IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
squeaky clutch pedal
Old Sep 13, 2016 | 06:38 AM
familydude's Avatar
familydude
Default squeaky clutch pedal
Hi,
Just signed up with Club Lexus. Wondering if someone can assist me with my IS300 (2002) manual - squeaky clutch pedal.
I've tried lubbing it and basically found out that there is a plastic piece that needs replacing and is the causing the pedal to squeak. It comes and goes but at it's worst it's very loud and annoying.
I've also inquired a CLUTCH PEDAL ASSEMBLY KIT from the dealer and it's awfully expensive.....not worth it, especially for one particular piece.
My mechanic suggested I ask this forum to see if I can get any leads on a used one or any other ideas.
Thank you
family dude
(Toronto, Canada)
Old Sep 14, 2016 | 07:03 PM
01MSMSXE10's Avatar
01MSMSXE10
What plastic piece are you talking about there are several pieces that are plastic on the clutch pedal assembly. What did you use to lubricate it?
Old Sep 15, 2016 | 07:13 AM
familydude's Avatar
familydude
Hi 01MSMSXE10
We used Lithium Grease. It works for a while then the squeaking returns.
as for the plastic piece this is what I can tell you:
ITS PART OF THE PEDAL ASSEMBLY....A RETAINING PLASTIC 'CLIP' that holds the spring...
Does this help? any suggestions or advice?
thank you
F.G
Old Sep 15, 2016 | 09:24 AM
01MSMSXE10's Avatar
01MSMSXE10
Originally Posted by familydude
Hi 01MSMSXE10
thank you
F.G
I'm assuming you're talking about 31301C (part number 90386-13015)?
http://my.is/forums/f115/squeaky-clu...-fixed-441275/
Old Sep 16, 2016 | 11:43 AM
familydude's Avatar
familydude
thank you 01MSMSXE10
I will forward this and hopefully find a solution
best,
family dude
Old Sep 27, 2016 | 05:46 AM
familydude's Avatar
familydude
Hi 01MSMSXE10
Thanks for the advice. I ended up changing the bushings and another clip which fixed the problem!
I changed parts 31301C (there were 3 of them I had to change)$12 and 31301P (one clip) $5.50.
Thanks so much for the advice.
Now it feels brand new!
Family dude
Old Oct 16, 2022 | 12:21 PM
knglulu's Avatar
knglulu
Default Tutorial
Hi 01MSMSXE10
Family dude
Could you help me out? I have a 2IS 6MT but from the diagram it looks like a pretty similar issue. Ive tried lubing the part the spring attaches to and it helps ish. still prevalent. im not sure how to change the bushings and was wondering if you could walk me thru it
Old Oct 17, 2022 | 03:55 AM
2001SolarY's Avatar
2001SolarY
Active Streak: 30 Days
2nd Gen are not the same. You should ask in the 2nd Gen forum.
familydude
Maintenance
Dec 29, 2016 08:38 AM
PseudoK
Feb 9, 2014 05:40 PM
Phommadong
Performance
May 24, 2011 07:05 AM
TLDriver
Jul 10, 2008 11:42 AM
5spdSC300
May 26, 2005 07:59 PM
