- Slight Hesitation on acceleration?
- Question about Tire Alloy Rims 2010 lexus RX 350
- Steering Lock Actuator
- RX450h Front control arm replacement
- Key not detected sound?
- 2012 RX350 Max tire size
- What size socket for breaker bar?
- 2011 RX350 CAT got stolen during broad day light in Philly
- When it rains, it pours. Power Steering light
- Any differences between 2013-2014-2105 F-Sports
- Which Cars Will This Part Fit?
- Need Help With TPMS
- 2012 RX450 Check Engine On, No Codes
- General info and questions
- 60K spark plug change, ignition coils too?
- Any thoughts on this weird power/electrical issue?
- FIXED: Transmission vibration at various speeds under light acceleration
- Help identifying door panel metal clips
- Center dash speaker upgrade
- Insurance co listed the RX350 as a wagon
- Radio won’t turn off
- dash switch compatible fitting
- 3G cell service going away on older Lexus models (pre 2017)
- Drive Belt and Engine Oil cooler line
- Traction control randomy turns on
- 2013 RX 350 Radio Static
- 2011 RX350 "jerking motion" between 2d & 3d gear
- Navigation system went out, ac doesn't work, no radio
- Steering locked and theft deterrent light blinking
- 2010 RX350 Under Engine Coolant Leak
- Obsidian vs Stargazer
- Buyers guide help
- traffic button on dash?
- Anyone install Ambient lighting ?
- GROM VL2 vs BEATSONIC
- Rear Powered Liftgate Issue - Are new struts the solution?
- Lexus Rx350 brakes and rotors OEM vs after market ?
- Water on the passenger floor only
- Headlight problem
- Hood and rear hatch struts
- RX 350 F Sport Differences?
- 2010 RX350 AFS/HID Headlight Confusion
- FOB works, EXCEPT for locking, after battery change
- Automatic rear door doesn't work
- sound system, satnav, voice control, etc all lost?
- center console leather replacement
- Help with windshield rubber seal
- Can Get Rid of Maintenance Required Message
- Buying a Used 2015?
- USB / Cigarette lighter always on?
- Squeeking sound as I turn the steering wheel
- speaker replacement ? RX350
- Need help with cd player
- Black Wheels
- How To Change 2010 Tail Light
- 2012 RX350 Rear Head Cylinder Gasket
- Rain Leak Around Rear Power Tailgate Motor
- Anybody Using Super Tech 0W-20 Oil ?
- Seat belt extension, air bag off.
- Upgrade soundsystem
- DRL wire and fuse
- rx350 2010 - engine would not start (good battery)
- Side Mirror Heating no Longer Working
- Changing Multi-Informational Display Language
- 2015 RX350 w/o NAV = Want to update to Android Head Unit...
- What are these different bumpers about? 2015 Lexus RX 350
- 70,000-Mile Service Completed
- shift lever too long?
- Help needed: Convert HID to LED?
- Rear Coil spring shock @ 93K miles
- Engine Noise
- TPMS Warning light
- Anyone else get screwed by the Lexus app update?
- 2010 Rx350 will only lock passengers side door and trunk
- Strut mount
- Shut Off Rain Sensing Wipers
- Cracking leather seats
- Wobbly ride???common issue or is it mine??????
- Maintenance Required
- Rear Dash Cam 12V power source inside cargo hatch
- Vinyl? Leather? Both?
- AWD error/Trac Off/CEL after oil change and etc.
- Oil Gush out?
- Keyless Entry Buzzer Replacement
- 2010 RX350 Bluetooth Issues
- remove bulb
- Headlight types??
- To buy a New Jersey 2013 RX 350 F Sport? (105K miles)
- AC Compressor replacement
- 2011 Lexus RX 350 Transmission slippage?
- 2013 lexus rx 350 Motor Rotation
- Cat Shield
- 2010 RX350 Radio Issues/ Electrical
- --Brake Caliper Color Poll
- SOS light was always green, now red
- Brake rotor pics - 91k miles
- which fuse is for MAF sensor
- Rear hatch door won't lift when pressing button on the door
- DVD Monitor Won’t Stay Up
- A/C Issues
- how to remove 2010 navigation module
- Anyone replace their own brake calipers?
- Rear hatch only opens when heated
- What is this part?
- Need help identifying part
- P219C and other issues..
- Settings for locking car
- how to unscrew backdoor license plate screw from inside panel
- Rx 350 2010 -2015
- Front lower control arm bushing at 120k miles
- Roof Cross Bars Didn't Fit 2010 RX450H
- Original DAB Module
- Engine sound
- P0012 A Camshaft timing over retarded.
- Key Fob Cover
- 2015 lexus rx350 f-sport license plate front bracket
- 2015 grille removal help
- Used RX: Miles vs Years
- My RX 350 radio: Is it XM only?~
- Rims identification
- Auto Dim Mirrors
- Outside air only, no AC
- Smoke after new battery installed
- Steering column
- Inside Passenger Taillight assembly
- Lexus is350 brakes fit on 3RX?
- Lexus RX 350 mold/leaky sunroof
- 2011 RX350 Creaking Steering
- Year to year changes?
- 2010 muffler leak - Replacement options
- --New Led tail lights--
- OEM Audio System (with Nav) wired Most 50 interface
- Name of caller not appearing due to international prefix
- Left Turn signal stuck on flashing
- 3RX Seat Covers
- All rear passenger side lights are out
- Sirius/XM Radio Issue
- 17's on RX 350
- Shows no sign of life - could it be a simple as a battey
- Take off ECO
- Cant open the tail gate when running
- Cushion Cylinder Head Cover location
- Transmission oil leak help -2013 RX350
- How long to keep 2010rx350 with 140000 miles???
- Trouble starting
- Melting dash issue?
- BSM and Stability Control. 2013 rx350
- Unintended Acceleration/no brakes event
- Need Help: Tires
- B1441 Passenger Air Mix Servo Broken
- Haul full size mattress 2 miles
- Clear Bra Horror
- Long trip preparation/capacity questions
- Ex 350 milage
- F-Sport Steering Feel?
- Brake/ABS Malfunction after bleeding the passenger side front brake.
- Location of Vapor (Charcoal) Canister on '13 RX350
- etrailer hitch for 2015 rx350 issue
- 2013 RX350 Heat shield question
- Rear shock replacement by dealer question
- 2015 RX450h - RES+
- --My Modded Rx
- Afs headlamps failing?
- 2012 rx 400h liftgate wont open
- AC bar won't go away in nav screen
- 2011 RX350 completely locked up/frozen
- Rear seat cable release mechanism faulty
- 2010 Nav Question. Split screen specifically
- Need help with broken headlight spring clip
- CV joint going bad?
- RX350 vs. ES350 & Avalon for Daily Commute?
- Trouble Shooting Inquiry.
- Turn signal indicator in the glass of the side mirror
- Ghost in the audio
- Power Window Reset
- 2010 rx350 audio system not coming up
- HVAC fan lost high speed
- 2015 lexus rx f sport key gloves
- Trans help... P0741 & P2757
- Parking Brake Stuck..?
- 200,000 k.... doing plugs.... should I change the back coils at the same time?
- minor damage on 2015 Lexus RX350 F-Sport
- Removing shift selector indicator trim
- Auto seat position is hit or miss
- Stubborn rear shock upper bolt
- Battery malfunction??
- Weird power tailgate issue
- Dashboard and panel lights shut off completely when headlights are on at night
- Fuel pump dying?
- Goodbye Allen Key Differential Plugs!
- Whirring noise in dash at steering wheel
- Looking at 2015 F-Sport with Low miles.
- Best RX model 2011-2014?
- P106A. Did anyone have this code before? 2010 Lexus RX 450h
- 13 RX350 Advice
- Steering wheel slight noise question.
- Where to find random plastic filler for this piece on dashboard?
- Advice: 2015 Lexus RX 350 or Rav-4?
- Amp Repair
- 2010 RX 350 Spoiler Top piece glued?
- Tailgate stopped opening automatically
- P0990 Transmission problem
- Rear shock bottom bolts
- 2013 RX 350 horn relay location
- Alignment Issues
- Tire size 255/55/19
- Part Identification
- Help...Rx350 frame damaged leak???
- Cargo area RX350 vs RX450h
- Po990
- Blower motor replacement
- RX350 2011 Apple iphone 12 pro max ios bluetooth incoming phone call disconnects
- Window Belt Replacement?
- Intermittent Vibration At Highway Speed
- Broken lamp glass how to change
- Active Sway Bar(s) for F-Sport?
- Brake pads and Rotor for RX350 2015
- Vibration/hum from 45mph to about 52mph
- Whirly noise from rear after installing new brake pads
- Ghost in/on my Audio
- Alarm arming when doors unlocked after battery replacment
- Rear spring weld gone
- Hatch motor opens and closes with remote, and not hatch button
- Waze issues
- Rust by tailgate
- What is this hose for and should I replace?
- How to change weather strip for front windshield?
- Front oxygen sensor
- Window Seal Replacements?
- Front Strut Install ISSUES - Bilstein B6
- P0500
- Considering a 2014 RX
- 2010 RX with No Nav upgrade to CarPlay
- 2010 Lexus RX 350 Android Auto Unit; Need help!!
- Noise coming from Engine RX350 2010
- Extended acessories run time
- 2011 w/P0607 code after rain
- A/F Sensor Replacement Surprise...
- Soft brake pedal due to missing brake shims? Safety concern?
- inteerior light switch
- 2011 RX 330 tailgate repair
- Drive Belt and PCV valve
- RX 350 2010 few questions about how to
- 2011 RX450 Headlight moisture
- BSM warning light
- Trailer brake controller installation
- 2015 RX350 Base FWD replaced Rear Main Seal and Engine Timing Cover
- Left Sunroof Open During Rain, Infotainment System Malfunctioning
- junk trap/ rust issue
- Taking the car on the Auto Train and the alarm
