break and all your oil spews out before the oil light even comes on! The twin shiny metal lines are the replacement oil cooler lines.
The other way to check a potential car is at the Lexus drivers site. You can join and enter the VIN of a car to see the build sheet and options. https://www.lexus.com/My-Lexus/account/create-account
Old Aug 22, 2023 | 01:09 PM
Bdpakaknox's Avatar
Bdpakaknox
6th Gear
Just what I needed to know, that is very helpful. Thank you very much!
Old Aug 22, 2023 | 01:57 PM
Clutchless's Avatar
Clutchless
See this older thread
https://www.clublexus.com/forums/rx-...d-threads.html
Old Sep 2, 2023 | 06:08 AM
jer's Avatar
jer
Active Streak: 30 Days
I also believe you can check via the VIN. Mine came with the tow package but no hitch.
Old Sep 7, 2023 | 05:37 PM
Bach42t's Avatar
Bach42t
4th Gear
Mine is a Canadian model, 2013 RX350. I did not see it when I plugged in my VIN but I indeed have the factory tow package.
Old Sep 8, 2023 | 06:52 AM
Clutchless's Avatar
Clutchless
I think all Canada models may have had it.
rmjvol
Hybrid Technology
Jul 4, 2021 09:43 AM
JDWhite
RX - 3rd Gen (2010-2015)
13
Oct 11, 2020 06:30 AM
My442
RX - 4th Gen (2016-2022)
Oct 13, 2018 04:49 AM
HowieNJ
RX - 1st Gen (1999-2003)
Sep 27, 2002 01:01 PM
