Used Buying Guide
Old Dec 15, 2019 | 07:56 PM
Moisture's Avatar
Moisture
Default Used Buying Guide
- Listen to the engine with the hood up both from a cold start and when fully warmed up. Shouldn't be any odd noises except for fuel injector tick
- Peek inside through the oil filler neck. Whatever you see should be clean. Look inside the oil cap and smell it.
- Brakes should look smooth. Score Marks inside the rotor indicate aggressive driving
- inspect tires. Work outer edges indicate hard cornering. Ensure tire wear is even to rule out possibility of worn suspension or bad alignment.
- drive over a speed bump. Suspension should feel tight and not make any sounds.
-paint should feel waxy smooth to the touch, not gritty at all.
- look for excess build up on the exhaust tips which may indicate rich fuel mixture or oil consumption
- shift into all the gears. Should be smooth doing from drive, reverse park etc. Manual transmission shouldn't be grinding.
-smell the exhaust during cold start. Strong smell of fuel could indicate injector problem. Oil smell could mean excess consumption
-very closely inspect all body panels. They should all match in colour tone. Look for overspray inside the engine bay and door sills. Closely check all panel gaps with your finger to ensure consistency
Old Dec 15, 2019 | 09:24 PM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
There is an exhaustive and 2IS specific buyers guide linked in the FAQ sticky at the top of this forum that members will find informative if you are shopping for a 2IS (as well as other potential buyer links)
https://www.clublexus.com/forums/is-...e-threads.html
Old Dec 16, 2019 | 09:12 AM
primavera's Avatar
primavera
Why you're trolling bro? Got nothing else to do? You joined the forum 2 weeks ago and left almost 200 comments! Just yesterday you've left 30 comments on different forums! Who does that???
Do you even own a Lexus??
Get a life!
NLLex
Apr 28, 2020 02:30 AM
