- RX450h shivering at a stop!
- "New" 2010, couple of questions
- Tire speed rating requirement
- What is the minimum rim width needed for a 2015?
- Smart Access Key - Drivers Side
- resetting [maintenance required soon] message?
- Squealing sound. 2013 RX 350
- 2013 RX Iphone 6 pairing ?
- 2015 RX 350 Push button start - Key lost somewhere inside the car
- Winter Tires & Rav4 17" Wheels ??
- 2015 RX resale value with new 2016 RX
- Buying Pre-owned Lexus from Non-Lexus Dealership
- Winter tires
- 2015 RX Lease rate....good or bad?
- Question about CD player
- Illumation on the turn/washer lever
- Parted with my F sport....
- OEM Remote Starter
- 3d leather floor mats
- Galaxy S6
- Passenger side mirror 2012 RX350
- Headrests
- What tire spec do you use for winter tires?
- Navigation Quit = No Heat, No Radio! ('11 RX350)
- New RX350 Help with AC
- Got rear-ended help!
- 2013 battery
- So Long...
- 2010 rx350 cpo
- 2013-2015 RX owners need your help
- after market gps
- Need help quick!! Bumper question
- How to remove upper-portion of B pillar? Another ticking victim!
- Rx 2013 and 2014
- System loading, don't turn off the power??
- 2012 RX 350 rough idle on stop
- Oil Filter Wrench RX450H & filter
- Scratched My New Lexus While backing
- for you guys that change your own oil
- Mods plasti dip and steel
- how do you...?
- OBD2 Port Location
- Cam Gear Replacement @ 53,000 miles … $3900 to fix
- Should I buy 2016 RX 350 or 2015 RX 350?
- roof rack removal
- RXs, strollers, kids and wives!
- RX350 steering feels light
- Start Button: Is there a way to go from engine On to just electricity on?
- Questions about buying a 2010-2012 RX350 (model year differences, known issues, etc.)
- Unlock button, windows down but not sunroof? How?
- How to enable bluetooth for playing music?
- RAV4 vs RX 350
- Car Battery Replacement Steps
- Please help before I will buy my first Lexus
- Electrical problem on my 13 RX350 F sport
- RX 350 2015 oil consumption
- Towing a 3000 LB car
- Dashboard noise - how to remove/adjust dash
- Where do you get engine cover plastic clips?
- 2015 RX350 Fsport trailor hitch installed
- Passenger seat height RX450h
- 2010 nav question
- Can any recent 15 RX350 buyers fact check this?
- Can't switch from XM radio to FM / AM in RX350
- Navigation question '10 rx
- Flying mad with service
- I bought a 2015 RX450h *I THINK*
- Did Lexus Dealer Do Me Wrong?
- Edmunds Used RX Cost of Ownership
- Purchase advice RX350 RX450h new or CPO
- Patches of yellow on paint
- Angling side mirror when backing up problem.
- CPO RX 350 2010 found repaint bumpers and quarter panel
- Lowering RX: For the wife
- How to replace front/back emblem for RX450H
- Multi information display error
- Brakes and Rotors
- ? Re: aftermarket rims on RX 350
- Replacing Fog Light Bulb
- 35000 mile service
- Differential and transfer case fluid interval
- RX350 Rear brake pads
- Lower control arm bushings
- Front Tow Hook
- Cooled Seats Doing Nothing
- Best Oil for 2011 RX350
- 2014 RX Driver Seat/Bolster Issue
- Are front windows treated with anything?
- has anyone tried aftermarket nav?
- How to eliminate "Maintenance Required" message
- Tailgate clearance (inner height) dimensions?
- Looking at Buying an RX
- [Toronto] Recommendations for backup sensor (incl installation) for 2011 Lexus RX350
- Delay receiving text msgs
- Nx 200t
- Brake pad shims and rotars 2012 rx450h
- wheel swap FWD to AWD
- Making a Faster RX350 ?
- Safety Options
- Iphone 6, USB charging and no sound with phone navigation
- Interested in getting a Rx any Opinions/Suggestions?
- 20,000 mile service at Toyota dealer
- Display Audio vs. NAVI (2013+ RX350)
- Rust around the taillight on the rear hatch
- 2010 fog lights
- Remote start on 2010 RX 350? How does it work?
- 3rd Gen Price Drop After 4th Gen Introduced?
- What do you put in your 'trap door'?
- Upsell by Dealer: 4 Protection Plans on Leased CPO
- Help with Key question
- 8900 miles and im replacing a tire
- RX350 2012 gasoline grade preference
- Why I Replaced '14 w '15 RX
- Recommended 20" tire size ???
- OEM 19" Rims off set ????
- Clunk noise
- Leasing a 2012 CPO vs. Financing Purchase of a 2008
- VIN decoder
- replacing brake fluid
- Cryo treated rotors
- Rear hatch door on 2012 RX350
- Enform
- Lexus certified paint issue
- Dodge Durango rental vs RX
- RX in the garage for a month...
- Why did you buy the RX?
- Ventilated seat fan location
- 2013 rx 350 back door question
- Seafoam on 3rx?
- 2013 RX450h F-Sport -- How much would you pay?
- Turn off car, door open, beep.. why?
- Center console buttons and joystick not responding
- Tow Prep Package-do I have it?
- OBD II Reader
- RX350 Tire - sidewall cut
- Home link retrofit lexus rx 2010-11
- Bluetooth Firmware
- 2013 RX 350. CarFax missing maintenance.
- Illuminated Door Sills question
- 2015 RX450h - Roof Rails
- Advice/Opinions Re: '13 RX 350 f-sport Rear Bumper Replacement Costs
- Aftermarket Wheels?
- 2013 Air works then doesn't
- Aggressive look for RX350
- PCV Valve
- Must-have packages options for 2015 350 FWD?
- ABS Malfunction Error (post recall fix)
- How do I enter phone numbers MANUALLY?
- SiriusXM issues
- New Issue with Audio system
- Remote Start - Worth It?
- RX 450h Gear Shift Knob - Poor Placement?
- Lexus RX350 modification
- 2010-11 Oil Cooler Line Recall
- 2011 RX 350 Head Gasket leaking coolant
- "AMG Look" on a RX350 ?
- Courtesy wipe
- 2013 RX 350 Taillight replacment
- Water pump
- Service problem! Arghh!
- 2012 RX Brakes
- iPhone 4S no longer supported
- Larger Tires
- Pre-collision system experiences?
- Reset Maintenance Notice on Dash
- retrofiting dynamin cruise control on 2010 rx450
- Lateral performance damper??
- Front side window tint
- Heated Steering Wheel
- TRailer hitch on F Sport
- Rear HVAC vent controller
- Will 2013 headlamps fit the 2012?
- Driver Side Mirror vibration
- smoked taillights
- Auto Turn Signal
- 2010 RX 450h Runs Sluggish
- swapping tires on my newly purchased CPO
- Bunch of questions
- CPO RX350 current APR rate and ATL dealer info
- 2015 RX350 ride quality
- Vibration/wobble at all speeds. Not a tire/wheel issue
- Need input from F Sport owners
- 50% tint on the windshield
- Improving "auto" function of wipers
- Remove /Install Rear Bumper Side Lamp Fixture
- Shocks Leak
- 2011 RX squeal sound
- Dashcam
- Couple little upgrades to my 2013 RX
- Goodby RX 350 Hello Highlander
- 19" RX350 vs 450h wheels difference?
- Hitch Bling
- Porsche Cayenne winter tires on RX 350
- Bluetooth issues
- F-sport wheels part #?
- Customization option: A/C auto switch operation
- 2012 RX350 w/24000 miles
- dealer inventory
- Vendor recommendations for parts?
- going from 2013 rx 350 to 2015
- Adding Legroom
- Touch-up paint for grill on 2013 RX 350
- Truth in Reviews??
- Going From a '012 to a '15 RX
- Photochromic vs Self Dimming
- Question: say transmission breaks, who is responsible?
- Hello, maintenance questions
- Towing Limit on My 2012 RX350
- Original or aftermarket windshield?
- Extended Warranty (RX350)
- Power folding mirrors
- 2011 RX 350 Rear Back Up Sensors Only
- brighten lights on bottom of interior rear view mirror
- a/c diagnostic test on 2015?
- Headlights Not Tied to Wipers?
- engine cooler hose recall reimbursement question
- Light Leveler Computer (ecu) Location
- AC not working
- Disable "auto" funtion of intermittent wipers?
- RX450H, HUD has problem?
- Messaging/SMS
- Extended Warranties - Out of State Purchase?
- How smart is ECO?
- Inside Cargo Cover/Shade
- Trans Fluid Change
- Help me decide
- 2015 RX climate control
- Odor When Outside Air Is On
- Completely Lock Power Cargo Door
- 30k Service Booked!
- Need help (Rear Hatch Open Button)
- 2010 rx 450 hid fogs
- Map POI Detailed Info
- Phone connection in wife's RX acting funky
- Wheel surface peeling
- How to increase or decrease the duration of the cabin lights in your RX
- Stereo too loud in front too low in back.
- Problem with left tail light
- No alarm on 2011 RX350
- Headlight Leveler Motors location
- Which year to buy
- Is there a prefered on-line Lexus parts supplier?
- Mileage bar graph goes away with cruise control
- What type of Fuses are used?
- How do you turn ON/OFF ECO mode?
- Crack above radio and below nav on RX350?
- Hard left turn noise
- weak heated seats?
- Thoughts on Black Rims?
- Abnormal wear on front tires
