2007 Is350 tranny code P0986
Old Dec 13, 2019 | 10:11 AM
shuiyuan's Avatar
shuiyuan
Exclamation 2007 Is350 tranny code P0986
Hi, i need help on this issue, my car had shifting issues from 4th downshift to 3rd, it will jerk pretty hard, i thought is a ECU issue so i sent to SIA electronic for rebuild
now i have P0986(Shift Solenoid 'E' Control) pops out 5-10 seconds everytime after i reset the code with my odb2 scanner, anybody has experience on where is this Solenoid and where to buy it? Thanks for reading.
Old Dec 13, 2019 | 10:37 AM
Moisture's Avatar
Moisture
You need to replace your shift solenoid- specifically the one which controls 4 -3 shift. You may as well replace all of them, as it will make your transmission feel like new again.
You need to drop the pan filter to access it, which is perfect because you should replace it with a clean one and add fresh atf fluid in there anyways.
Moisture's Avatar
Moisture
I'd recommend taking it to a transmission shop. Do not drive the car anywhere else as you will damage the gearbox.
Old Dec 13, 2019 | 01:38 PM
shuiyuan's Avatar
shuiyuan
thank you so much for your fast reply, do you know which one is solenoid E?
Old Dec 13, 2019 | 04:38 PM
Moisture's Avatar
Moisture
No clue. their are a lot of solenoids in there. I would simply replace all of them.
While you have the pan apart, you might as well rebuild/replace the valve body too.
Iamproctor
Aug 21, 2020 08:34 AM
Lexluuuger
Jan 23, 2015 08:46 AM
legendary1
Jun 20, 2014 01:44 PM
Ether1227
Oct 11, 2010 09:22 PM
900cc
RX - 1st Gen (1999-2003)
Nov 24, 2009 05:47 PM
