- IS350 60K Mile Service...any other advice?
- New (sort of) returning after a hiatus with ask for help.
- Squeaky driver seat
- Is350 (2008)
- Intake sound Generator on 2is?
- More intake noise
- 09 is250
- IS250 Subwoofer
- 2009 IS350 Advice
- Advice/ what wheel is this from?
- Infamous P0420 code. Please help.
- 2006 IS350 won’t start, HELP
- I need help best tune+intake+exhaust for 2012 is250 awd
- Anyone got experience with prepainted ebay bumpers?
- 2006 IS 250 - Latest navigation DVD
- How to set calendar in 2006 IS 250
- Spare Tire Replacement Kit - Weight Reduction for those with BBK
- Sound of water for few seconds when starting IS250 RWD
- Any problem with these spark plugs?
- Getting rid of HID and going LED - H11 don't plug n play?
- Replacement tires
- Aftermarket microphone placement?
- °F coolant temperature range for gauge
- 19x8.5+35 F 19x9.5+30 R
- Replaced headlights, don't know this plug goes
- IS350 fuel pump replacement DIYs?
- 2011 IS350 sputters then dies...
- Question about ECU updates from Lexus
- 3GR-FSE swap
- Engine Completely Died VSC/AC/Check Engine
- Glove box door silver trim
- help with gas mileage
- Loud noise shifting from 1st to 2nd (06 IS350)
- Anyone have any review on the economy front bumper?
- Crashed my 08 IS250 RWD into a pole
- Knock Values in Techstream
- My Lexus IS250 2007 drags to accelerate
- Lets see your DIY CUSTOM WORK that was done BY YOU!
- 2007 IS350 w/ 128k Miles
- Brake change
- 09 is250 AWD w/ H&R springs
- Is this 2007 is350 a lemon
- Wheels and Curb rash.
- ? 2011+ Headlight conversion for 2010 IS 250 with HID?
- Battery replaced and now vehicle will not crank
- CAN Bus ID's or data
- Looking for Aftermarket headlight options for 2010 IS 250
- AWD Midpipe options?
- Pricing on 2IS and reliability
- Turn signal on mirrors 2011 Lexus is250 awd!!
- 2007 is250 - Center Console 12v Power Outlet not working (changed fuse and part)
- My wife discovered what the PWR/Snow switch does
- Access to Rear Differential Carrier Cover
- Buying an IS250
- Tiny bulb in headlight
- Buying an IS350
- 06 IS350 18-inch Fitment Question
- Programming a Key Fob w/o any Fobs
- Need help connecting a curt universal 4-wire tow harness
- 2006 is350 problems with aux , and audio / good shops in tampa??
- brake fluid question
- HELP! Lose all power once car is off
- Help! Identification of a Hose
- Megan OE-RS Catback
- is250 6mt single mass steel flywheel
- IS200 Headlight Relay
- Any cheap way to clean rear view mirror?
- New OnePlus will not stream to bluetooth- UPDATE- Got it working
- IS350 Engine Swap in IS250?
- Cheap 18inch wheels for 2006 is350?
- Check engine/VSC light help
- Check engine traction control check vsc
- Front Passenger Wheel Bearing/Hub Assembly Replacement Help!!!
- Buying used is350..can't choose between 06 ' with 85k or 08' with 105k
- Battery? Altenator? Somethng else?
- Looking for a 2012 Lexus IS 350 f sport
- Loud whirring sound when accelerating around 2k - 3k RPM
- Diy dashboard fix
- CV Axle failure - Boot not ripped, band fine - Grease coming out from metal cap
- Headlights
- Loud knocking screeching noises when turning on aircon and heater
- Vibration in gear
- IS-350 2008 driver seat cover?
- Remote Start
- System too lean and 02 sensor signal stuck
- No sound from speakers
- 2012 front clip
- VSA light and misfire codes
- Brake pads! What y'all using!!
- Is350 turned off wont start back up
- Term (2IS)
- Lexus is replacing my IS350's Dashboard
- 2006 IS250 transmission problem.
- Need YOUR expert opinion
- Will these rims fit my is350?
- 2007 IS350 150000 hard to start but starts
- has anybody tried the Sony XAV-AX8000
- Power and Ignition supply for instrument cluster
- First NORCAL Lexus Meet of the YEAR!
- LED Conversion Kit (Lexus IS 250, Year 2008)
- 2IS Help Me Decipher Whats Happening With My Engine!!
- 2IS Hidden Wiper Interval Features? Yes!
- Tesla style radio for 06 is350 with nav
- HKS HiperMax GT IV
- My IS250 is jerking and not sustaining it's motion
- Help Deciding Between 2 Used IS 350's
- Let’s See Lexus Wheels
- 2013 lexus is350 VLAND OR STOCK
- Lexus advises to uses 5W30 instead of 0w20 in 2nd gen IS
- Suspicious Service from Lexus Dealer
- Paddle Shifters
- Good Car Battery Dies Very Quick!
- Another Tesla Style Nav Unit - With OEM Style Buttons!
- Car turns off when shifting
- OBD Apps | Torque Pro & OBD Fusion with PID pack
- Stupid (Mustang) Wheel Question.
- bought used 19in f sport wheels
- Canada spec radio??
- VLand vs OEM output
- Amsoil Oil Filter for 250
- General Information Request
- Kali Maa shakti de
- 2006 Lexus IS250 Dead after Battery swap
- For Sale, Want to Buy/Trade threads go in the marketplace only
- Navigation Connector Conversion?
- Short shifter project for 2IS complete and a success
- Part name?
- p0172 is back!
- Alternator Interchangeable with Toyota cars?
- Power button question
- Radio and amplifier pinout diagram
- Service/Shop Manual (not Owners’ Manual)
- ABS and Brake lamps but no code?
- Trac light and check engine light
- 2010 IS250 with 45k miles - looks pristine - should I?
- 2008 IS250 Repairs help!!
- 2009 IS250 DRLs
- Is250 p/s light
- Rwd boys! Hows driving in the snow?
- For-sale items go in marketplace - not here
- 17" MSW wheels on an IS350
- Tires! Staggered or square?
- Is350 Wont start (won’t turn over really) battery good
- RR Racing tune for IS350
- Contest, who has the highest mileage IS250 ?
- Navigation system and display system not working
- Looking at a high milage 06 IS350
- Losing break fluid
- Replacing mid-exhaust
- IS250 2007 Aux/Bluetooth/Carplay Options
- Own a 2008 LS - want a 250 "real" manual trans car
- Considering a High Mileage 2006 IS 350 RWD
- RPF1 on tungsten pearl?
- 2008 Lexus IS250 doesn’t start
- Need Guidence (IS-300) 2008 Mark Levinson SUBWOOFER
- 2008 is250 all warning lights up
- Carbon build up engine replaced but check VSC light still on
- Running out of ideas with this code.
- Nav back connections diagram?
- Resistor and capacitor on secondary wideband o2 sensors
- Tach needle not working when cold
- High Mileage Transmission Fluid Change
- Headlight Shuts Off Intermittently
- 2006 IS350 androids head unit installed
- Genesis track 19 wheels on 2nd gen ISx50
- Anyone doing long distance driving?
- Symptoms of bad alternator
- Crankshaft Sensor - 2008 ISF
- Anyone have a good trans pan gasket part #?
- Sold my IS250 about a year ago and bought a 19' RDX
- High Mileage Car Check-Up
- Used Buying Guide
- 2006 IS350 wont crank. New battery
- Opinions and advice on Idle
- Question on tire sizes
- Impressions of the IS350 after almost 4 months of ownership
- tire sensors
- Downstream denso sensor for RWD
- Front seat bolt thread pitch
- 2009 is 250
- 07 is250 with problems
- How does a slipping auto transmission feel
- 2007 Is350 tranny code P0986
- Climate and radio dead
- New 19" ebay wheels
- IS250 Coolant Change
- 2008 IS250 Electrical Problem
- No Sound Amp
- What makes up F Sport besides appearance?
- Bluetooth Issue
- I need help finding Parts for a 2012 Lexus is250
- Can't Communicate with IS 250 OBD
- help: code B1795 occupant detection ECU corrupted software
- Question on installing LED Bulbs
- Front bumper scrape bottom of the car is damaged.
- What is this sound inside the car coming from my AC system?
- Help with my A/C
- BC Racing replacement parts
- How can I get to subwoofer?
- Opinions on a used IS F steering ECU
- Lexus is250 wont start No brake lights...
- WInter time block heater
- 2008 IS350 Headlight cracked, bulb out
- Vland headlight aim adjustment
- Opinion on Price of 2007 IS350
- Oil and Oil Filter Recommendations
- Replacement Navigation Solutions
- New Owner 07 IS250 AWD
- Black screen 06 IS250
- IS250 AWD rear end help needed
- ISF Rims on IS250
- 2009 is250
- 87 for a month instead of 91 *RESULTS*
- Help on wheels size
- Boys I need your story on MAINTENANCE
- Tranny Problem that NOBODY can solve!?
- Wheel pattern
- 2008 IS250 Display is dead. No lights and buttons work
- No sound after sub/amp install
- 06 IS350 Cuts power under full throttle
- Year to year differences/looking to buy
- spark plugs
- My IS250 won't start
- 2is Amp dead again any options?
- Smart key card on 2007 is250
- IS250 Limp Mode CEL 3 codes disappeared after restart
- New noise & unknown part on 2006 IS250
- 07 is250 went to limp mode and 3 Errors and back to normal
- Screws/Fastens for Radiator Support Assembly?
- Manual Transmission RA63 VS RA62
- No more red triangle!
- Clunking sound when backing out of drive away and going over bumps
- Temp gauge shows lower after long drive
- Clunking nose when turning wheel. Ball Joint?
- AC Compressor Replacement 2006 Lexus IS 250 AWC
- Driving without instrument cluster
- help needed to identify engine tapping noise on is250
- car pulls all over road
- possible IS purchase..some questions...
- VSC Check with trac off light
- HELP!!!! Trying to program my old 2Is keys to my replacement ECU
- Wrecked IS250: Parts Fitment Questions
- Removing Rear Muffler section of exhaust IS250
- Driver window rattle help.
- IS350 Code P0020 - Camshaft sensor problem
- Pre-facelift vs facelift models
- Questions about replacing rear axles.
- Time to change IS350
- Melting Dashboard -- out of warranty
- Who knew.... 2013 recall for stickies
