- 3rd gen RX w/ 4th gen wheels??
- Security locked please help
- Low Profile Driver's Side Mirror?
- Destination Assit intermittently not working
- Puncture tire, no leak (assuming)?
- What to watch for? - approaching 225k miles
- SiriusXm doesn't go pass 235
- Front seat replacement
- Rubber oil cooler hose but no warranty extension
- F-Sport Transmission Failure
- Floormat and cargo cover difference between '10-'12 and '13-'15
- ABS Light
- Tank strong drepression
- LED brake light resistor
- 2010 RX350 Need Hot Leads for Always-On USB Ports
- Is there a way to turn the engine off and radio on?
- New owner and new to the brand
- I Got Towed Last Week - First Surprise Breakdown at 241k!
- Noisy CD player
- Brake Pad Recommendation
- Cold air only on the passenger side
- Driver door misaligned. Need help.
- CPO Yr15 RX350 AWD $30K 38K miles good price?
- RX 350 2010 , custom modification advise
- Cleaning gunk out of caliper piston. Best method?
- Equipment list
- Trading a 2015 rx350 for a 2015 rx450h
- What should be done at 120k Miles
- 2015 rx450 front bumper guard dislodged
- 2012 RX Hood Struts
- 2013 RX450H Replace Tail Light
- 2011 RX450h - windshield replacement - radio issues
- Timing chain
- RX350 starts, shuts off, Power Steering Msg
- Rear hatch open issue
- Does the 2012 RX350 have the same trunk cargo size as the 2013 RX350.
- 2010 Lexus RX 350 Battery problem
- 2013 RX350 F-Sport Maintenance
- Rx 350 2010 , engine swap advice urgent
- Roof mounted microphone - move, replace, bypass?
- adding remote start to factory key fob
- Grille removal/parking sensor replacement
- Brake lights RX450h 2010
- 2013 F Sport to replace totalled 2006
- LED Foglights
- Are there models with air vents below rear seats?
- Fender liner plastic fixtures
- Yet another “unidentified sound coming from the rear of the vehicle” thread…
- Steering wheel cover
- HID head lamp upgrade
- Replacing rear marker light bulb
- 2014 RX 350 Grill Paint Specs
- Pre purchase inspection for timing cover leak
- How to delete all personal data
- VSC light sporadically comes on
- Headlight question
- RX 350 Question regarding possible purchase
- What Should I Have Received With My CPO RX350
- Window Tint
- Car doesnt read key FOB until the FOB is 1 foot away or less
- Console Storage Organizer
- Contact transfer failed
- Why does the 2013-2015 have a lower towing capacity?
- 2010 RX 350 Air conditioner issue
- 2013 RX350 lift gate issue
- Head/Fog lamp out
- Rx450h -11 check AFS system + TSC light
- Anyone Know Lexus Financial Rates now, for Financing a Purchase of 012 RX 350
- Any potential concern of this 2013 RX350 ?
- gas and windshield tank capacity for 2015 RX350
- Trying to understand 3RX audio options
- Touch lock not working
- ALL Maintenance lights are flashing when engine is running
- Winter Tire Fitment
- 2013 RX 350 FWD Lowering Springs
- Power tailgate and intermittent wipers not working...
- First Routine Maintenance Service
- Missing rear LEXUS badges??
- 2013 rx 350 window lock and window issue
- Rodent damage to wiring harness - where to repair
- Is it possible to fit the headlight and bumper from a 2013 RX onto a 2012 RX?
- Rear tailgate communication not working
- RX350 2013 Airbag light on
- RX 350 / 450H Cargo Space Big Enough for a Large Dog?
- Replace HID bulbs?
- Difficult to read oil level (2010 RX350 AWD)
- Winter Driving
- Heatd mirrors
- Looking to buy a 3rd Generation RX 350 - what should I look out for?
- '13 RX 350 Brake Pedal Electrical Buzzing Noise
- 2010 Rx 350 - power rear hatch issue
- Anyone SUCCESSFULLY installed aftermarket blind spot monitors on a 2010 hybrid?
- Help with bluetooth text feature...
- New Lexus Owner
- Brake fluid change
- Button between Display brightness up and down
- Siri eyes free navigation problems
- Poor experience in a french Lexus shop
- repair bill opinion please - non dealer, front suspension
- OEM front suspension assembly?
- RX450h with no sound from radio?
- GPS volume & GPS time
- 2015 rx 350 vs 2012 ml 350
- AWD mode is activated
- Check power steering system
- Need some help and advice with an RX 350 purchase.
- 20” wheels on my 2015
- Fan Belt Serpentine Belt replacement?
- Tire Pressure Sensor issue
- Headrest stuck
- Rubber strip came off
- Rear seats noise
- Trunk/Rear Door Rattling Sound
- Auto start
- Left front speaker not working on Aux
- HappyDancer triggers Airbag Warning Light
- First Tire Rotation Coming Up
- What month do new models get released ?
- 2015 RX350 Brake Pad Replacement
- OBD2 EML 327 connector
- 2010 450h questions
- Causing the VSC Dash Light to Illuminate
- Steering wheel shakes while braking
- Chips and scratches on 2015 RX 350
- Passenger side seat heater won't turn off
- Daylights/Headlights not working
- Service/Diagnostic Menus on Non-Navigation Trim
- Would you still buy your 2011 RX 350 today?
- Amp went out. Lexus/Toyota equivalent?
- How to show posted speed limit on nav screen
- 2015 Rx headlights in rain
- Codes Clearing by themselves?
- 2010 RX350 not pairing with my phone
- 3rd Gen RX Mode Servo Location / How to replace
- Long term reliability
- Cost to replace rear bushings
- How I sold my 2006 RX to buy my 2015 RX
- Power mirror not working
- Replacing D4S headlight bulb 2015 RX 350
- Is this a good deal on a RX 2015?
- Pandora via Galaxy S7
- RX 350 Rear Springs Diameter Size?
- Painted my Headlights :)
- Center console lid
- Liftgate not closing rx 350 2010
- Unknown wire connection
- 2013 RX350 lock/unlocking beeps.
- Transmission Cap O-ring
- Eye Candy 5 Minute Mod :)
- Smart Key Features!
- someone broke my window glass! Need some info
- Driver seat going back when about to exit auto
- Removing Headlights
- Right, Low-Beam Headlight not turning on
- 2015 RX350 Struggling to start
- Best USB connector for Google Phone and Lexus Rx350 2010
- Tail light burnt out
- RX and ES owners opinion wanted.
- 2010 RX 350 part ID question
- My 2011 RX 350 is jerking when I shift the gear knob to reverse and when driving
- Looking for Help (buying an RX)
- Anyone use Amazon basics Oil?
- Door Seal help
- Replaced tires , TRAC off
- Replacement front seats
- Looking at higher mileage 2013 RX350's
- Obd plug location in RX350
- Noise with brake pedal release
- How to reinstall the dome light in the rear
- Vibration after winter tire installation
- Traded in the wife's RX for a Highlander
- 2015 Rx350 Totaled or Not?
- Bluetooth Issue ('11 RX450h)
- Quick Question Audio
- Orange Colored Wood Trim
- 2011 RX350 alternator,electrical,??
- Problems getting Samsung 7 to play stored music
- Center screen "hangs" after voice recognition command on iPhone
- Underbody plastic cover part number
- Center wheel cap replacement
- Workshop Manual ?
- Tried LED headlight, no good. Anyone tried as well?
- Water Leak Under Steering Column
- hatch back
- Tire replacement or just wheel alignment is fine
- 2013 RX 350 upgrade ideas
- Noisy Radio Fan
- 2011 Transmission problems?
- 2011 Lexus RX 350 Aftermarket back up camera?
- 2009 rims on 2011?
- Inconsistent phone issues
- Interior Exterior Lights
- Extended seat rails for my 2015 Lexus 350
- Noisy Engine??
- RX350 2015 keys
- Oxygen sensor Rx350 2010
- 2010 RX350 Driver Seatbelt Issues
- reset after battery replacement
- Sliding console trays make clunk
- where to get proper wheel balance done
- Rear power lift gate not working
- engine block heater in cold climes
- VSC, Track light on RX 350 2011 / 69.7K miles
- 2015 RX350 Pros and Cons....
- Eco light
- Rear Cable seat release removal
- Rust on my Lexus!!!
- F sport shock swap to standard shock
- 2015 RX 350 engine tapping noise when idling
- 2013 RX450h/350 Headlight HID bulb Replacement
- What is this item on the rear passenger suspension
- Differences between,2011 RX and a 2015 RX
- rear power tailgate
- Compass in mirroe
- Climate settings won't keep memory
- Manheim recent MMR for used RX350 2013 - 2015
- Front signal light has double filament?
- Which Year 3rd Generation?
- Advice between purchasing 2014 RX350 and 2014 RX450H
- i have dvd head rest for 2008 lexus rx350, will they fit in lexus 2010 rx 350
- How to add USB drive ?
- Timing belt replacement -Should I?
- Need new brake light
- Relay access and locations/functions??
- 2011 RX350 with 64k miles - should I do it?
- center console cupholder Anti slip?
- Possible : Disabling the LED DRLs when Headlights are on ?
- Buzzing sound from inside
- 2012 RX350 + Platinum VSA
- 2015 RX350 - need cupholder adapter
- What and how much?
- Drl not working after changing bulbs
- 2012 RX 350 heated & cooled cloth seats
- What is this component in Engine compartment grinding noise!
- NEW Crystal Eye V3 Tail Lights
- I hate Sirius and how they control my radio in lexus 350rx. How do I get control back
- How reliable are the electronics in the 2013 RX350?
- rear caliper piston boot torn
- Random Chime/Alarm Sound
- How long does the 60K maintenance work usually take?
- 2012 back hatch opening question
- 2015 RXF Nav turn by turn question.
- A/C Needing Software Update?
- Making use of unused/fake buttons in 2014 lexus rx 350
- Need advice on a OE or OEM part
- Does Lexus rx 350 need winter tires
- Why? (no remote touch on some models)
- 2015 RX350 trunk trim panel removal Q (rear dash cam install)
- Question about different packages for '14 RX350
- Front Ball joints leaking
