IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Low Engine Oil Light
Old Jun 20, 2016 | 07:13 AM
mitsuman's Avatar
mitsuman
Default Low Engine Oil Light
My low engine oil light has been coming on/off periodically since my last oil change I had done at a reputable shop.
I have check the oil, and it showed it has been low, so I have added oil a handful of times.
Anyone else deal with this? precursor to a larger issue?
Old Jun 22, 2016 | 05:52 PM
DrDDay's Avatar
DrDDay
Leaks you can see?
I would start with the valve cover and oil pan gaskets.
Old Jun 23, 2016 | 03:29 PM
mitsuman's Avatar
mitsuman
There seems to be some small leak somewhere. Not the valve cover though. That gasket was just replaced less than a year ago.
The thing that bothers me is it comes in for about 20 seconds, then goes away. Then comes back on later for another 20-30 seconds.
Old Dec 28, 2016 | 09:59 AM
Shanenest's Avatar
Shanenest
5th Gear
I have the same thing in our 2006 GS300. The low engine oil light comes on intermittently. Did you ever figure out what the problem was with yours?.
Old Dec 28, 2016 | 11:04 AM
mitsuman's Avatar
mitsuman
I have a leak in my oil pan gasket. Changing it out next time I change the oil.
Old Dec 28, 2016 | 12:17 PM
ForzaF's Avatar
ForzaF
Your oil pump might be on the way out .I had this issue on my integra especially standing on the red light , as soon as the car was going it went away as there was sufficient pressure again. I would get it looked at asap as you can damage your rod bearings and scorche the crankshaft.
Old Dec 28, 2016 | 12:22 PM
tonynca's Avatar
tonynca
It's more likely that the oil pump is going bad than a leak on the oil pan. I would definitely change that out asap before the engine goes away....
While you're in there might as well change the timing belt and water pump if you haven't done that in awhile. They're cheap parts that could be worthy of a replacement since you have everything apart.
azncaboy
Dec 9, 2022 11:58 AM
LexusES30
Mar 23, 2019 05:22 PM
carlosL250
Apr 6, 2012 11:17 AM
gtr02
Nov 13, 2011 03:16 AM
sehnsucht
Mar 17, 2010 03:00 PM
