- Doors locked immediately when driver door closed
- 2013 RX 350 F-Sport - New Owner - Questions/ Possible Problems
- Rx totaled
- 2010 RX 350 Audio Buttons Not Illuminated
- Interesting dilemma: 2015 Lexus RX CPO or New Toyota Highlander Limited?
- Who do you use for OEM parts supplier on your RX
- driverside mirror
- Windshield Wiper Reservoir Leak
- Degregation in gas mileage
- RX350 that was moved from USA to Saudi Arabia
- RX350 Photo Red Light Violation video
- Transmission noise
- 3rd gen RX to which gen highlander?
- Need help on deciding which RX to get
- 2015 RX Tail Lights?
- Feedback RX450H used
- Headlight lense have a reflecting shadow?
- Adding Bluetooth to 2011 RX350
- RX450H Car Charger Location
- Which Year Model to Buy For My Second RX350?
- Hand wash or Automatic car wash
- And then it snowed!
- Interior lights
- Tie polypropylene rope through 5 wheel openings as "tire chains"?
- 2015 RX 350 - just purchased
- Lexus Insider Messages -
- 2013 RX350 - Rear Liftgate Issue - Opens with button but wont close
- Is it the right deal on a 2015 F Sport
- 2013 RX350 Remote Starter Kits
- Was my 450H used to tow a trailer?
- Missing front splash guard? - Looking for possible part #
- parking assist sensor problem
- full brake upgrade options on rx350
- transfer case, differential and transmission
- 60K oil change and a freebee
- Interior Lights -- Auto OFF?
- Rear Washer Fluid Reservoir?
- 2010 RX 350 Fuse Panel red strips
- ASL--what a joke
- Anyone using 17" rims?
- 2012 RX350 headlight bulb question
- Is there a way to keep all 12v outlets hot all the time
- 2010 vs 2013 RX350/400h Questions
- Key detected in Vehicle
- Can magnetic block heater be attached anywhere?
- Carista OBD2 adapter sale - 25% off. Also, you get 1 month free in the Pro app
- Reliability of 2010 and newer, upgrade or no?
- Other OEM wheels that fit - for winter set-up
- How to quickly find a destination on Nav
- Hood Shocks & Rear Trunk Shocks
- Trouble Shooting Bluetooth and Voicemail
- Wheels locked?
- RX CPO price
- 13 RX350 F-sport wheels tires for winter
- iPhone and Lexus
- P0051- oxygen sensor bank 2 sensor 1
- RX270 Light Towing
- RX 450H rear windshield washer pump and level sensor
- 2014 Rx 350 Pricing
- RX450 alarm sensitivity adjust!
- Driver's side rear shock replaced AGAIN
- Replace rear side marker lightbulb
- Rear Brake Pad Replacement Cost
- Do you have to drain the filter before you change the oil filter
- No TPMS sensors, but no warning??
- Help identifying "F-Sports package RX"
- Glove Box Door Won't Close 2011 RX350
- 3rd Gen RX Speed Governor?
- Getting new tires-alignment cost?
- Head Gasket leak/Coolant - 2010 RX 350 AWD
- FR. ACT. STABI. Warning
- O2 bank 2 n sensor 1 problems
- Door Seal
- Brake Lights Stopped lighting up
- Recall confirmation
- P0015 & C1201 Codes
- 2014 RX350 weird issue with iPhone7 fantom calls
- rear window defogger
- 2014 RX350 AWD vs. 2015 RX350 AWD
- Single Chime after Starting Engine
- Looking at 2015 rx 350
- Low tire pressure light won't come off
- Talk me out of a '13 Audi Q5 Premium Plus
- passenger door lock not working rx450h
- Aftermarket Wheels - Larger Width, different offset than OEM, is that bad?
- No Dash Kit for Aftermarket Radio?
- New to The RX Family... One question.
- Caster Adjustment
- a/c filter change
- Cruising Range increased from 245 miles to 362 miles?
- Shopping for a 2010 RX - General questions
- First time buyer TX, lots of questions!
- Optima battery fitment issue
- Sticky for TSB
- BSM too sensitive
- RX-F a good choice?
- changed the rear shocks on my RX
- See clock without vehicle running
- Maintenance Required Vs. Oil Change
- Is an Alarm/Security System Needed for a 2014 RX450h?
- Distinct Sound Coming from Steering Wheel Area
- Cargo Cover flaps connectors
- Lexus Parts Exchange Program
- cracked rim on my 2010 RX 350
- Get RX fixed without report
- RX 350 Sports Mode
- O2 Sensor Location
- Break in or lock cover fall off itself?
- Navigation with Napoleon syndrome
- What happens to headlights if you shut off car AFTER you open door ?
- Carista LPS options for my 2011 RX 450h
- rx350 19" original rim
- Warm up time
- Non-Tow Package Trailer Wiring
- AC not cold
- Aftermarket TPSM Installation Complication
- 2010 RX450h/RX350 - Engine Oil Cooler Addition
- RX350 Navigation System
- Getting new rear shocks installed
- streaks that come down from side mirrors on both sides?
- Dash Cam
- Need help removing footwell bulb
- Help Identifying a Part Number
- 14 Rx. How to tell if TPMS is working?
- Ebay LED interior 2013 RX350 $6.95 for the set + install tips!!
- 2015 RX350 excessive vibration at stop lights
- Estimated Costs for replacing Front Struts and Rear Shocks?
- Satellite Radio/Radio Fin
- Is AWD option worth anything when buy used rx350
- 2013 RX purchase help
- RX450h 2010 Questions!
- Auto Dimming Side Mirrors do not dim effectively
- New RX Owner - Maintenance Options?
- HID bulbs suggestion?
- Gear shift light not working
- Suspension Issue
- Headlight for a RX 350
- Replacing Rear Parking Sensor Housing
- RX350 VIN number not found
- USB Phone Charger Issue
- TPMS Question
- Finally the RX350 got tint
- Condensation in headlight
- Freeway exit information screen
- Vibration in gas pedal solved with sorbothane pads??
- Tow options for 2014 if I don't have tow package?
- RX350 Mirror Casing / Housing
- Toyota not so cheap
- Oddball Electrical Malfunction??
- Lease Buyout FL Help Not Going Smoothly
- ASL automatic sound levelizer
- rx450h locked inside by electrical failure
- Front Seat Power Adjust Issue
- Lexus.com service history for my 14 RX?
- Remove 2010 RX350 liftgate panel - help!
- Android Drive Assist instead of built in SMS
- power liftgate beeeep
- Shocks
- 2011 Lexus RX heated steering wheel
- Lexus Running Board Install
- First year for smart key and timing belt vs chain
- List of Common problems for 2014 rx 350?
- Plastic clips
- Multiple Malfunctions All At Once
- Anyone using Mirrorlink with 2014 RX350?
- Transfer case on 2014 RX 350
- XM data
- 2011 Lexus RX350 suspension
- who changes their own oil?
- Wheel Bearings...
- Weird looking engine air filter.....
- Rim Upgrade for the Rx 350
- Vin Decoder from Club Lexus Forums
- RX450h overhead panel removal
- Emergency Communication System?
- CPO and 30K mile service
- 2015 rx450h base conversion to f sport bumper
- Remote starter - OEM or after market? Help me choose?
- Downshifting hard at 30mph when coasting
- Battery life/replacement? (merged threads)
- 2008 GX470 or 2012 RX350 - Need Help Deciding
- is there difference F Sport Appearance and Package
- Front license plate delete
- question about lexus smart card key
- Nav. Update/ Possible Dealer Issue
- Minor Fender Bender
- Lexus RX350 battery cost
- Luggage/Suitcase space
- accidentally towed 4500lbs with my RX...
- Rear collission lights
- Passenger side CV Half Shaft interchangeable with Venza?
- 2012 RX-350 distorted/wavy windshield
- Low Humming Sound
- Center console cover / armrest cover
- 2010 RX350 Audio Issues
- Looking at 2013 RX 350, is this a good price??
- ride quality differences 2010-15, used car value?
- Please make this reminder go away!
- New look on my 2012 RX
- Help to find car keys
- What is this connector under my rear bumper
- cargo area rear seat release not working
- Better or worse? 2001 RX vs. 2013 RX......
- Replacing new battery, how ?
- 2012 RX-350 MAF ( Mass Air Flow) sensor cleaning easy or hard ??
- 2014 RX350 F-Sport Vibration
- 2013 Accessories Catalog
- what is the removable flap on the inside of the tailgate
- RX350 Grill
- Navigation question
- 2012 Lexus RX 350 Hesitation - slow to move after a stop
- Clicking noise during hard acceleration/reverse
- Squealing on start
- Discovered the mute button yesterday after a year
- Does IS rims fit RX?
- Buying a 2011 RX350 What do I need to know
- Connect iphone to car's screen
- Battery for 2012 RX350
- RX synthetic oil change
- Rx350 2009 vs 2010 best value and reliability?
- Compare 2010 to 2011
- Does 2013 Lexus Rx350 with Luxury package come with HID?
- 2010 rx 350 p0031
- Tow package standard on Canadian RX's?
- Parted with my RX this week.
- Key not detected, both fobs have new batteries
- Newbie with key fob issue
- F-Sport Paddle Shifters-What kind of clutch technology
- Suspension Torque Settings
- 2011 RX350 Audio Amplifier Location?
- Dash Designs - Dashcover for RX350
- Flash high beams also flashes HID low beams??
- 2013 RX350 F- Sport - Heat shield hanging from below
- F-Sport 2015 rough ride
- Text messages no longer displayed
- Lexus enform
- RX 450H GPS Mount
- Comfortable Driving...or Not?
- Running boards
- Help!! Lost trim clip piece in metal
- Driver Side Fender
- 2014 RX350 dashboard cup holder - removal
- Passenger Seatbelt light and air bag light issue
- 2014 RX 350: Run A/C without running engine?
- Past service print-outs
- O2 sensor issue - first p0057. Replaced sensor then p0161?
- Enter addresses into GPS from computer?
- Firmware update for 3rd Gen RX?
- Where's this from
- Front underrun
