- Gas pedal unresponsive
- Temporary Short knock on Cold start
- Where to send 2JZGE Head for upgrade/rebuild??
- Is300 doors interchangable?
- non stretched tire size help xxr 521
- tail light fuse
- i need help 2jzgevvti ecu pinout please
- Any Phoenix area shops for engine work?
- errorcodes - who knows what they mean ? what to do ?
- Shift Extender 04 IS300 5SMT
- New Member! Any mod suggestions?
- IS300s good for occasional HPDE?
- Blue tooth interface.
- Throttle body problem please help
- Rough idle and brake like comes on
- Hissing sound near rear wheel?
- Just received my 1jz... harness?
- Changing Headlights of LEXUS IS300 (2002)
- Headlight Level Sensors Replaced - Dash Warning Light Still On!
- ATF Temperature Sensor
- 01 is300 1JZGTE vvti swap, intercooler?downpipe??
- My new 2002 IS300
- 01 is300 temp gauge went up
- New to the IS300 platform need some help.
- Serpentine belt Tensioner Pulley
- This Lexus IS 300 Pro Drifter Will Make You Rethink Your Priorities
- Riddled with indecision - to sell or not to sell
- Wheel Size Help
- 2001 is200 starting problems
- New to the forum
- 2jz Valve grinding Y/N?
- Hello
- Need advice on Parting out my '02, 5-speed, Black on Black ??
- My first is300 ! ! !
- Help identify wire behind glove box
- Timing belt confirmation - many photos
- Total Car Novice Needs Help
- coolant issue
- '02 Aftermarket Steering Wheel
- Looking to buy TRD side skirts and some other parts
- IS200 auto trans "problem"
- Coilover about to die soon?
- just a little help
- 2001 IS300 Trac Flashing & CEL on
- Just picked this up over the weekend
- Tranny Troubles
- Replacing exhaust on 01 Lexus IS300
- Taillight issue (taillight dim)
- new shims?
- squeaky clutch pedal
- 1 click when trying to start
- New here
- AC Drain Clogged
- 2002 control arm repair
- Melting interior
- 1uzfe vvti RS5R30A swap
- please help no center ac
- Auto to manual conversion
- Front Bumper
- lexus is300 tires size question
- IS Auto Geearbox question
- 2002 Sportcross NAV removal...
- What is this? Should a hose be connected to it?
- Just bought a 2005 IS 300
- foot well light
- IS300 Fuel Leak! Please help!!
- P0115 ects
- need any help plzzzzz misfring
- Its still a mystery
- Look at this.. Help Please
- Table board
- Is200 sport radio wiring harness colours -- please help!!!
- Potential Purchase Of a 2001 IS300 with 180k miles
- 01 is300 CEL on and traction control blinking
- OEM steering wheel e-shift button modification paddleshifter conversion
- Interior swap question
- car stalls while driving
- U joint question
- First Time Buyer: 2004 IS300
- Turbo Question
- New To the Forum
- Engine air flow
- Acceleration Lag in 03 IS300
- Fuel feed line.
- 03 is300,......fuel pressure... Help???
- FNG in socal here
- Is it a good deal to buy this Lexus IS300
- Rear Bumper Hit While Parked
- Is300 Aristo Swap
- :cry: Lost my car to a distracted driver. Looking for an IS300
- Alloy colour
- Help
- MAF sensor code..please help!
- Rear bumper help
- rest in peace
- Bad vibration while driving
- Signal lights dont work but hazards do
- Battery replacement Driver window not working
- TIP: Check Engine Light for Idle Air Control
- New guy!
- about to buy 2003 is300
- New to this scene !! and need parts
- Just picked up an IS300 and I love it
- Trunk wing spoiler
- Market price for 02 IS Sportcross with Salvage title
- Check Engine Light and TCS light - Odd Symptom
- 04 is300 east stl
- Identifying Hose
- Dealer or independent shop?
- Got a 2002 IS
- New project Is300
- 4th gear not working
- Low Engine Oil Light
- Is300 headunit help
- Trade high mileage is300 for bard gsr civic?
- just bought a SPORTCROSS excited!
- WTB r154 extended shifter housing
- Should I trade my g35 in for an IS?
- Lowering springs
- Electrical connections crumbling under hood, what to do?
- Sportcross rear seat
- FS threads go in the classifieds only
- Considering buying an IS300
- For sale threads go in the classifieds only
- Need advice on a turbo.
- Just picked up an 02 Sportcross, help!
- Newbie from SoCal (LBC!)
- GTE or Fully Build GE
- FS and WTB threads go in the classifieds
- Strange Noise IS300
- Help. Aftermarket subwoofer and amplifier installation
- Is300 wheel and offset help
- 2001 Lexus IS300 Not starting. Help please
- Engine Temp?
- Would Like some input. Current IS300 owner prior ISF owner
- Exhaust mount tab behind rear bumper
- Techstream 2005 IS300
- Urgent help needed - transmission
- Battery Charging Problems... PLEASE HELP
- W55/W58/NA MkIV Supra Clutch and Flywheel
- Tire sizes
- Refill for Lexus pens
- Help!!!
- Are these GTE or GE pistons? Help!
- Is300 rely issue??? Need advice
- DIY Remote Oil Filter Relocation Kit
- clutch disk question
- How to disable an aftermarket alarm
- Ignition Swap
- Can you drift an open diff?
- 1,100HP LS-Swapped Twin-Turbo Lexus IS300 Takes on Texas
- Odd noise in IS
- Anyone ever replace airbag(s) on an IS300?
- New Guy
- Rewiring fog lights
- USA gas octane ratings vs Europe and Japan (RON vs AKI)
- Considering to buy an IS300 for DD
- N00B here with an SXE10 Converted RHD Lexus IS300
- Selling Wide Body Kit
- Swapping my is300
- Price estimate
- 04 lexus is300 dome lights
- aristo trans in first gen
- My car is going crazy
- Friend going to Japan, what would you want from there?
- Headlight issue
- Please help
- IS300 aftermarket stereo
- electrical help
- Magnaflow Catalytic converter
- New to the club! i need help!
- Electrical Mirror Syncing Problem
- Cheap wheels and tires?
- New to the site..my lexus
- GTE internals and HG
- new to this site & new to Lexus and put low octane smh
- 1st gen factory NAV.... rarity?
- Tint percentage on a pearl white IS. Post up your tinted IS300
- Full interior swap
- 1st gen IS300, First Impressions
- Timing belt help p1656
- New owner of a 2003 IS300
- IS300 with BC Coilovers ride comfort
- Belt Pulleys
- Do supra twin turbo wheels fit is300?
- Need cats for california spec car
- 2001 is300 Motor Mount R&R
- Wheel fitment
- just came across this, VVTi 1UZ 6-speed manual IS200
- Purchasing a 2001 IS300 with 128k
- Question on crank balance
- Rev limit problem at 5500 from neutral switch
- Need break light help......
- IS300 Exhaust Manifold
- AEM V2 Is300 2jzGE VVT-I WireHarness help!
- issues with my is300 2001
- Low volume from Kenwood DDX371 after battery died
- Picked up an 01 IS300
- Official brake spesefications?
- Looking for a decent roof spoiler - 02 is300
- All FS & WTB go in Classifieds Section Only
- In Search of Manual Transmission IS300
- is this possible? can u turn the mileage back?
- Canadien models.
- Need help on rim size and fitment
- I need help replacing hood latch
- new to lexus
- New Owner - Found a Gem
- new to the forum
- 2002 IS300, 150k miles -- has over 30 check engine codes?!
- Laid Down 461whp/404tq (Pump Gas)
- Leaking coolant
- 15k mile SportCross in 2016?!
- question on the new light bulb
- Not Ready/Failed Smog Check
- All new IS300 Turbo Kit - Review
- Need Help Picking An Used IS300
- Installing aftermarket steering wheel, can I bypass SRS?
- What to look for when buying a IS300?
- Will These Wheels Fit?
- New CL Member
- P0031 cel 05 how many o2 sensors question
- Major Electronic Failures, NEED HELP!!!
- No Dash Lights; Engine will not rev past 4000 rpms
- L-tuned body kit? ID help
- Help with headlights
- To Air intake or not to air intake? That is the question
- Exhaust Manifold
- Help my is300 battery is low....
- Can't disconnect door lock rods from clips
- bad relay killed my battery?
- Keep getting cylinder 5 misfire-.-
- Megan downpipe hks exhust?!?!
- IS300 Fuel Door Release
- Lexus Car Horn
- Traction control module
- New IS300 owner
- New Owner and SportDesign and Bushing Question
- need help plzzzzz
- is300 bumpsteer
- Im New!!! multiple misfires! please help!
- Running 18's on my is300
- How-To Tuesday: Replacing the Brake Lines in Your Lexus IS
- GTE Coil on Plug Conversion?
- Sportcross - Restore project
- light by shift knob dont wrk help?
- 05 IS300 CEL ON and "Trac Off" light blinking N/A 01/01 code
- Lexus is200 timing belt replacement
