IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
IS200 auto trans "problem"
Old Sep 22, 2016 | 05:00 AM
Amoze's Avatar
Amoze
Default IS200 auto trans "problem"
I hope someone can give me some ideas what is the problem with my automatic gearbox
I bought a IS200 -99 with auto gearbox. When I start the car when it's cold and put it to D... The car seems to slip/rev a bit too much and there is a small delay before the car starts moving when I push the gas pedal. The hesitating is something like less than a second but I noticed it immediately because it is noticeable enough to feel kinda very "weird". Also when cold the kickdown doesn't seem to work when I mash the pedal. The car is changing gears without a problem when cold and there is also no delay between changing from P to D etc... Also I don't notice any powerloss or slipping when driving cold or warm.
When the car warms up it's 100% fine and nothing wrong with kickdown or that kinda "slipping" in low speeds. Repair manual says it has had gearbox fluid changed in a toyota shop about once per year/10000km for the last 4 years so there seems to be something wrong. Also last change was 8000km ago and fluid is still almost blackish and a bit burnt smell
I was thinking maybe that small toyota shop put wrong oil in the box few years ago because there was a castrol sticker next to that repair notice. I think these auto boxes are the same as supra transmission that they require the toyota type-T oil to work properly?
Do you think there's any chance that it might be fixed with a flush and fluid change or better to buy a new second hand transmission straight away? In here you can only buy Toyota type-T fluid in 5L jugs so not that cheap of a trick to try if the box is broken
jacal
LX - 3rd Gen (2008-2021)
12
Mar 1, 2016 03:56 PM
Sleepy2is
Oct 28, 2014 04:17 PM
mikeli689
24
Jan 4, 2014 05:33 AM
Tha Cash
Oct 9, 2009 07:52 AM
flipicanez
Mar 24, 2008 06:40 AM
