Light Leveler Computer (ecu) Location
Old May 13, 2015 | 01:52 PM
actman's Avatar
actman
Default Light Leveler Computer (ecu) Location
My suv is a rebuild and it originally had HID headlights. They were replaced with Halogen lights that don't have levelers. My dash comes up with Check Headlight Leveler error. I want to turn that off.
Someone on here told me to disconnect the Computer that controls the light levels and it's location is behind the panel above the brake pedal. My mechanic can't seem to spot it. Lexus dealer gave me a part number of 85967-08020 which turns out to be a computer ballast. Does anyone know the right part number and location of that ecu
Old May 13, 2015 | 02:26 PM
vlad_a's Avatar
vlad_a
You may want to subscribe to TIS (Toyota Technical Information System) for a couple days and get as many manuals as you can. It will be a worthy investment.
Old May 13, 2015 | 02:39 PM
actman's Avatar
actman
I did look into that at one point. However to find out where this unit is may not be that easy. Might be better luck finding help on here especially if someone has had that unit fail on them in the past.
Old May 13, 2015 | 03:03 PM
vlad_a's Avatar
vlad_a
The wiring diagrams I have for my IS300 have all of ECU locations.
With all the problems you have with this rebuild, tech manuals will be of great help.
Someone here may know where it is, but this being the RX forum, chances are lower than with other makes and models.
Old May 13, 2015 | 03:27 PM
actman's Avatar
actman
Do you thing in the wiring diagrams it will be easy to pick out the headlight ecu ?
Does it supply the part numbers and locations easily?
Old May 13, 2015 | 03:43 PM
vlad_a's Avatar
vlad_a
No part numbers. You can find those easy enough when you're trying to buy a unit.
But it does have a diagram of the whole car with each ECU, even connector mapped.
Took 30 seconds for me to figure out where it would have been and its name in the IS300 if I didn't know already: Headlight Beam Level Control ECU.
Old May 13, 2015 | 04:36 PM
actman's Avatar
actman
Ok u talked me into subscribing !
Old May 14, 2015 | 11:08 AM
vlad_a's Avatar
vlad_a
Cool. I've been meaning to subscribe myself to get the RX manuals, but haven't gotten to it yet. I just don't have a lot of plans for mods for it.
STi, on the other hand, will get an aftermarket remote start and an in-dash nav, so it gets first priority. But not before I finish replacing stock shocks and get my V1 hardwired.
kellyrene
Mar 3, 2014 01:32 PM
jay-b
Aug 25, 2010 09:28 AM
Jace_91
May 28, 2009 04:55 PM
spence288
Jan 15, 2009 05:28 PM
retrodrive
May 16, 2002 04:29 PM
